ivantruckman
Everything posted by ivantruckman
  1. Ive beat the crap out of my hand drilled rims, no problem. but CNC equipment is way cool
  2. Check the fusable links , check all grounds. when all the indicator lights come on its usally a failure of the alternator, or its path to the battery, ie the fusable links [ATTACH]6224[/ATTACH]
  3. hahahaha ya, if i buff long enough will it change every thing back to blue i got a brown fender green hood and a loyale bumper on an blue 88 gl. but i look sexy driving it
  4. [ATTACH][ATTACH] [/ATTACH][/ATTACH] need paint and a grill. yeehaa
  5. I had a throw out bearing spring rub on my pressure plate once. made a tiny squeek it was a ea81 ,1984 wagon 2wd., what year soob do you have. I would also think it could be the dust shield on the drive shaft, they do bend easy
  6. What about rust holes in the solid metal pipe, o rings ?
  7. MAY 07, 1990 | Recall ID# 59034 Recall Reason SUSPENSION:REAR Recall Date MAY 07, 1990 Model Affected DL Potential Units Affected 285000 Recall Summary CONTINUOUS EXPOSURE TO ROAD SALT COULD CAUSE CORROSION OF REAR SUSPENSION COMPONENTS, ESPECIALLY THE INNER ARMS. Consequence THE CORROSION COULD AFFECT THE OPERATION AND CONTROL OF THE VEHICLE. Remedy RUST PROOF OR REPLACE REAR SUSPENSION, AS NECESSARY. Notes SUBARU OF AMERICA, INC.
  8. Welcom to the rust belt , this rear control arm came off a 1986 gl 4x4 wagon, i did hear that subaru had a recall for this very item, i dont think this owner went back for it
  9. Do ea81 engines have different Vacuum characteristics, i know they have longer intake manifolds, hmmmm. thinking..... a carb should be a carb, airflow across a venturi , sucks fuel out of a jet
  10. AHHHH the old tow dolly pulling in the driveway, wife screaming "now what did you buy" "another one" "how many do you need " its a magical moment.
  11. Maby Ill take the two sedans and make a stretch limo ,hmm. kinda feel guilty murdering two subarus. maby Ill keep old green and convert it to a 4x4, than lift it. i think lifted 4 door sedans are sexy ??? ladys. what do you think
  12. Are you still in high school, do they have a vocational tec center, they may be able to help with welding and fab stuff, like bumpers , or maby the body shop can cut /trim fenders and stuff. just a thaught
  13. are the jackman wheels stock or aftermarket, i have spoke wheels on an 86 wagon and i cant find a j on any of them
  14. i used a 9/16 (.5625) 35/64 is (.5469) try to go up one incramental size till it fits http://www.carbidedepot.com/formulas-drillsize.htm did you use a counter sink to match the bevel of the lug nut. i think its a 60 degree. you may want to ask scott in bellingham, he knows the size,
  15. the plastic bulb holder , for my front marker light just crumbled, trying to change out the bulb on my 88 wagon, oh crap.. i was thinking of making a mold , and cast a replica from a castiable urethene, does anyone have an easyer fix. I tried several parts cars and all were toast. i just gobbed some silicone in there for now , but i will have to change the bulb somtime. arrggg [ATTACH]6212[/ATTACH]
  16. Nice, I like it. im gettin out the chainsaw zzzzzz my car wont look that good however
  17. i know a crappy photoshop job , has anyone done this, i have a 93 subaru 4 door sedan, and a sazwall, and i want to get "big " with it. all i need to do is make some sort of top.
  18. "Forecast was for scattered clouds temps near 25*. But it's cloudy, snowing, 19* with windchill of 9* blowing right into the garage. Can't get BRAT in far enough to close the door, got an ER-27 W/tranny sitting in the way. Sure do wish Jerry wasn't using his lift this weekend....... " I feel your pain brother, i got ice and frozen mudd all over the undercarriage
  19. ABS sucks, i pulled thge fuse out of my 96 legacy. i can stop way faster with out Abs, last time i did some dash light bulbs i took out the abs indicator light on the dash, what a waste of money. unless you dont know how to drive in the snow or ice , (most of uss do) there useless
  20. sweet. i just picked up a 2 wd 93 loyale 4 door sedan looks just like it but green
