Everything posted by ivantruckman
1986 gl 4 inch lift strut problems
ivantruckman replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
front struts are blowing out -
I am going to try the Jezek mod . kia sephia front springs , and new gr2 struts. getting expensive . -
ivantruckman posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a 1986 gl wagon , 4x4, 4 inch lift . 15 inch steel chevy redrilled rims . my struts keep blowing in 4k miles average driving . im using new gr2 gas inserts . my coil springs are stock and kind of weak . can a weak spring cause this .? I know a lot of Guys running a lot heavier tires than I am . This is the second set in less than 1 year 10k miles . -
My spedo went out , I checked the cable its good , I checked the transmission , the cable turns when the wheel spins , I have heard of a speedometer gear stripping ? is the little gear in the gauge housing behind the spedo ? I spun the cable in a cordless drill, and the speedometer doesn't move . am I missing something ?
Under the steering column , you should be able to read the flashing ecu codes
front brake locks up on a 91 loyale
ivantruckman replied to littlemamma's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do Loyales have the hill holder circuit? is this a 5 speed .? if so check the spring to the hill holder valve . -
13 inch tire discussion
ivantruckman replied to Mechanical_misfit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
for my daily driver I use walmart douglas xtra trac 185/70/13 , They were on sale for 39.00 as of 7/3/2015 , but they rip you off 18.00 dollars to install them . I just do cash and carry , Take them to a local small tire shop and for 7:50 each im in business . -
Are these the right gcks?
ivantruckman replied to superooo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The only difference would be automatic or manual , they are different lengths. And the " turbo shafts have a different spline count . but 2wd or 4wd are the same .. -
Loyale wheel bearings
ivantruckman replied to Jman1991's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have heard that you need to grease the bearings ,even if they look pre lubed . the grease they use is not good . it just makes it easy for them to assemble them at the factory . -
This fell out of my gl!
ivantruckman replied to Stihlman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would address the backfire issue first -
Fuel issue~ Fuel pump or something else
ivantruckman replied to Bratmobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
when it broke down did it just shut off. ? check that the disty is turning. if it isn't the timing belt broke -
1986 Brat tranny question
ivantruckman replied to dp213's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the smaller dip stick is for gear oil , the front deferential . 80w-90 will work fine . -
ea82 help horrible noisy lifter
ivantruckman replied to jaytee5211's topic in Old Gen.: 80's GL/DL/XT/Loyales...
dextron 4 will work well , when you resealed the oil pump did you replace the shaft seal as well . ? -
2 WHEEL DRIVE AND 4WD FRONT STRUTS ARE THE SAME PART NUMBER , THERE IS A LEFT AND A RIGHT KYB RIGHT 233022 / KYB LEFT 22023
Stub quit engaging after axel replacement
ivantruckman replied to Webster's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the roll pin is just a retainer , it wont take any torque at all before it shears -
ALL EA 82 THRU 1994 LOYALES WILL WORK . 2 WD OR 4WD THEY ARE THE SAME FRONT SPINDLE , I HAVE SUCCESSFULLY USED METAL OR BRASS SHIM STOCK TO REPAIR THE BALL JOINT SOCKETT . AS LONG AS THEY DONT MOVE IN THE BORE YOU SHOULD BE GOOD .
Idle has degraded to zero.
ivantruckman replied to ErikAnderson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
emulsion tubes are dirty -
noise from passenger wheel well?
ivantruckman replied to Rocketdog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
did you check your dust shield backing plate ? -
New Suspension for 93 Loyale 4wd
ivantruckman replied to MTSuby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I removed my struts and brought them to my local spring shop and they disassembled them for me, the rear are called shocks but they are actually struts . the dia is so small I just had them do it . it cost 30 dollars to have done . then I reinstalled them myself. I would use only kyb gr2 (gas strut) front and rear , any other brand is junk and you will have to re do them in a year or less. I found out the hard way with Gabriel , they suck bad . -
I have a 1991 loyale spfi . when I accelerate the vents go to center . and my acceleration is sluggish . I used a vacuum tester and found no leaks in the duct system lines , I tested the egr , and even the manifold lines . im wondering if the leak is only under load , perhaps its the manifold gaskets , but I get no change in rpm with carb cleaner . I cant seem to find it
Did you do a 2 inch lift by using blocks on the strut only? the axle will wear out quickly , you should block the cross member at least 1 inch as well.
im thinking a different problem now.... driving it to work today , I was using the defrost. when I accelerated the ducts went from defrost to vent . I was only at 1/4 on the throttle. and it was instantly . ill have to get the propane out and see if I can find it. im sure its intake gaskets.
How much for the wheels off an 86 DL wagon?
ivantruckman replied to JAmacT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
are they wagon wheels , and do you have the center caps ?
