Rooster2
11
Everything posted by Rooster2
Welcome to USMB. Lots of good folks here to help with your inquiries. I can answer one question, there is no external auto tranny filter. You will find reference to an internal filter that is accessible only if you drop the tranny pan. I don't advise doing this. The filter turns out to be only a fine mesh screen to prevent metal particles from circulating throughout the tranny. Only once did I change the screen, when it did not need to be changed. The problem then arises in having to scrape off the old pan gasket, and installing a new one. You practically need a grinder to remove the old baked on gasket. Next, installing a new gasket without it leaking is really difficult. My best advise, is not to change that internal filter. No one, from what I have read, has ever found that screen filter to be clogged. I would advise changing your tranny's ATF three times with 5 minute drive intervals between changes. There is a drain bolt on the tranny pan for ATF drainage. You need to do it three times, because only about half of the ATF can be drained from the tranny. The rest remains in the torque converter, and cannot be drained. The three changes requires a lot of fluid, but works out well. Changing out ATF may very well help your tranny perform better. You may want to add some Lucas AT additive to help reduce the slippage.
A/c
Rooster2 replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Is the compressor clutch cycling on and off about every 3 to 5 seconds? -
Check to see if the fan belt is tight, and in good shape. Also, check power steering fluid to see if full. It is possible that the p/s unit is going bad. I had that happen on a 91 Subie, when the unit decided to disassemble itself. I bought a replacement unit from a wrecking yard for $35. It swapped in easily, and worked great.
Like you, I have a 98 with an EJ22 motor installed. My "new" motor came from a 95 Subie. I had a shop do the installation last Fall, and the results have been good. I am guessing that your old EJ25 motor had EGR. Some EJ22 motors did not have EGR, and maybe yours does not. If this is the case, then you will constantly have a code displayed for EGR malfunction. On my EJ22, there are a couple of vacuum hoses that are not used. I think they may have been for gas vapor reclamation. My installer screwed bolts into the hoses to seal them off. I hope these thoughts are a help.
Responding to your questions by the numbers: 1. Change the ATF. There is a drain plug on the bottom of the trans to do this. Change and drain 3 times with min of 5 minutes of drive time between changes. Reason for this, is that you can only drain about half of the ATF out of the trans. The remainder stays in the torque converter. The 3 changes helps get all of the old tranny fluid out. I am guessing the trans fluid in the car has never been changed during the life of the car. New fluid in the trans will certainly help the trans to shift better. I would do this first before doing anything else to the trannyh. 2. Normal for car to roll just slightly forward or backward when selector is put into Park, and motor is turned off. All cars with an automatic transmission do this. 3. I have no idea what the mechanic is talking about regarding tracking. I don't think he does either, as reasons to replace the tranny. Sounds like mechanic scare tactic given to a woman to sell a tranny job. I wouldn't go back to that mechanic again. Just my 2 cents worth of advise. Keep us posted on any updates!
I will find out how well an SAE type e-clip works. It seemed a tad loose, and came apart once after the e-clip was installed. However, I may not have had the e-clip fully clamped down in place. I reinstalled, clamped it down hard with needle nose pliers, then added a few drops of glue for a better hold. Time will tell if that e-clip stays in place. I got my fingers crossed!
Epilogue...............just finished swapping in a new climate control unit. The e-clips are a pain in the neck. Recommendations for anyone doing this job in the future. 1. Purchase 3 each e-clips for where the cable housing is friction fastened to the climate control unit plastic housing. The old e-clip will be so bent up upon removable, that it will be unusable. Also, it is just too easy to drop a new e-clip down into the dash unit, where it will be lost forever. I helped prevent dropping the e-clip, by inserting a folded church bulletin in the dash opening, placing it under the cable. If dropped, the e-clip is somewhat easier to retrieve. It helped a lot, God saved me from dropping the e-clip. I had trouble sliding the cable back into the slot opening upon reassembly. After a while, I realized the hard plastic cable covering was bent/distorted, so didn't want to slide into the slot opening. I rounded the hard plastic by flattening the pinching it down with needle nose pliers. Upon reassembly, I also added a few drops of glue around the e-clip to add strength to the e-clip friction hold. 2. I looked hard at disconnecting the cable near the floor, but found little room to work. I did remove the e-clip from there, but gave up that approach, and re-inserted the e-clip. Using needle nose vice grips to hold the e-clip for insertion is the best tool to use. I hope this advise helps someone in the future to make this project just a little bit easier. ...................Regards..........Rooster2
I suggest taking your car to a tire store that sells the brand of tire that is on your Subie. It costs little to have a tire store balance your tires. Tires is all they do for a living, so they are far better at balancing tires correctly. If one of your new tires is bad, and new tires can be defective, they will be able to put on a new tire under manufacturer's warranty. I would avoid a Goodyear or Firestone tire store. Too often, IMO, they are overly money greedy for sales, at the customer's expense.
JB Weld is the first thing I thought of too. However, since it is the car's original, I would be more inclined to buy a replacement radiator. The old radiator is apt to spring a leak somewhere else. Last Fall, I replaced the radiator on my 98 OBW. I bought one from Advance Auto Parts on line. Google "Advance Auto coupons," to get a $30 discount code to apply towards the bill. Their discounts have saved me a lot of money. Product quality is good too.
I got 99% of the way swapping it out, only to be stopped on how to get the e-clip removed that holds the cable tubing from the plastic housing. This is the clip that holds the cable with insulation at the housing. I dug at the e-clip with a very small screw driver, but it refused to pull up and out of the slot in the plastic housing. It started to get dark, and hard to see what I was doing, so I called it quits for the night, and reassembled the old climate control unit back into the dash. Is there something special to do to get the clip out? I stuck a small piece of cardboard under the e-clip to catch it, should I have gotten it out and dropped it. LOL................. LOL on your dropping your e-clip down into the dash. I already dropped one of the screws that mounts the climate control unit into the dash. Just so easy to do. Thanks for any help...............Larry (Rooster2)
I would take the car back to the dealer. Call the Service Manager to get an appointment; tell him what you are experiencing, and that you want a rebalance. Unless the steering pulls consistently to one side, I wouldn't get an allignment. In my experience, a vibration is usually a tire issue on a new car. Also.........just because you have new tires, doesn't mean that a tire cannot be bad. I have bought new tires (as replacements), and noticed a vibration. I took the car back to the tire shop to learn that one of the new tires was manufactured with a defect of being "out of round." I don't know why the guy installing the tire, then balancing the tire, couldn't detect the defect. The tire store replaced the tire at no cost to fix the problem
