Everything posted by archemitis
The Maiden Voyage: SS Subaru
archemitis replied to nicky nighteyes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so... you were driving in the ocean... lets talk about that =] do you always do that? or were you just testing it out? seems scary to even get close to the ocean in a car. but im in minnesota -
i heard that a hatch will float, but judging how that front end is pullin the rest of th car down, it would have to have 33s to float. looks like fun! -
2.0 is a turbo motor! 1.8 or 2.2 for na! duh!
loyale won't crank
archemitis replied to Mike Browning's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes, sometimes you get lucky and your cables need to be cleaned or tightened. my starter has 197k miles on it as far as i can tell, and my car has good documentation. -
Tips on passing SMOG? (78 wagon, with issues)
archemitis replied to Kostamojen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well, some ghetto tricks. get it hot before the test. unplug the fan, and get it close to the red(not too close). also theres some stuff you can put in the tank that guarantees a pass thicker oil wouldnt burn past the rings as easy as thinner oil, so that helps too. theres more, just cant think at the moment. -
More torque from my ea81T
archemitis replied to EA82Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
something tells me the only way to get the low back, is to get a high compression na ea81, or ea82. but whats the fun in that? bump the compression would get you more low end, but you could never run that much boost. -
What could I get for Selling My Soob?
archemitis replied to Skipper47's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i've never payed over 400 for a subar, but i see em in the paper for like 1700 all day long, aim high, and hope you find a sucker =] -
Why you should never cross a stream with AC on.
archemitis replied to jelly man's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that alt trick is cool, never thought about it. spfi and mpfi dont need to see anything from the alternator to work, so all of our cars could have an alt kill switch. better yet, a hydrolic tensioner pulley that you could loosen to turn off water pump too =] -
has anyone had the Guts to try this?
archemitis replied to Geck512's topic in Old Gen.: 80's GL/DL/XT/Loyales...
um no -
for expensive little things like this the USMB is the best online parts source. place an ad in the calssifieds, and im sure somebody will send you 3 for 20 bucks.
How to get 220-230hp from 1.8turbo?
archemitis replied to Tee Koo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
jon of scio i know how to make the perfect engine! but i cant tell you! =P -
i am pretty sure all you need is the lecacy turbo, and stick the ea82 exhaust housing on the bottom.
subarus are dogs, thats why they came with dual range trannies and the gearing to just barely go 80. remember this? http://www.ultimatesubaru.org/forum/showthread.php?t=10369&highlight=rx+dyno thats the highest dyno sheets i have ever seen from one =] sorry -
xt6 seats in ea81 car
archemitis replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i thought i liked the older seats, but then i got into these. the rx seats are still kinda hokey, but these feel like race seats, compared to others. most of the height adjust is in the construction of the seats, steel hinges and pivots, it would be alot of trouble i think. -
EA82 seats in a brat??
archemitis replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ultimatesubaru.org/forum/showthread.php?t=12335&highlight=hatch+xt6+seats i still love them, should be about the same as your seats. everybody thinks im extra short till i get out of the car. -
So far, the stories are false
archemitis replied to ezapar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
have faith. i live in minneapolis mn. pleanty of tax dollars for lotsa salt on the roads, within a 100 mile radius. i managed to find one cherry(cherry for me) 86 hatch from WA, and one very nice red wagon, from virginia. got em both for about 300 a piece(with blown motors). it did take two years of driving a rusty one before found these two, but both were by chance, by word of mouth. so what im saying is, be patient, and you can get a good subaru anywhere, just let some poor sucker drive it to you! -
90 loyale, most likely a spfi motor right? sometimes the idle air controll valve will do this to you, sometimes it makes it idle too high. you can try some carb cleaner down the throttle body, and the iac hose, comin right off the tb. i heard you can adjust idle too, but not sure.
who can spare an 85-86 ea82t dizzy/ignition module?
archemitis replied to nutt7's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you can use one off of any ea82 carb model. same stuff... er at least, works the same. -
well everybody needs to remember.. peak hp is gay, when you make about 20 hp till you hit 6 grand+
these are subarus, you cant take a 65 hp motor and get 200 out of it natuarally aspirated, with stock heads, even heavily modified stock heads. sorry
