Everything posted by ivantruckman
stumbles spits and sputters when cold
ivantruckman replied to 2Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i took my coolant sensor off and cleaned the scale off of it, it ran much better -
Safety Brain Tickler'-Utah
ivantruckman replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
"It is nice to see some here from Ut. I thought that I was the only one." im a mormon from michigan.. does that count ??? -
lowering the cross member isn't a bad idea, it will allow you to put bigger tires under the wheel well , and you will have the cross member at the same height you started with.... pics of the setup would help a lot if you can
i put in a 1000 watt inverter to run some light power tools, instead of the spare tire i have 24 series deep cycle with a charge isolator, i want to make a jeep style spare tire carrier swing out thingy on the back soon
it wold run like crap if it was off even 1 tooth. is it popping thru the intake ??? if not your probably ok
the brake pistons thread in just like a bolt, you have to turn them in (left) to get them to collapse
EA82 body mount repair?
ivantruckman replied to Rooinater's topic in Old Gen.: 80's GL/DL/XT/Loyales...
83 fuel tank wont flow
ivantruckman replied to WheaT_BeeR_MaN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i had one do that, i tried compressed air to revers the blockage, didnt work however. i ended up replacing the whole tank. -
heater fan relay location ???? help
ivantruckman replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That was definatly the problem. of the four plugs . green ,black, blue , white. the fan relay was the white one. sweet . thanks again all , another one solved -
HAHAHAHHAHA "stand on your head" no kidding. I did find them , will check them out, thanks everybody.. they didn't look like relays at first. kinda look like plugs, weird round things. I was expecting square bosh looking relays -
yes im looking for the interior, cabin air fan relay, my 91 loyale did the same thing, but now its pooped out. -
used engines are cheap..go for it
Oh man my brain is fried....its a 91 loyale, wagon, has ac as well... -
yah 390mm is close to 15 1/2 inch usless ,except for a door stop or a hose hanger
1992 Loyale won't start...
ivantruckman replied to capecove's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you may try to drip a little bit of gas down the intake. if the battery is low it could affect the fuel flow, you shouldn't have done any damage by running it out, is this a 5 speed (clutch ) you can try to push start it ? -
bed liner on a car body?
ivantruckman replied to zukiru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I do it all the time on my pickup trucks and wheel wells. I live 3 miles in, on a gravel road. if I don't have it on ,the stones pummel the body and will rust it out in weeks. I also used it on the floor patch material on my 86 gl wagon, I was tired of filling up with water when crossing the creek on the way to my favorite fishing spot. yummy fat bluegill and crappie -
i agree the door should not be filling up with water.. yikes ..could cause door rot from the inside
front camber question
ivantruckman replied to goldendale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
these strut lift towers are cut at 15 degrees right ? , my homemade 6 Inch strut tower blocks are at 15 degree angles, no camber problems -
ej swap no spark!?!?!?!?!
ivantruckman replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what about a siginal from the crank angle sensor -
the clock problem is usally a solder joint problem, take the back cover off the clock and wiggle the wires looking for a loose solder joint, and resolder it. works most of the time , ive never seen bad camber problems with aa lift kits, can you take pics of the installation. somthing must be wrong ?? -
was looking a a couple of turbo wagons , I have never owned a 1.8 litre turbo. one guy said it was a fast car, how fast can a Twag be , apart from more to go wrong , is a Twag a waste of money ???
"Could you Imagine a Loyale Wagon Full with Nine Girls + Me Driving? " except for the sister thing, it sounds like the beginning of a penthouse forum letter, i would love to have nine girls in my subaru just before i scrapped out my 84 wagon (very rusty) i had my kids in the car and went crazy, sideswiping a tree running into a barrel , dirt mounds etc. just to see the look on there faces , priceless
Just bought a '84 Subaru GL - Pics Inside =)
ivantruckman replied to tbcboo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that is a sexy car, looks just like my first subaru, the one that started my addiction
