Ginger48
Location
With The Mountain Goats
Ginger48's Achievements
Advanced Member (3/11)
10
Do a Google search on Marvel Mystery Oil and MSDS. It's just lubricating oil and mineral spirits (paint thinner)
Oil filters-would bigger be better?
Ginger48 replied to Kwhistle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's very simple. The less filtering media there is (and Subaru oem oil filters ARE small) and the more contaminants there are in the filter WHEN the oil is cold and thick, the oil IS going to find the least restrictive place to flow through.....and that's the bypass valve. Why do you think oil filter manufacturers install bypass valves in their filters? If they didn't, you'd blow a hole in the filter media. When the bypass valve opens, guess where all the contaminants that were previously trapped in the filter goes? The oil filter manufacturers aren't going to install something that isn't necessary and doesn't ever get used. Conversely, the larger the filter (more filter media) the less restrictive it is and less likely the bypass valve will need to open when the oil is cold and thick. If you use synthetic oil, or you change your oil and filter every 3,000 miles this is most likely a moot point. EDIT: Oil filter bypass valves are NOT designed to open at a specific oil pressure. They are designed to open at a specific pressure differential. The more contaminants there are in the filter and or the colder the oil is, the greater the pressure differential. -
That is true. In one of the papers SAE makes available to the public, they show how air and oil filters actually filter better after they get a layer of contamination on them. Clean isn't necessarily better. -
Sorry, but you did miss one important benefit of using a larger filter. When starting a cold engine, the bypass valve can open thus allowing dirt previously caught in the filter to circulate through the engine. The thicker the oil, the colder it is, and the smaller the filter, the greater the chances this will happen. In cold climates it's best to use the largest filter available. -
If you want the ultimate in oil filters install a Frantz bypass oil filter. It will keep your oil analytically clean 100% of the time. Some will bad mouth the Frantz but modern oil analysis tests have proven the Frantz does work as advertised. Any full flow filter, regardless of manufacturer, is nothing more than a screen that removes the large particles. A bypass filter on the other hand removes much smaller particles. Large over the road diesels that run for over 1 million miles use both full flow and bypass oil filters. -
TBS-(exist for subarus?)
Ginger48 replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you want the ultimate fuel atomization, install a propane or natural gas fuel system. You'll experience MUCH less power. -
What kind of gas milage do you get?
Ginger48 replied to akc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
86 GL wagon with 315,000 miles: 22 to 24 mpg mountain driving (8,000 to 12,000 ft elevation) 38 to 40 mpg flat land keeping speed UNDER 60mph 48.8 mpg flat land, 55mph w/strong tail wind! Seldom drive in cities so no idea what mileage would be there. -
Will my Ea-82T run without the turbo?
Ginger48 replied to hoverman37's topic in Old Gen.: 80's GL/DL/XT/Loyales...
9 years ago a friend of mine took me for a ride in his Subaru powered gyrocopter. It was powered by an EJ engine with a distributor and holly carburetor. The pilot and craft are now somewhere on the bottom of Lake Michigan. Subaru's are safer on the ground. -
Google Frantz filter for new units or check eBay for NOS or used.
If you want the ultimate oil filter, install a Frantz oil filter. I've been using them for over 40 years. Our military even uses similar depth type filters to save on oil changes. Oil analysis proves they work.
Show off your roos Mileage!
Ginger48 replied to beataru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1986GL 311,000 miles on the clock and still counting. Still original engine that's never been opened up. Uses one quart of oil/1800 miles. I don't change the oil....just the Frantz oil filter cartridge. Body still good. Purchased when it was 3 years old. 1986GL 163,000 miles. Unknown past. -
Thank the greenies for introducing moose into Colorado. It's my understanding they were never there before.
For the last 21 years I've always used aftermarket 160 or 180 degree thermostats in all my EA82's and NEVER had any cooling issues. Using 195 degree thermostats will slightly increase fuel mileage but they also put increased strain on the cooling system due to the increased pressure the extra heat creates. Since I also own Chevrolets and the thermostats are interchangeable with Subaru, I usually use Chevrolet thermostats. If a Chevrolet thermostat will flow enough to cool a 454 cubic inch engine, I'll flow enough to cool a little 1800 cc (110 cubic inches) engine. Remove your thermostat, place it in a pan of boiling water on the stove. If it fully opens, it's not the thermostat.
