Gloyale
86
Everything posted by Gloyale
Power for the injectors should come from the ignitin relay, not from the ECU. The ECU simply controls the ground side of the circuit for firing. Locate the wire for the CEL out of the ECU, and hook it to your CEL in the dash. (or power a lightbulb and hook ground side to CEL wire of ECU) The CEL should then light whenever the ECU is energized, telling you that it is functioning.
I'm not knocking the process at all. In fact, I am a big proponent of these strut swaps. Sorry, didn't mean to put anybody down, or suggest that this swap shouldn't be done. Do it.....you'll love it. But it's a strut upgrade.........not a lift.
1987 GL-10 EA82T Runs Rough & Lacks Power
Gloyale replied to jboymechanic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
With one cam dot up, and one down, the the timing marks should not be visible at all. What should be visible are the 3 belt alignment marks (3 hashmarks with no #s) When the center mark is lined up with the arrow on the bell, the cams should be one up, one down. Sooooo.....let's try it this way..........rotate the engine until "0" TDC mark lined up with the arrow on the bell, and drivers side "dot" down and out at at 45 degree, and the passenger side up and out at a 45 degree. Once you've got it like that, install the disty with the rotor pointing at #1 cylinder. that should get you to basic timing. Adjust with a light from there. -
Yeah, it used to be I on;y had to add the relay and/or pushbutton start to early EA series subarus. But recently, as time has gone by and the first EJ cars are 20 years old now, I've had to install relays on a few. The my theory at this point is the wiring is degrading and has reduced amprage capacity. I used to think it was ignition switches, but I've replaced a few with no change. Same with connectors and terminals. Seems the on;y thing left is the OE wiring getting old. Anyhow....yeah.....add a relay......triggered by a pushbutton if you like.......but either way will solve the problem.
Don't listen to this. The starter is not bad, there just isn't enough amps. It happens alot that there will be voltage when measured on that wire. But in practical application there isn't enough Amp capacity to actually run the starter. See my above post about adding a relay. Add the relay, and you'll never have this starting issue again.
You probably did blow a fuse or have a short. Your lights aren't working. turning on that switch is making the lights work, but you shouldn't need to do that. I'm guessing that one of the headlight relays or fuses is to blame, as the running lights are powered off of one of the headlight relays.
Look, I wasn't trying to step on anyones toes. But there are literally a handful of truely lifted EJ series cars around. Lot's of strut swaps. But on;y a few true lifts. I was merely emphasizing the point that swapping struts is VERY simple and basically an afternoon job. It's changing parts......not lifting. Building and installing a lift is more complicated, I only am trying to emphasize that point. As someone who has actually built several kits now for EA and EJ cars......mostly EJs......I find it hard to hear others talk about how many lifts they've done......when really they are just talking about swapping struts......it's day and night differences.
I had this same problem recently with my 5spd swap. I would suggest using an EA82 Flywheel. The EA81 flywheel is about 8mm thicker. (extra meat on the crank mating area) Moves the friction face and the whole Disc/PP assembly closer to the trans. This leaves very little room for the Throwout bearing between the PP and the trans. Also, the EA81 Pressure plate fingers don't mate well to the EA82 throwout bearing.
I disagree. Swapping struts is swapping struts. If it ends up higher after so be it. But that isn't "lifting" a subaru in my book. A true lift is more than just struts, or even strut spacers. But this is a sidepoint, and not terribly helpful to the poster so I'm gonna end it at that. Outback or Forrester struts would be a great swap for this poster.
Your thinking sounds right to me.
So begins my 87' 4wd wagon EJ22 swap
Gloyale replied to phantomcrooner's topic in Subaru Retrofitting
Yes there is a pressure sensor in the ECU for altitude compensation. But I repeat.....there is never a time when that is supposed to be hooked up to the engine. It is an internal piece of the ECU. Not sure what it will really do to the engine managment when hooked up to the intake. But it definately isn't supposed to need to be that way. -
You mean you swapped struts. A true "lift" is much more involved. Requires adding blocks to the subframe. Just clarifying.
Hows this sound for 84 Wagon?
Gloyale replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've got a full set of Metallic green wagon doors with manual windows. Or I can make you're power windows work. either way PM me and make an offer -
Clean out the contacts on the master switch. Espescially the "lockout" button. All the grounds for every window run through that contact, and when it gets all covered in carbon it stops working.
Need Vacumn Hose diagram for Subaru 1985 GL Wagon
Gloyale replied to erose54's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here's the main vacuum system Ignore the "ditch this" and here's the Air bleed for the carb...I made some notes about bypassing it if the vavle is screwed....but you can ignore that.
