Everything posted by ivantruckman
My New Project - '87 Subaru GL Wagon
ivantruckman replied to SubaruGL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
does water freeze in browerd county..do you see any of those sexy ."police woman of browerd county" sheriff deputy's ??? you may want to fill the radiator and leave the cap off. than look for bubbles -
Timing Belt Brands
ivantruckman replied to tractor pole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i had one ebay belt kit . from the importexperts .. brake on me in 3000 miles. however out of 5 kits purchased from them , its not to bad of a deal. -
Water leaking out of dash after heavy rain.
ivantruckman replied to 987687's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check for leaves or other junk in the drain holes. near the corner of the fenders.. had the same problem, it could also be windshield gaskets -
91 loyale won't go into overdrive
ivantruckman replied to subielynn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i was gonna say 3000 rpm at 45 seems normal for my 3 speed 4wd auto, yes count the gears.. you may not have a problem at all.. except that its an automatic -
I have a 91 loyale 3 speed auto, 2 wheel drive , I'm getting ready to convert it to 5 speed manual, I just read the conversion write up , but it is for an earlier ea81. is there any major differences between the two. i have a fully functioning 92 loyale 5 speed 2wd donor car (rear end total). any help would be much appreciated
fuel smell inside the cabin
ivantruckman replied to dwuollet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it there any rust. some fuel lines run under the back seat, or along the rockers , well here in the rust belt any way , i just started sniffing around, i didnt sniff the seats however -
EA Steering shaft ideas for lifted rigs
ivantruckman replied to Crazyeights's topic in Subaru Retrofitting
nice clean look. my gehetto extention looks crappy. -
Whats broke on your subaru lately.
ivantruckman replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
massive oil leak, coming from the right side, some little gasked, have to pull the engine and get big whit it.new head gaskets , and all the belts and seals. arrgg stupid ea82 "boat anchor" GD quote -
87 GL fwd EA82 wagon brake question
ivantruckman replied to OREchipmunk78's topic in Old Gen.: 80's GL/DL/XT/Loyales...
HMMM, could be a number of things, it kinda one of those id have to look things. if your fluid is low, you would have a mushy pedal, if you pump the pedal does it get firmer? -
you gotta lift it, but go with 27,s, perfect fit
someone here has a diagram with wire colors and everything. did you try the search ?
Typical Turn Signals
ivantruckman replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you could change out the flasher relay with a eletronic one. i did this when i used custome led lights on my homade front bumper -
need awd auto trans please
ivantruckman replied to swampbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there getting hard to find nowdays, i got my one on ebay, didnt see anything there now -
1990 Loyale idle problem
ivantruckman replied to 2Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Awsome -
HELP! died on the side of the road
ivantruckman replied to Ricearu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is this a carby or EFI ? have had very similar problem with EFI, it was a wanked out T.P. sensor, would get a good signal when cold, when hot it would hunt for a signal. -
Subie: My 92 Loyale
ivantruckman replied to SubaruJawn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you got to get rid of that 3eat there slooooowwwww , but the car is still awsome ,
