Mykeys Toy
Everything posted by Mykeys Toy
  1. :-\ no buttons. Turbone and I looked it over and played with a few things and got nowhere.
  2. I know they are adjustable but I cannot for the life of me figure it out.. Fricking secret squrrel crap I swear. Does anyone know? Mike
  3. Now we just need SubarDave to show up and everyone else is screwed. LOL
  4. Hey this is supposed to be about pics get bck on topic. Mike
  5. That wont take much for me I paid $450 for my new toy.. Granted it's 2 wheel drive but I kinda like it. Lets see 1 sub and a mediocre amp or just one good sub like an SI or maybe ID Max and I can double the price of the car.
  6. Thats odd I would swear that the 720's were supposed to be oversized 6 1/2s but a tape don't lie. BTW which damping material you gonna use? or are you using mat and spray? Mike
  7. I understand how it works and is supposedly very easy but as mentioned above relays confuse me and then throw in the most stuff in our cars is always hot with a negative trigger that doesn't confuse me its scaawy. mike
  8. Nice pics everyone and Dave I stole a pic of my ride from you. Mike
  9. I might as well be on that list also but alas I must resist the urge until I get a few more things fixed and or replaced on my car.. BTW gen3s have much better mounting locations and have more room in them also.. Try playing with a gen 2.
  10. Mr. Brat gimme a call when you leave your meeting point. Hopefully everything will go according to plan so me and mine can leave on time if not we will try to catch up. Mike
  11. Thats the problem though. He already owns the 720 PRS the extra 1/4" is going to make it tough without cutting unless he uses a spacer. fortunately they are not very deep drivers so depth should be much of an issue.
  12. I'll agree on the chit talking. I have been a member of car audio dot com for a long time and it is getting worse. The original crew kept it a very minimum. for audio stuff where I wish to learn try diyaudio dot com.. They make feel like a new B. Mike
  13. Your prs speakers are oversize 6 1/2s (6 3/4) and are definately not going to fit without spacing them or modding at the very least. Nice speakers and would love to hear them btw. Just out of curiosity which car audio forum do you belong to I have never met anyone that knows who SI is let alone someone into old subes. I thought I was one of very few is gets a little crazy once in a while until eulogious popped here:grin:. Now I have competition so I gotta step up my game. Mike
  14. ^ agreed ^ Go back to the detail work on the 6 and pick up the wiring after the show when you are less stressed.
  15. The plan is friday night between 6 and 7.
  16. If you are familiar with electrical systems then I would use a test light or VOM. I always use new wire and wire my own rather than use old wire that is too small to begin with except for the acc power. Be sure to use new speaker wire because the factory wire if I am not mistaken on your car still uses the common ground. Mike
  17. I was pretty sure it was the same body. I will stop poking fun now since if my brat ever breathes life again I will need body work done on it that is beyond what my capabilities. A second more experienced eye should e able to figure it out fairly easily. I will get to that later though I just want it to run for now. Mike
  18. Mykeys Toy replied to Mugs's topic in Shop Talk
    Try this for CB stuff just make sure you compare prices. http://www.pacetronics.com/
  19. I don't think this mythical RX of yours exist Russ hasn't made it to a show yet Sorry I just had to poke some fun your way.
  20. I bought a new oil pump a few years ago and decided to use it to eliminate or find a problem I am having. So I get it out of the box of new stuff and find that it has no seals/ o-rings on the outside. I figured if it was new it should have come with new seals what gives? Mike
  21. Rob you are a big meany.
  22. I simply ran my own constant wire to the battery and fused it. It is the wire your radio actually gets its power from anyway and If you compare the size of the factory wires to the one on your deck and add in the wiring from your car is very old to me it was a no brainer. BTW it is also a good idea to run your own ground. The ground should be equivelant (sp?) to the sum of your power or source wires for several reasons. Mike
  23. All 2.5s will work though the phase two yields better compression ratio and less likely for piston slap.
  24. Here is a ton of info leading up to what you want there are a few more threads about it and one of them has an exact part number specifically for the frankenstein motor ( hybrid) you do not use EJ25 or EJ22 gaskets. I think Cometic makes them but I ain't sure.. The few threads that I read fastinated me but that kind of project would be getting in way over my head... BTW the Dual port EJ22 heads work better. Dont P and P just throw some cams in there and go like he Double hockey sticks. Mike
