Aspen
Everything posted by Aspen
torque bind - drive around in tight figure eights. If it shudders it may be torque bind. If the car was repair it 'may' be OK. It may also have been damaged prior to the repair. My repair 2.5l developed rod knock 25K miles after the HG repair. I wouldn't bother with one of these, but that is just me.
I USED to have bad shudder at idle in gear. Now it is GONE! Happy, happy, joy, joy. :banana: I did many things to try to fix. Tranny flush, twice, IAC clean, then swap, throttle body clean, new plugs. Nothing worked. Then the shortblock died due to rod bearing failure. So I got a Phase II shortblock and used the motor mounts from my Impreza. All is good now. I can hardly tell when the motor is running now and it idles at about 500rpm. So try the motor mounts. If that doesn't work, try the motor. It doesn't appear to be tranny related. My 2 cents.
It might be better to not do all those tests and instead just find a replacement 2.2l. Driving around with the HG leak is bad mojo for your valves and shortblock. You may end up having more failure shortly. I wouldn't trust that motor on long trips. For the price of those tests and new HG you may be able to find a used motor. If you do wish to check it out, the easy way is to look for black goop in the overflow tank and bubbles after a hard run.
The hard brake line is going to be a pretty big job for a shade tree. It is 'possible' to do without dropping the gas tank, but 100 times easier if you do. To drop the tank you need to drop the diff and undo the tank straps. those straps will likely fall apart from rust. That is why the mechanic declined. He knows it won't go well. That stuff is heavy and much easier done on a lift with tools like tranny jacks. I agree that the rest of the stuff can be done for reasonable amounts. If I were you, I would get the hardline done by a shop and do the rest of the brakes and engine sensor stuff on my own. How is the rest of the car for rust? If the tank is ready to leak and the fenders and suspension are rotten, then maybe you should move on to a different car.
Roof Rails
Aspen replied to AWD Yahoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
you should definitely post your trim for sale or swap with a WRX guy. Many people want to remove their racks and have the smooth look. Look on nasioc.com. You can likely get the rails and trim for free in trade. Since you are a canuck, look on the toronto-subaru-club board as well. -
This isn't going to help much but I find it odd that I happen to have an 1997 MT cruise unit that I have not been using for 2 years. I promised it to someone else on this board already for cheap, but I won't go back on the deal. Once I dig it out of the garage I will make a copy of the schematic and part numbers. PS It took me about 4 years to find the stupid cruise for a reasonable price in the first place.
I had the dealer swap tranny filters and flush the coolant and replace with OEM stuff. No difference in the vibration in gear. I spoke to the service manager. He suggested it could be the engine mounts. He said to try loosening the mounts and let the engine settle in, then retighted. There may be some tension causing the vibration. If not that then swap the mounts.
I have a used one in my garage from my 97 Impreza L. Removed when I did an engine swap. The off/on dash switch and stalk are still in my car which is away for a few more weeks at the shop. I bought it from Folger. If they don't have one, you could buy mine. It is missing only the nipple to the intake manifold for vacuum. I have the complete instructions too. I might be able to source that nipple for free too, otherwise its likely a $5 part. $35 USD plus shipping.
There are several threads on this problem. Sorry to say, there is no sure thing solution. I think your idle is OK at 600-700 rpm. I doubt it would run at 300. I doubt it is the tranny fluid since yours was done recently. A skipped crank tooth would idle poorly when in neutral as well as in gear. You would be down on power and fuel consumption would be relatively poor. This sure is an annoying problem! Mine is more severe when the car is cold, but it never goes away completely. I am going to swap engine mounts to eliminate this possibility, but I am not hopeful.
Vibration
Aspen replied to mks64's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It feels more like the transmission is applying force to the wheels as opposed to the brakes being difficult to actuate. I did some experimenting to confirm what I was feeling. I suspect there TC is applying torque when it is cold at idle, the vibration could be worse due to this extra load and making whatever it is shake more. As it warms up there is less load and less shaking. -
Vibration
good luck. Mine does it too, as do many others with different generations and different engines. Now I have a new symptom to add. When I first start out in the morning it feels like the car does not want to stop. I have to put the brakes on pretty hard to keep the car from moving when at a stop in gear. This is noticeable and causes lots of shaking. After the transmission has warmed up (ie 15 minutes of driving) it is not nearly as bad. I can ease up on the brakes and the shaking is maybe only 1/2 as bad. It's been around -5C around here, so it takes a while for the fluid to warm up. Current possible solutions are: new engine mounts new torque converter ATF pump Flexplate TCU I am going to flush the tranny again and replace the filters and use Subaru ATF just to rule that out.
