Everything posted by ivantruckman
1990 Loyale idle problem
ivantruckman replied to 2Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
your probably on the right track. is the idle fluctuating or steady ? -
86 EA82 wagon 3spd auto: 4wd won't engage
ivantruckman replied to beat_truck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check for vacuum leaks in the accuator lines, the acuator could be bad too. if everything checks out, you can jack the car up on all 4 wheels and try to engage the 4x4, if the rear spins whithout a load the rear clutch pack could be bad. is the trans fluid dark ?. -
yikes, not orange lettering, maby a different font .you have to project a good image
i have a small scale for filling paintball tanks. hmm that should work
i did see a plug under the reciever drier. but it has 4 wires on it. ill see if the fsm online has a wiring diagram
mystery ring inside transmission!?!?!?
ivantruckman replied to Subafly's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks like the pilot bearing outer race -
i have a 85 gl wagon ...i fixed a leaky hose, evacuated the system, and went to recharge the system, and compressor clutch would not cycle , is there a low pressure switch in this system ? if so how do i jump it out. were in the low 90 degrees and muggy. of course they never fail when its cool outside , any help would be appreciated.
That Womans a Keeper
is this a 4x4 auto or was it i should say, or a 2 wheel drive i could look over my cars, i have bolth cars here
nice...it will help the pads not to wear as fast
you could post an add in the "subaru parts wanted" section on the usmb site. im sure somone has it, they hardly ever fail, on ocasion they dry out, but you can grease them with a needle adapter. a good used one would last years
hmmm, same here. 1986 ea82 wagon , no bashing
Good, Cheap CB sugestions?
ivantruckman replied to GeneralDisorder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
our 4x4 club uses channel 33 on the course, cbs are an awsome way of comunicating for us you can get updated info on the bog pits ,etc here in michigan we have offroad parks , the one outside of flint is about 60 acres -
ive had 6 die this way on me, 3 this year... its a subaru thing
How do I replace the CEL on my 1992 Loyale
ivantruckman replied to csressler's topic in Old Gen.: 80's GL/DL/XT/Loyales...
your lucky, im waiting for my light to burn out -
loyale tranny swap question
ivantruckman replied to mdjdc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
She's really into sweat equity and I appreciate her work ethic. Thanks Guys. thats rare these days. you must have a gem there..shes a keeper -
Bolt on 90 amp alternator
ivantruckman replied to Splinter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
delco alternators rock. you can rebuild them cheap, all internal parts bolt together, no soldering . there durable as hell. most people that have the skills to rebuild them also have the skills to modify the case to fit there cars. thats a very cool case however. i cant seem to find a 80s nissan here in the detroit area. but i can get tons of 10 si units for cheap http://cgi.ebay.com/ebaymotors/Delco-Remy-10-SI-Alternator-Rebuild-Kit-70-Amp_W0QQcmdZViewItemQQhashZitem518bbed497QQitemZ350236890263QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories -
check with your independent muffler shops, my local shop sells parts as well
What Ive been working on lately...
ivantruckman replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Awsome vintage towmotor fork lift -
Restored Green Gen 2 BRAT
ivantruckman replied to Pooparu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
needs a 6 inch lift, could rock crawl with the gull wing doors open ? -
timing belt replacement
ivantruckman replied to tractor pole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
