Everything posted by Mykeys Toy
Newer Halogens/HIDs into second gen brat?
Mykeys Toy replied to SubieBrat's topic in Subaru Retrofitting
If you want to run HID you will need to do the headlight relay thing anyway or it will not trigger because we are ground switched not hot switched. Upgrading to 4x6 H4 conversion lenses are not all great. I have tried 5 different types and 3 are junk. Do not get any that have the built in projector. (trust me). Then if you still wanna go that route because it isn't bright enough Kensun off Amazon makes a great H4 kit for the money. IF you want to do it right try this.. but you gotta pay to play and have it done right. http://www.theretrofitsource.com/complete-retrofit-kits.html Just as an aside the 35watt hid lights draw less its the initial start up that is the big draw. The 55 watt versions are more expensive and can almost guarantee you will melt the light housings as well as draw big power. I have already done this just not the right way and around here when it snows HID in hte H4 package are aweful. They will blind you not help Good luck. Mike -
You might hit up Turbone or Caboobaru. I have never seen coilovers on a 6 but if anyone on here knows or has looked into it would be them.
Seafoam it is.. This weekend. If no joy then I will pop off the rocker assembly and check the pushrods and hope that I didn't bend one. Can I use a straight one from another engine if mine turns up bunk?
I have had it for a long while and finally adjusted the valves this weekend. One intake #3 was a little loose and one Exhaust #4 was quite tight. Adjusted and double checked. Put her all back together and still have valve noise from what sounds like number 4. Any ideas or will a short drive maybe work it out? Dunno what else to do short of running seafoam or something. Mike
I finished my valve adjustment.. Took my a little longer since I wanted to clean the covers before reinstall. I double checked each one after adjustment so they should be spot on. I have got to figure out why I have lifter noise on one side.. It's gonna drive me crazy. I had it before valve adjustment and still have it.. I did find one intake a little loose and one exhaust was too tight (same area the noise is coming from). Wonder if it will resolve itself with a little driving? I guess I will ask in the regular forum.
self inflicted steering alignment issue
Mykeys Toy replied to joe5's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Worn bearing? -
Oil pressure light to meter conversion
Mykeys Toy replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
light sender is sideways gauge sender is vertical and much bigger around.. BTW never had any luck with aftermarket sender playing nice with factory gauge. Mike -
Ellevehc's gl build thread
Mykeys Toy replied to ellevehc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That sux. You didn't even have a chance to enjoy it -
http://youtu.be/PvQ9InhEKu0
- 1 reply
- 2
WCSS16 - 8.16.14 - Pt. Townsend, WA
Mykeys Toy replied to Subarutex's topic in Meet n' Greet. Your USMB Welcome Center
So are you going to be a regular now.. I think even your daughter would enjoy it.. even if it is only for 10 seconds at a time. -
Just wondering is your temp going up a bit? I am thinking it could be a plugged cat. You have done everything else I can think of. I dont have a good spare for you to try out or I would have you drop by and grab it to see. I do have a catted Y pipe but I am unsure of how good the welds are so as not gas anyone out. If you want to try it drop me a line. other wise someone may chime in if you post it in the wanted section. If you know a good welder that could have it gutted and still retain stock appearance then there is no possibility of a future plugged cat. -
its old age Eric.. I am right behind you. -
It is a good idea to have some spare flat and cone washers.. BTW they are pretty cheap. I killed a front hub by not knowing. -
Awesome build Kris!
#$%^$%@#$ you finally went and I couldn't go! glad you had fun. I think I need finish a few things and pull many strings before next year.. I will send some pics of my fun today in a bit. -
I realize sourcing a new intake is easier but why not just have the ea81 ported n polished. I will flow at least as well as the gen 3 intakes. Custom is so much better to look at and the sleeper factor is awesome.
I need you all to take lots of pics.. Sadly I won't be making it this year. I have to track down a water leak in my walls. Sooo much more fun than a WCSS event. -
Nice Jackmans! Beware! Swapping parts to a gen 2 are doable. I think the bolt diameter is going to cause problems trying it the other way around on the pivot bolt.. I could be totally wrong but from the explanation above I don't think so. test fit and make sure before modding anything. I would hate to see you stranded because of this.
