themoneypit
Everything posted by themoneypit
wagon to ute/pickup conversion?
themoneypit replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
now that is just freakin sweet!! -
3-door leak into rear compartmnets
themoneypit replied to kayakertom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
GOOD TIP and on my 90 rs 3dr that i had in high school also had leaky rear taillights. i put a bead of silicone along the top of the lights where they meet the body and never another drop... -
:banana: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170499757836&viewitem=&sspagename=STRK%3AMEWAX%3AIT so i pick this baby up tomorrow... 83 year old orig. owner. pretty stoked! ill get some better pics when i get it cleaned up and home tomorrow.. will be needing some peugot wheels and lift kit in the very near future if anyone has some theyre getting rid of.
*83* Dl Wagon heatin up!! need help
themoneypit replied to Howard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
when it sits idling, as it heats up to half way on the guage does the fan come on?? if not im thinking fan temp sensor.. (the sensor in the radiator) also check the fuse for the fan and make sure its not blown. when you added coolant after the thermostat replacement, did you bleed the system good?? rad cap off, heater on high, run until thermostat opens, then top off and put the cap on. worst case scenario, as i had to do to my gl hatch, wire the fan direct so it comes on as soon as you start the car. i changed sensors, fuses etc... fan still wouldnt come on, so i ran a power wire from the solenoid to positive plug on the fan, then grounded it to the ground on the battery. now, as soon as the key is turned on, the fan comes on and im good to go... -
Lifted XT6 with air suspension
themoneypit replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks gary. i appreciate the info. cant wait to get going on my 6 project.. and yeah im keeping the air struts. i hope i can figure a way to leave the rears in there too.. but if i have to put rear coilovers then thats ok too. -
i will be sure to let ya know what, if any, problems i run into while doing the swap. i hear ya i love stick! lucky me i have my 2010 rs/ss camaro with a 6spd and 426h/p to hold me over now that the nice weather is back here in ct :lol:.. ive had a few xt6s that were stick, and theyre so much more fun to drive than automatic. granted in the automatic i get close to 30mpg highway driving.. never even came close to that with the stick. i hope the swap goes smooth, and i dont have to buy a bunch of stuff so i can afford to buy the lift kit for it as well.
given the years of ea81s.. you have to expect rust in the tank.. usually when the filter plugs to the point that its undriveable, it means its getting full or rust. had this happen several times. i would def keep both filters!! IIRC the primary filter (underneath car) filters the gas before it goes into the pump. if you remove this one, rust will go thru the fuel pump and ultimately burn it out, or clog a line somewhere that will be next to impossible to find. instead of the chain stores like auto zone, etc... try a napa, or no name place. the local napa here usually has the primary one in stock. worst case, cap of the vapor port on the one you found and put it as the primary filter. years ago, a buddy of mine had an ea81 with a rusty tank. he would keep a couple primary filters in the glove box and a pair of pliers for the clamps. about once a week he would all of a sudden lose power, but it would idle fine. he would change that filter on the side of the road and itd be good as new until next week
its another xt6. same 88 just 5spd. i may have to score a set of pedals from someone on here thou, these are looking bent and a little messed up...(gas pedal mostly) might be able to change just that over from mine, not sure yet.. ill have to see when i get them out thou. but basically, all the axles are the same automatic, to standard xt6's?? i sure hope so cuz the donor car doesnt have a good axle in it i got it to run this morning and drove it around the yard click clack patty whack damn this thing is ruff!! diff lock didnt want to stay engaged, so i may need those too..
hoping someone can scan the pin out diagram and numbering for me from the factory service manuals. or if there is a link to FSMs that i can look it up myself would be good too.. i tried searching, but ECU pin out in search shows nothing.. you can email it to me at tartags420@aol.com thanks in advance
88 xt6 ft4wd autotragic being swapped to 5spd ft4wd. just picked up the donor car today. so far my list is as follows. if ive missed anything please ring in and let me know. also any advice, or tips for the swap would be greatly appreciated as well trans and crossmember rear diff pedal assembly/cable diff lock solenoids/switch driveshaft guage cluster starter flywheel clutch kit thats off the top of my head, are all the speed sensors the same auto/stick, axles (front and rear) and so on?? any advice of what im up against would be appreciated too... i also hope to order a lift like what grossgary put on his 6. so basically my 6 is going to get a HUGE UPGRADE!! 5spd, and lift with some bigger rims/tires.. i already have a set of 17" wheels i just need tires.
hey gary, did you ever figure a way to make it work with the rear air struts? or are you running coilovers in the rear still? im so tempted to order the same stuff you did and put a lift on mine!! i already have some 17 inch rims that would go on it, would just have to buy some sneakers for them. what size rims/tires are you running on yours?
i dont think thats garys lifted 6, but that thing is damn sweet!! i believe garys is white, and also freakin sweet.. makes me jealous... if you need a rack, i just bought a reman one one ebay for 35 bux shipped to my door.. they are pretty cheap now that theres not a huge demand for them anymore.
no cupholders... what the heck!?!
themoneypit replied to xbeerd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
in my xt6 i put them inbetween the e-brake and passenger seat. holds a dunkin donuts coffee no problem.. pretty sturdy too... in mine, as soon as i can remove the original radio/eq i plan on putting a set of legacy slide out cup holders in there thou. i grabbed a set out of a parts car b4 it went to the crusher. im hoping to do it soon since the weather is finally starting to warm up around here. -
what is this thing and what does it do?
themoneypit replied to Kartier's topic in Old Gen.: 80's GL/DL/XT/Loyales...
some of them have 2 of these, one is an egr solenoid.. are you getting a check engine light with it off? if so check the code and see what it says. i have a brand new one in the box from subaru. he's right theyre like 150 bux. if the one i have is the same as this one, id sell mine for 75 shipped... i no longer have the car i bought it for... the part number i have is subaru 14774AA141 looks the same, just an updated mounting bracket -
All 4 cylinders full of fuel?
themoneypit replied to Mr Whiskey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
IIRC to check the codes on these, the computer is up under the steering column. it will have a flashing light on the front (remove lower plastic panel to see it). when you turn the key on, count the flashes. longer flashes are intervals of 10, and quick flashes are intervals of 1. example 3 long flashes and 2 quick flashes is code 32. -
yeah, i get the egr code in the obw.. doesnt really bother me. the loyale was a 92, or 93 i think... im pretty cool with the people at montambaults i should stop in and ask them if they plug into the computer or not. i went to chase parkway after the swap to see if they could re-program the car to not look for egr. they said no. i dont know if it will pass or not when it comes due for emissions. on another thread here, someone said to ground out plug 81 or 82 (IIRC) on the computer and that should get rid of the code. i havent tried it yet. another thing mentioned in that thread was to splice the egr sensor into the harness before the main plug on the engine and that may rid the code, but again havent tried any of these yet. i just finished my swap a couple months ago. and not due for emissions for another year or so. but hey, if you figure a way to trick the car, even if its a temporary switch for the computer to get it thru emissions, let us know, or me atleast so i can avoid the problem down the road.
