Aspen
Location
Ontario
Vehicles
I Love My Subaru
Aspen's Achievements
Advanced Member (3/11)
10
torque bind - drive around in tight figure eights. If it shudders it may be torque bind. If the car was repair it 'may' be OK. It may also have been damaged prior to the repair. My repair 2.5l developed rod knock 25K miles after the HG repair. I wouldn't bother with one of these, but that is just me.
I USED to have bad shudder at idle in gear. Now it is GONE! Happy, happy, joy, joy. :banana: I did many things to try to fix. Tranny flush, twice, IAC clean, then swap, throttle body clean, new plugs. Nothing worked. Then the shortblock died due to rod bearing failure. So I got a Phase II shortblock and used the motor mounts from my Impreza. All is good now. I can hardly tell when the motor is running now and it idles at about 500rpm. So try the motor mounts. If that doesn't work, try the motor. It doesn't appear to be tranny related. My 2 cents.
It might be better to not do all those tests and instead just find a replacement 2.2l. Driving around with the HG leak is bad mojo for your valves and shortblock. You may end up having more failure shortly. I wouldn't trust that motor on long trips. For the price of those tests and new HG you may be able to find a used motor. If you do wish to check it out, the easy way is to look for black goop in the overflow tank and bubbles after a hard run.
The hard brake line is going to be a pretty big job for a shade tree. It is 'possible' to do without dropping the gas tank, but 100 times easier if you do. To drop the tank you need to drop the diff and undo the tank straps. those straps will likely fall apart from rust. That is why the mechanic declined. He knows it won't go well. That stuff is heavy and much easier done on a lift with tools like tranny jacks. I agree that the rest of the stuff can be done for reasonable amounts. If I were you, I would get the hardline done by a shop and do the rest of the brakes and engine sensor stuff on my own. How is the rest of the car for rust? If the tank is ready to leak and the fenders and suspension are rotten, then maybe you should move on to a different car.
Roof Rails
Aspen replied to AWD Yahoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
you should definitely post your trim for sale or swap with a WRX guy. Many people want to remove their racks and have the smooth look. Look on nasioc.com. You can likely get the rails and trim for free in trade. Since you are a canuck, look on the toronto-subaru-club board as well.
