Everything posted by Mykeys Toy
I have already done this and the only way to not be a nuisance is to purchase and install the projectors also. My headlights are aimed about as far down as I can make them go and they still light up everything above below and to the sides. On the upside most people don't care when they do it so it is aimed right at oncoming traffic and is absolutely horrible. So the folks around here don't bother flashing their lights at you. I would still feel better with a proper beam pattern.. Just my .02
Wedding Bells for 98ImprezaWA
Mykeys Toy replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Congratulations! -
The garage queen gets a new heart ::ea81 build::
Mykeys Toy replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you got back to dropping that motor in yet? I wanna know how it runs... Hurry up darn you! -
Well the sender is showing 12.79 ohms and the gauge hasn't moved from full since June. Going to have to look into a potentiometer.. It has more than a few good uses.. Kind of audio nut also and helps with just the right amount of resistance to one speaker or another for perfect blending.
New here, seems like an older subie forum
Mykeys Toy replied to zf2's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the family! I have many people that i would call friends that i have never met and many others that have bent over backwards to help me and others keep our rides on the road. This board rocks. Mike -
That would be great Abe! I was hoping it would be the sender. After unplugging it and turning the car to run the gauge did not move, still pegged. So I tried jumping the wires at the point of sender, still pegged. From what I have read and what has been posted. The problem is going to be wires or gauge. Still kinda hoping it is the wires. I am much more comfortable with fixing ,patching and splicing wires than cluster removal since the last time I neglected to remove the steering cover and something else that got scratched up when I did so.
I am glad you found it. I am sorry I didn't get to the pics I was going to take for you.
OK well some progress.. THe gauge doesn't move when the sender is disconnected... The snag is I lost the wire in the loom then again when it goes under the dash. I will get there a good schematic would help haynes and chiltons both suck eggs.
82 Brat GL master cylinder.
Mykeys Toy replied to Miatadude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am going to assume this lack of pressure is recent. And that you have bleed the brakes all the way around to make sure. So I got a new master at teh autoparts store for $50 no core and once it was bench bleed ( I waited over a year to do it ) The brakes were awesome. Almost as good as my hatch with rear discs... Touchy but fun on anything that isn't pavement. -
So which is it Stella or Lily? .. Kudos Brian She is a fine rig..looks good dirty to. Oh I hear some Floyd in the background....OOOOH I need a dirty woman.
I will try to get a pic for you this afternoon. Unless it has been replaced It will be right there.. I usually don't even jack the car up because I can reach under with everything I need.
After Rob sent me a cheat sheet for my temp gauge and got that one worked out... I thought it might be applicable to the fuel level also... Sometimes the gauge will read ( I never know if its correct ) Anywhere from 1/4 to full. It reads full more often than not.. It could be the sender. But in order to check I think I need to know what the resistance range is supposed to be or am I thinking backwards?
Has any one swapped a gauge from one cluster to another? I believe my fuel gauge has died a painful death and would like to laid to rest.
Very cool project.
Front-end noise :: brgs or axle ?
Mykeys Toy replied to Dee2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It really depends on the noise. If it is a clicking noise then it is axle new or not sometimes you get a lemon. If it is more grinding squealing or howling it could simply be an axle nut not tight enough... it happens. You could very well be right about the bearings. I hope that helps narrow down the possibilities. -
Throwing in one more tidbit here. For troubleshooting challenged. This might only apply to the blue FPCU. The Big black wire on the FPCU plug is hot only when the key is on not acc. So is the yellow wire though I think that may be the trigger. The two blue wires share a plug Are the supplied power to the pump and not sure what else. The small black wire is fuel pump ground. So to make it all work I added a ground wire put spade terminal on it and plugged it into the ground supplied to the pump and jumped the tellow wire to the two blue ones. Now maybe this is long winded but I did just wake up and thought I would share so maybe someone else doesn't have to do all the testing and double checking that I did. Good luck Mike
I do not have a turbo car so it may be different but all of my gen 2 cars have always had them just in front of the rear passenger side wheel on a triangular plate held up by three 10 mm self tapping bolt/screws.
Ah so now that I have time and show is over went back to trouble shooting.. I have power everywhere including fpcu and @ the pump but something isn't making the connection to send the ground back to the pump. So the question is will it hurt anything to pull the ground output wire from the fpcu and and replace with a good ground?
What Relay To Use For Aftermarket Horns?
Mykeys Toy replied to jj421's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I realize this is a little late but on the Daniel Stern website there is a diagram to wire up a relay for ground switched cars. I did use it for headlights but in theory should work for the horn also. Basically you use the hot for a trigger but the factory ground wire for the horns is now the the relay ground so that leaves the + feed to wire up and the + output ... relay is done. Then ground the horns if not mounted to a grounded metal body part. Good to hear you got it going though. -
What happened were you in that much of a hurry to leave Sunday? We went for coffee and come back to an empty space.
Aand you asked about a late summer BBQ we can come up with something before you leave.. get a few friends together and such. Give it some thought maybe talk to Rob.. I promise Ronnie won't be drinking
They cant all be the best ever for everyone.. Most of my balloon deflation had to do with vehicle issues and not being able to show up on Friday. Aside from all that the BBQ truck was kinda scary so I passed my tickets off to you while others were lining up. On the up side that was one of the coolest mudpit dirty fun tracks to date. I thoroughly enjoyed watching others play in it.. I am hoping to partake at some show in the not to distant future. If I am able I will help wherever I can Just ask. My work schedule is the only thing that may complicate my helping. I have only the most vague idea what it takes to organize the event and think maybe a few different people each year should help with planning. different ideas and or perspectives. IDK just throwing my thoughts out there.
Had a Good time at WCSS
Mykeys Toy replied to 6 Star's topic in Meet n' Greet. Your USMB Welcome Center
It was great to see old friend and make a few new ones for the short time we were there... Now where are the freakin pics? I showed up too late to get any of my own.
