Rooster2
11
Everything posted by Rooster2
Once the buyer had your offer, he undoubtedly used it as a negotiating point with the next interested buyer to get a higher offer. In my opinion, I wouldn't buy anything from this seller. He has little integrity. After you had "closed" your deal, the seller should have been telling every potential buyer that the car was "sold." End of conversation to anyone else wanting to buy his car. He wasn't doing that. His "word" is no good. Even if he comes back to you saying your original deal is still acceptable, I would not buy his car. The guy is not to be trusted, and is likely to jerk you around some more should you continue dealing with him.
Years back, I had a Pontiac wagon with the woody grain vinyl sides. The vinyl began to deteriorate badly with peeling and color fading. I repaired using vinyl shelf sheets, the kind made for kitchen cabinet shelving. I cut the sheets with scissors, pulled off the paper backing, and the adhesive on the back of the vinyl stuck well to the side of the car. It was pretty easy to push out bubbles of air under the vinyl to make a good looking appearance. The kitchen vinyl is rather thin, so it doesn't last more then 3 years, but it was no big deal to add more vinyl right over the previously applied vinyl that was applied years earlier. I remember the vinyl sheets were available in a variety of colors, and wood grains, and the nice thing is that the sheets are inexpensive. I would suggest looking into this approach/
I had a mechanic, who is a buddy of mine, check out the squeaky, creaky, rear end corner. Using a mechanics stethoscope, he was able to figure out the noise is coming from the parking brake inside the rotor. There is no looseness found when pulling the road wheel left/right, or up/down, so the wheel bearing is still good. The parking brake seems to work okay, but something must be rubbing, or lightly grinding, within the parking brake mechanism to create the noise. I will take the rotor off the next nice day, when I have time off to see what is going on. Anyone ever have trouble with the parking brake like this?
I had the same resonator problem on both my 98 and 99 OBWs. I went to a "torch cut out, new pipe bend, weld in," family owned muffler shop. I had them simply weld in a short piece of straight pipe to replace the resonator. Surprisingly, the exhaust system is as quiet, as when the resonator was in place. It cost me about $35-40 to have the straight pipe installed. This work was done about 3 years ago, and the repair has held up great.
I started hearing a squeaky, creaky sound, that is now sounding like a mild grinding sound. My first thought was bad brake pads creating noise from metal on metal. But no, I pulled the road wheel, inspected the pads, regreased the pins, and reinstalled. The noise is still there, when I spin the road wheel, when up in the air. It has a creaky, creaky sound. I now suspect a bad wheel bearing. I did a search on rear wheel bearing replacement. Most of what I read talked about front wheel bearing replacement. So, I came away from the sight confused. From what I could read, the rear bearing needs a puller to remove it from the hub. Did I read and understand that correctly? If I search for a replacement from a wrecking yard, what Subie models and year range would have a rear hub that would fit my 99 Leggie Outback? Thanks for any advise.
Well, it is only my single experience.......I had a 91 Legacy, that I dropped the AT pan on. The pan wasn't leaking, I just wanted to change the filter, because I thought it must need changing, as the car prolly had 150K on the odo. Upon dropping the pan, the filter turned out to be only a fine wire mesh unit. It had almost nothing trapped on the screen, so it didn't need changing. The nasty part was cleaning off the super hardened backed on pan gasket. Even up on ramps, there was minimal space between the pan and the pavement, to be able to work at cleaning off the gasket. From that experience, I deduced that it wasn't worth changing the screen filter, and if anything, I could have easily cleaned off the existing filter and reinstalled. After reassembly, my pan gasket leaked. I prolly did not do a great job cleaning off the old gasket, under less then desirable work conditions. Just snug tight, don't super tight the pan bolts, or you will warp the pan, and that will cause leaks. This is just my single experience, but thought I would post it, as you seem to be looking for testimonials.
Thanks for the advise............... After I wrote this thread, I looked at my old seats to see that one large nut affixes the buckle unit to the seat frame. I will just swap them out. I am still surprised that the buckle units look the same on old vs new seats, but internally something is different to prevent the buckle from working correctly.
I just swapped leather seats from a 97 OBW, into my 99 OBW. I am surprised to find out that the buckle on the leather seats won't latch to the belt tongue. The tongue simply slides in and out of the buckle without latching. This is happening on both seats, with WD-40 failing to fix the situation, in case something was sticking or binding inside the buckle. Only conclusion I can make, is that the buckle must be different internally, though both look the same from the outside. Anyone else ever have this problem? My solution is to swap the buckles onto the new seats from the old seats. It appears to be just one bolt holding the buckle to the seat frame. I hope I don't run into any snags completing the switch over.
Prolly a good place to start, is to remove a door panel, and look for unused wiring with a terminal with nothing plugged into it. I remember that is how my 99 OBW wiring is set up, when I replaced a broken door mirror. This will tell you if your car is wired for heated mirrors or not. Also, I remember that the mirror is held on with screws. They can be extremely difficult to remove, as they are often super tight. It is very easy to round off the screw head, so be careful.
Update....................such a nice day, with lousy weather forcasted for tomorrow, so I decided to install the leather seats today. Swapping in is the easy part, I knew that. The wiring for the heated seats turned out to be impossible. I could not find any tucked away connectors/terminals that were made for the heated seats. Just nothing available under the carpet, or under around the removed console. So, I gave up, but did tap into the hot lead from the cig lighter, ran a wire back and taped it off, just in case someone is able to tell me a clean and simple way to rewire for the seats. Thanks for any further advise. BTW, the leather seats from an Outback Limited, are nice. Not as comfortable as I had hoped for, but a mile better then the standard cloth OEMs. It was worth the time and bucks to do the swap in.
O........what a messy wiring harness is correct. I have a large hunk of it from the donor car. I think I will follow the advise about tapping into the hot lead to the cig lighter for power, and hopefully find existing hidden wiring terminals to hook wiring into. If I get the seats to heat that is fine, if not, I am okay without it. Just going to be so nice to sit in a seat with some spring/give padding. The current OEM cloth seat is bad. This will be my upcoming Saturday project.......weather permitting.
