Everything posted by ivantruckman
I saw the light!!
ivantruckman replied to SuperchargedRS's topic in Old Gen.: 80's GL/DL/XT/Loyales...
all of my loyales dont have foam inside the bumper, they only have a light ( 16 guage) backing frame , covered with a plastic shell. i think the lights would vibrate a lot, unless you mounted them with a heavier steel backing plate -
what do you think its worth
ivantruckman replied to bigo1966's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you will have to spend alot of cash , "oil leaks" sounds like a full t belt and cam seal,gasket job to me . but .... i could never find a hatch out east, id get it in a second out here -
Loyale will not start: no fuel to engine
ivantruckman replied to Bizangous's topic in Old Gen.: 80's GL/DL/XT/Loyales...
can you hear the fuel pump whurring , its underneth the right rear passengers side , try tapping the pump with a hamer handle, my lil loyale does that all the time -
Replacing Gas Tank: Need Input
ivantruckman replied to brianbarber's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the moustache bar holds the back of the diff, if removed you can pivot the diff a little bit . no need to drop the whole rear suspention. the bar is shaped like a handlebar moustache -
Baja Bug type modification for the Subaru
ivantruckman replied to Scott in Bellingham's topic in Off Road
http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=front.jpg 6 inch lift. and alot of sheet metal work -
its one of thoes sambar mini trucks... sweeeet
Tire help size vs weight and gearing?
ivantruckman replied to lilpusher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
im running 205 65 15s on my wagon, i take it you dont have a hi/lo manual trans, i usally run in low all the time im off pavment , basically 45 mph is like running 60 mph , i can climb hills no problem, but i dont have mountains here -
is this a push button auto trans ?? you may have different size tires on it, or different types of tires. or even some worn tires mixed with new tires . if you can try to take the car to some loose sand or dirt and then try to take it out of 4x4
it has two front driveshafts, i think its much better than one shaft, their idiots
updated pics http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=2subies.jpg http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view¤t=front.jpg how do you get these stupid pics to show up instead of posting a a link arrggggg
so is the lower raidiator support strong enough to support a skid plate ???
i suppose uphill you could have blowby causing a drop in compression
im looking for ideas for homade skid plates, im interested in the mounting fabrication, i dont have moutains or big rocks here in michigan, i need the real life proven ( big dented skid plates) off road proven ideas, thanks to all in advance for the pics.........Ivan
When do you change your belts?
ivantruckman replied to MTSuby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you definatly dont want your water pump to quit running, could cause alot of trouble if your not paying attention to the guages -
Timing Belt without discharging AC???
ivantruckman replied to GBANGER's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i would still replace the belts, while your in there, there not that expensive, you could also think about replacing all the idlers too http://cgi.ebay.com/ebaymotors/85-94-SUBARU-LOYALE-1800-GL-RX-XT-TIMING-BELT-KIT-EA82_W0QQcmdZViewItemQQcategoryZ33625QQihZ010QQitemZ200211405935QQrdZ1QQsspagenameZWDVW you cant beat this deal. the Consensis is their of good quality. i have two kits running now in bolth my daily drivers, no problems yet -
Rear Shocks for '86 4WD GL wagon
ivantruckman replied to subaru86's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sweet . good info as i have to do the same, thanks for the measurements and the leg work -
i put 195 70 15 tires on without a lift kit
woooooooohhhhhhh :-\ had to think about that one
Puh-leese, Hep a bruthuh out !!!
ivantruckman replied to HiPlainsShifter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
omg thats not supposed to happen. their is a difference between a 2wd and a 4wd .. either a nippondenso or a hatachi disty, my supplier gets it wrong all the time, frustrating
