Rooster2
11
Everything posted by Rooster2
I am the guy, who promoted Trans-X as a product to fix Subaru "tranny delayed forward engagement," and wrote the original thread about 3 years ago. Unfortunately, this is a fix for a problem unique to '99 and '00 Leggies with automatic transmissions. So, sorry, but I don't think that any amount of Trans-X will fix your problem. There is a considerable amount written about ATs on this website. From what I have read, and only from what I have read, the recommendations that I have seen is to replace a bad transmission with a good used one, and not spend a lot of time or money trying to fix an ailing tranny. Subaru automatic trannys usually last a good long time so I have read, and as a result, buying a good used one from a wrecking yard is pretty inexpensive, like maybe $200.
Prolly the easiest way is to do minimal re-wiring . Tap into a hot line, then run that wire directly to the back of the lighter plug. Use an "in line" fuse on that wire as a safe guard . Use the existing ground that is already connected to the lighter plug to complete the electrical circuit. You will need to figure out where the screws are, that hold trim pieces in place around the radio etc, that need to be removed. It is not hard work. Just be patient and don't pull too hard on anything plastic, or you will break something.
After reading your post, and thinking about the coolant not flowing, I am suspicious that your head gaskets may still be the problem, even though you replaced them last summer. If a bad HG, lets enough hot exhaust gas to enter the cooling system, it will form a hot bubble. The water pump is designed to pump coolant, but can't pump much coolant, when a bubble of exhaust gas is present. A good test is to let the motor cool down, add coolant to the radiator, then start the motor, then look for air bubbles in the filled rad over flow tank, as the motor starts to warms up. If you see bubbles, then it is for certain that your HG has failed. I have both a 98 and 99 OB Wagons. They have both blown head gaskets, so I have seen the HG over heating problem first hand.
After thinking of how to fix this problem, I have come to the conclusion, that it is much easier to just splice into a hot wire, use an in-line fuse on the new wire, then wire that directly to the socket. I will use the existing green colored wire, which is a ground. The heck with trying to trace down relays, thermal fuses, searching for a wiring diagram, and what ever.
It is a two wire connection to the cig lighter. I used a circuit tester light, but could not get the tester to light. I even grounded to a bolt head, but still no light. I connected the two wires to old socket and new socket, and got no power, when I plugged in either the cig lighter or tire air pump, that is when I started looking to see if I had power.
I plugged my GPS into the cig lighter socket, only to have the socket short out and produce smoke. I replaced the burnt socket and blown fuse, and later realized that the plug unit on the GPS cord shorted out causing the problem. With the socket and fuse replaced, my circuit tester light tells me that I am now still not getting power to the socket. Replacing the fuse with another good fuse still did not solve the problem. Any thoughts on what to do next to solve this problem??
I have a similar situation with my 99 OBW. I jacked up the right rear, where the rotating noise was coming from. With the parking brake off, and trans in neutral, I could spin rotate the road wheel. I figured out the noise was coming from the parking brake. I have just ignored the noise, as it is not very noticeable. When rotating the road wheel, you can see if the dust shield is rubbing the rotor. If so, just pry the shield back a bit with a large screw driver to stop the rubbing.
Chiming in...........from what I have heard and read, it is not likely that your coolant will mix with the oil, if the HG is leaking. Using the Subaru additive, which is some sort of a "stop leak" product will stem the HG leak. In my experience with non Subaru cars, when their HG leaks, it becomes very obvious when checking the oil level on the dip stick. The oil starts looking like a frothy chocolate milk shake. You can't miss seeing that mess on a dip stick. If you are not seeing this, then you are safe. Your coolant is not leaking into the oil.
I have a 98 OBW that needs a new rear bumper cover. My wife is a great lady, just don't have her back up your car, or any car. She can't back up without scraping or denting the bumper cover. The cover looks pretty bad after the last scrape against a wall last week. I feel I may score a better looking cover at a wrecking yard to swap on. I couldn't find any description on a "how to" to remove the bumper cover, so I seek advise. Thanks for any help.
Well the squeal could be from a loose belt. I would check that first. I agree with porcupine that Lucas was the wrong product to add to the P/S system. Suggest you drain out all fluid, and put in ATF to get back to what is suppose to be in the system. If it continues to act up, I would replace with a unit from a wrecking yard. It is an easy swap, and cost less then $50. I did the swap years back on my 91 Subie, so I know how easy it is to replace.
I agree with GD, I have never had a problem with the green antifreeze, no matter who the manufacturer is. If there ever was a problem, the class action lawyers would try to make it an issue for a class action law suit against the manufacturers. As far as I know, that has never happened. When I was on Audi and VW forums, I heard the same talk about buying only Audi/VW antifreeze, now on USMB, I am hearing this "buy only" from the dealer advise. All say there is supposed danger in using after market antifreeze. I am not convinced. Makes me wonder if the posters are simply working for the manufacturer, or dealership, and trying to generate some customer traffic and revenue.
I had this happen on an Audi I owned years back. I removed the bulb, then used a hair dryer to blow heat in the hole where the bulb resides. Once I got it good and dry, I used aquarium sealer/glue to seal any surface that looked like it could allow moisture to get inside the headlight unit. Also, check for, and glue any rock chip on the face of the headlight, that may have put a pin hole in the facing, allowing moisture to enter the headlight. Gluing/sealing should fix your problem.
IMO, a slightly narrower tire will not help fuel mileage to any noticeable degree. If it were me, I would run tire pressure at 35 psi. The car will ride a little rougher, however, the higher psi does reduce rolling resistance a little bit. You 14" wheels will prolly not fit your Impreza is my guess. The smaller wheels will not fit over the brake caliper on what is designed for the 16" wheel.
bogging
Rooster2 replied to mojoman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Maybe needs tune up with spark plugs, and maybe spark plug wires. -
In buying a car from a private owner, I carry cash with me, but am very leery about flashing cash for anyone to see. Only when it is settle up time, do I meet someone discretely, (and with confidence that the situation is on the up and up), that I present cash for the transaction. Otherwise, you can be leaving yourself open to get robbed.
