Gloyale
86
Everything posted by Gloyale
Moronic ignition coil question EA81
Gloyale replied to Sapper 157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Test for continuity through the 2 distributor wires. Again, there should be 2 wires on each coil terminal. body harness B/W to + body harness Y to - (tach wire, will actually run without this) Disty harness wire, can't recall colors, but basically they just make a loop from + to - through the disty. So one wire to each side of coil. -
EA82 Oil Pump Issues (Seized Rotor)
Gloyale replied to bingerbangers's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The outside housing of the pump (the part the rotor rides inside) is scarred visibly in your photos. The new rotor will b´riding against that scarred suraface, and will chew itself up again. You can bet the rod and main beaings are shot. Infact if one of them spun and the port in it is now blocked, the rest of the crank could be starving for oil. -
that block is trashed. The scars in the pump housing back side are bad. Expect new pump to fail sooner than later. But you may get some life out of it. Run heavy oil with lots of lucas. -
Where to get a lift today in 2017
Gloyale replied to Shamrockofthesky's topic in Old Gen.: 80's GL/DL/XT/Loyales...
build it yourself. If you ask me, six inches of lift is too much for that brat unless you are swapping engine and drivetrain. With no lo range and the stock 1600, you are better off with maybe 2" lift and only a slight bump in tire size. -
I did for my XT and my old GL. Just grab a set of arms from some newer vehichle, subaru legacy or whatever Cut off the end, weld it onto the old EA arm. Paint and reinstall.
There is no reason you can't pul the timing covers and the belt before pulling the engine. If you set the Cams to unloaded you can roll the crank over all day long with the belts off. Just make sure not to go backwards or you can damage the oil pump. I know a very competent local mechanic who chooses to do the headgaskets for subarus with the engine still in car. He uses a lift and does most work from underneath. Engine unbolted and shifted up off the crossmember. For reassembly, a short bungee cord stretched around the bolt heads will hold them halfway out of the head while they are slipped into place between the block and framerail. He warranties his work but has never had to redo one. JUst comfortable with a different way. Still perfectly acceptable method. Not my preference, I pull the engine. I don't understand why you would need a new longblock? Worst case from what you described is vavle damage from not setting the cams to a proper position.
That is from the water passage between the 2 block halves. If there is now no o-ring up there, you may get water leaking into the oil. There is also an orange o-ring at the back end of the crank, under the flywheel/flexplate. But I can't see how that would get to the oil pan. Sure it's not Orange RTV?
Unless they are aftermarket wires they will not be connected like that. Anyhow, sounds like your radio has a dead channel or a shorted channel. Common on Subaru stereo installs. Here's why. The factory wiring uses a common ground wire for both speakers on a side. So there is no way to properly wire 4 seperate channels like most aftermarkets. So what I do is use factory wire to one set Fronts or Rear doesn't matter which. in this case, I'd run the front 2 channels to the connector behind the radio. You will have 2 wires that would be for the positive signal to doors speakers that will be unused. The door speaker wires go through the rubber boot in the door jamb. Just under the kick panel trim is a junction were the wires will go through a pink 2 pole connector. Best bet for installing a new stereo is to run a new set of wires to these 2 pink connectors. Run these back to the stereo to the rear channel output.
IDK what you mean "pulling" the belt on. Should be no need for that. Belt should not be stretched AT ALL for installation. Simply slip it into place with the lower smooth roller and the tensioner not yet installed. Line up the belt to all 3 marks, and then install the compressed and pinned tensioner. This will be engouh to keep it from slipping yet. Then install the lower smooth roller, making sure to lift up on the belt to get enough room to install the bolt straight and not crossthreaded. Last step pull pin. No need to stretch or pull the belt with wrenches or whatever you are describing.
1978 brat trany wont stay in 4WD
Gloyale replied to 80brat's topic in Historic Subaru Forum: 50's thru 70's
Don't use 4wd on pavement. Only for soft soil. My guess is the trnas mounts are shot, and the movement of the trans relative to the body is causing the 4wd to disengage. Problem for EA71 and EA81 4wd cars. That is why in the EA82 they moved the 4wd shifter to the 5spd stay. So it is not connected/mounted to teh car body. So as trans jumps around, the lever moves with it instead of changin the engagement.
