Contact Methods
AIM
amaranesiac
Website URL
http://bosox-blueshoes.blogspot.com
Location
Keene
Interests
cemeteries, photography, music
Occupation
IT/Administration
Biography
I'm a half-hearted car nut.
Vehicles
2003 Subaru Legacy L
subihoot03's Achievements
Advanced Member (3/11)
10
did you figer out what the clunking noise is /was .I am haveing alot of clunking noise from my front end when hiting bumps i have rebuilt the front end and it still does it
Thanks all, I guess i just needed a push in the right direction. I'll swap out that door speaker when the temp climbs above 40.. Wait, that might not be til April... subaru360, I felt it was very fair. Especially since I've been reading about mechanics on the left coast charging $2000+ for the same job...UGH...I lucked out.
So I finally took the plunge and dropped $1500 for needed repairs into the 2003 legacy. This is my daily driver and I occasionally have to commute with it, so there is no other decision in my eyes. Head gaskets were going and then some. The laundry list: All gaskets and seals Timing belt, tensioner, water pump Plugs and wires Thermostat Exhaust flange And all the other necessaries for the head gasket job. Sure, $1500 is a lot but my wallet doesn't feel lighter because now it's a brand new car...virtuallly... At any rate. Now that all of the work has been done, I'm noticing that the speaker in the passenger side door is GONE. Is it going to be painful to replace? Could I, someone capable of changing oil and brake pads, feasibly do it myself? I've done it on a 1996 cavalier if that makes any difference.... :-)
I know, I have a way of blowing things out of proportion. I have honestly never had a car that has thrown off CELs at random...only when there was a major problem. Except for that Camry that started glowing orange when it was time to die, but that was a different story entirely. So truthfully, when I saw the CEL...yeah...I feared for the worst, but mostly because of everything else that was going on. I was really worried that a black cloud was starting to follow me around, even though most of my smaller subi issues could have been taken care of with preventative maintenance. I am at times the poster child of ignorance.
I generally do my oil changes when the NH weather permits me to be comfortable. Somehow my girliness gets in the way otherwise. So it's entirely feasible that if I know exactly what to do I could drain the tranny too myself, and then refill. All I know is after the "service" that I just had done the shifting is oh-so-smooth and nice again. As far as the CEL goes, it was a cyl 1 misfire...as I suspected. This is an issue that we will take care of with the HG which will be done...in the next month or so. The leaks have gotten exponentially worse, even since three weeks ago. Thanks for the insight...again...all of this fuss is usually just me panicking...
I mean, yeah, plug wires and some other small stuff...it is due for tranny service NOW which is what is happening. But I don't know...I just have this sinking feeling that there is going to be one more bad thing wrong with it. When I get the HGs done etc it will also include the other stuff that should probably happen at that time: spark plugs, wires, etc. No timing belt necessary -that service was actually performed at the right time and correctly... No code reader here tonight, which is why I am sitting, paniicking. Hoping for the best when the tranny service gets done in the morning, if it starts in the morning.
Take it or leave it. I'm guilty of thinking brake pads and oil changes are the only necessary parts of the maintenance schedule to follow. So here's the deal. My 2003 Legacy (AT), of which I have spoken many times before, is going for major surgery soon...head gaskets, seals and all of that great overhauled engine stuff. 130K and it's about time as the head gasket's leaking oil and coolant and it's getting to the point where I can smell both...strongly. But it's not running hot at all...remarkably. Car is also due for a tranny flush/service tomorrow. Tech told me that the lines were beginning to corrode and that it was starting to leak fluid a little (two weeks ago) and I scheduled an appointment to bring it in and have it taken care of. Maybe I am just freaking out because it's what I do best, but tonight (in 14 degree weather) I was driving about 50 up a fairly steep grade and I heard and felt a bit of a misfire. The car kind of shuddered, but then recovered. I parked it at my destination for about two hours, and then started it with the remote. I let it run for probably 5 minutes and then went outside. I could hear it running loudly and unevenly, and when I climbed in the AT OIL TEMP and CHECK ENGINE lights were both flashing vividly. So I did the reasonable thing and cut the engine, waited a few seconds, and started the car back up. It started fine... The CHECK ENGINE light stayed on solidly but the AT OIL TEMP had mysteriously disappeared (thank G-D, I find that one more daunting anyway). It drove normally the 1 mile home and now it is parked. Unfortunately, this being New Hampshire and it being close to 10 pm, there is no AutoZone open where I can check the codes on the engine. :-( I guess I will just cross my fingers and say a little prayer, but what are the chances that this has something to do with one of the aforementioned conditions (leaking head gasket/leaking tranny lines)? Is it more likely that I just have bad luck and now there is something dire going on, more dire than what I am already facing? This really makes me wish I I'd bought that 2.2L Impreza two years ago when I had the chance...
I can't offer any sound mechanical advice at how to fix this problem, but the fuel smell in my 2003 Legacy (2.5) was linked to failing o-rings at the fuel injectors. They were cracked enough to let fuel evaporate at the injectors when the engine was started and allowed to idle in cold weather. Yuck. I thought I was going to die until I had it fixed...suddenly no more headaches
...the dreaded head gasket problem. Consider this a cautionary tale, but this one will hopefully ultimately have a happy ending where driver and her favorite Subie live happily ever after. 2003 Legacy sedan. 129K problem-free. Small oil leaks that I could smell dripping onto and evaporating on the manifold, but never anything major. So when the weather hit the "miserable" mark here in New Hampshire, the fuel injector O-rings decided to crack and spew fuel all over the inside of my engine, prompting me to take the precious Subaru in for service. Poor financial situations and just plain bad luck have prevented me from getting any major preventative maintenance (short of tires, brakes, air filters and oil changes) done on the poor, neglected, daily-driver Subaru. So it was kind of a treat to be able to take her into my local independent Subaru mechanic to have her looked over. Sure enough, the O-rings had failed, so the mechanic replaced all of the injector O-rings and I went to pick up my Subie. $211 out of my pocket, and the tech hands me my invoice. I look it over and note that "head gasket leaking oil" has replaced the "head gaskets seeping oil" that was present on the invoice last time. Dang. Oh well, Subie and I have spent 2 painful years together and logged over 30,000 miles. You know, it really can't be that bad. The car never runs hot at all and for all the abuse she suffers she does just fine. But the tech indicates that the head gasket is leaking coolant too, and while it's an external leak I begin to realize that no...I haven't escaped the travesty that is the EJ25. Dang. Oh, and the transmission lines are corroded and need to be repaired when I bring the Subie in for the transmission service in a month. $235. That's neither here nor there and it doesn't have anything to do with the head gaskets. The tech quotes me $1550 worst case scenario. Removing the engine, tearing it down and sending out the heads for resurfacing (provided they aren't warped, which they shouldn't be given the fact that the vehicle hasn't been overheating), replacing the timing belt and the water pump, renewing the seals, and replacing the valve cover gaskets. Really seems too good to be true, but these guys are that good. I inwardly jump for joy that I will have virtually a new car with all sorts of life left in it...only it won't be 'til I've spent almost $2k in maintenance that should have just been taken care of proactively. Mostly, I'm just thankful that I opted to take the car in when I smelt gas. Realistically, I should have taken the car in when I smelt oil. But being the nonchalant person I am, I took a rather relaxed approach to the whole deal of car maintenance and chalked it up to "harmless leak that's not affecting my oil level". Moral to my lengthy narrative: please don't ignore the oil smell, no matter what engine you've got. Seriously. It could turn out a lot worse than my situation.
