Everything posted by ivantruckman
Turn the fan speed knob for heat/air...Nada.
ivantruckman replied to lastchance's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmmm not sure about a T-wag, only 2 relays , maby some T-wag owners will chime in...bump -
I have a 86 GL, 4x4. having trouble finding struts at the local parts house, my question is , are the strut inserts the same on a 2 wheel drive vrs 4 wheel drive , i have a 2 wheel drive parts car with almost new struts, thanks all in advance
yes, the same engine, the loyale is fuel injected, is the 87 a carb ?
Subaru? What's that?
ivantruckman replied to Mechanical_misfit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have two rear tubes, but there from 2 wheel drives , i wonder if there the same post some pics if you can, ill do some measuring. your tube is shot, not your control arms.. right ?, ill be in cadallac for thanksgiving , could meet you someware along the way ?? , if you need the body shell, i dont know what to do, they come up from time to time on ebay / craigs list -
I live in a rural small community and the local tire shop hasn't even questioned me. I guess there are enough rednecks doing crazier stuff than me
Where to buy 185/80/13 tires?
ivantruckman replied to eulogious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I run those Douglas tires from walmart, 40,000 miles my A@# , more like 15,000, but they work -
new wheels --> tires and lift question
ivantruckman replied to geo.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dude i got that same hammer and grinder from harbor freight. awsome:headbang: -
Anyone have a belt squeel fix/tricks?
ivantruckman replied to SDSOOBI's topic in Old Gen.: 80's GL/DL/XT/Loyales...
usally an overvolt (in a hatachi) starts as the internal regulator is about to fail , it spikes like that, its getting ready to fail.. -
Hahah yes but no :(
ivantruckman replied to Attractor1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
5 K is nuthing, the tac redlines at 6.5 k -
check the ground as well, ill try to get pics as soon as i get my car on the hoist, the fuel pump is under the passenger side rear wheel just ahead of the suspension
most likely the relay above the fuse panel, i don't have a ea81 here to look at, but i think there similar -
92 Loyale having acceration issues
ivantruckman replied to Boneyard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes , Mass Air Flow Sensor , i have had alot off success in cleaning them, also you can clean the throttle body too. -
Need budget lift kit. Any pointers?
ivantruckman replied to Ricearu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I use a simple muffler cut off tool trimmed the fenders and put 15 inch re drilled Chevy truck rims.. 15 dollars a rim , from the junk yard, thats 60 bucks. and 45 dollars a tire from walmart, close out special, if you could find a matched set of four 205-65 15 tires at the junk yard..maby.... but still I have 240 bucks into it. how cheap is cheap ? -
Maby .....If you trim the fenders.... a little bit
is that box blade attached to the subie.... cool
Rough and ready... Between Yuba city and Grass valley ????... Gods country very beautiful, awesome off road country
Righteous
'92 Loyale drive shaft
ivantruckman replied to rickssubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can get drive shafts at the local pick and pull junk yard, the last one I got was 15 bucks, that was over (70 k ) miles ago, do you have any JY s near you ? -
I need a distributer
ivantruckman replied to gl86wagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is it a 2 wheel drive or a 4x4 , ie .. denso or hatachi ??? -
timing belt questions
ivantruckman replied to jesusno2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
rotate the engine one full turn after the first belt is replaced , than install the second belt , basically one cam hole will point up and the other cam hole will point down , when your done... -
Premature ball joint
ivantruckman replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
chinese rubber is crappy, they dont have a good vulcanising tecnology yet,thats why they have so many people there , fauty rubber -
AC refrigerant.
ivantruckman replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if your just topping the system off, you would need a charge hose and can tap for r12 as well, my r12 system uses half a 12 oz can a year, i would rather buy a can of r12 every year, rather than do a whole conversion to r134 if you convert it to another type of refrigerant you have to evacuate the whole system . i would not recharge the whole system with r12, but topping off would be fine -
you may have issues using it on the front wheel. it may rub the brake caliper
Safety Brain Tickler'-Utah
Hood ,fenders , yes, no ,bumper and grill is different and if you use the hood you will have to replumb the windscreen squirters, or you can use all four, MORMONS ROCK !!!! -
Throttlebody Help
ivantruckman replied to Southwestmale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you could try to clean it out, i was able to get a little scale out of mine with carb cleaner. you have to take it out of course, and you can clean out the idle air control valve too ??
