ivantruckman last won the day on May 20 2017
ivantruckman had the most liked content!
About ivantruckman
- Birthday 07/03/1965
Contact Methods
MSN
ivan@carotruck.com
Location
caro, MI.
Interests
offroad , car repair
Occupation
welder /fabricator/ line mechanic
Vehicles
over 10
Recent Profile Visitors
ivantruckman's Achievements
Certified Subaru Nut (8/11)
39
1991 loyle spfi iac wiring
ivantruckman replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its likely the the wire on the engine harness is broken . Ill have to trace it . Thanks all . -
The two wire plug to my idle air control valve ......... the ground wire was showing open . I had 11.6 volts to the positive side . so I just grounded the ground wire to the engine . now it has weird idle issues . does the ground wire go thru the ecm . . it runs better un hooked . just wont idle when cold. and starts hard . arrgggg.
My 1991 loyale will discharge the battery if not run in 3 or 4 days , Alternator is good , Battery is new , and I load tested it , Did a specific gravity test, all cells good . I remember hearing about the ignition switch going bad and doing all sorts of weird things. Any help would be appreciated .
Tap the holes using a 7/18 x 18 tpi tap . no need to drill it out. then buy 7/16 exhaust studs .
Oil pump reseal / no pressure
REPLACED THE SENDING UNIT / GETTING A READING AT THE GUAGE . LET IT RUN FOR 15 MINITS , FINALLY THE LIFTERS QUIETED DOWN . NEVER HAD AN EA82 TAKE THAT LONG TO QUIET DOWN . ALL IS WELL FOR NOW . THANKS EVERYBODY... -
Loyale not being very loyal
ivantruckman replied to devingilberto's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+ 1 on the plugged cat . a T P S wouldn't keep it under 25 . and it would throw a code ? is the CEL on ? -
My next step is to use a test gauge to verify the oil pressure . I was just paranoid and didn't want to do any damage im sure I am over thinking it. it did seem to shoot out a lot of oil from the sending unit hole -
its was just under half on the gauge when cold , the lifters don't pump up , I have only ran it for 30 seconds so far , but usally they stop clattering by then . -
93 loyale fwd inner tie rods.
ivantruckman replied to jaytee5211's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just used 2 adjustable wrenches . I think the flats on the inner rod is 19 mm , -
Alternator not charging battery
ivantruckman replied to gap's topic in Old Gen.: 80's GL/DL/XT/Loyales...
when the dash light glow , is a bad regulator . You will get ac readings on your volt ohm meter .I have had " rebuilt alternators " bad out of the box . some rebuilders just clean and replace only the bad parts . and they don't properly test the regulator . -
Just did a reseal on a ea82 , now I have no oil pressure . there is oil volume . I took out the sending unit and ran it for a couple of seconds . oil everywhere . I have done several of these with no problem . is there a pressure relief check ball that may have fallen out ?
Water Leak Down Test? What and How?
ivantruckman replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
most small head gasket leaks will happen only at full operating temperature as Subaru nut says
