About 2K4 STI
- Birthday 07/18/1975
Contact Methods
AIM
Flat4RX
Location
Vegas
Vehicles
87 Turbo RX
Recent Profile Visitors
2K4 STI's Achievements
USMB is life! (4/11)
10
Lots of pics and good info here http://www.ultimatesubaru.org/forum/showthread.php?p=994282#post994282
Help Needed... Wont crank over
2K4 STI replied to 2K4 STI's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That my next venture is to completely pull the battery cables out, clean both ends till they sparkle like new and try again. At least my old Deftones cd popped out of the cd player ,LOL forgot it was even in there. -
So I decided to try the jump battery method first before running and getting a battery. With the cables hooked up to just the positive and negative leads "no battery in place" and the other end to my new bmw battery, it clicked for a second,like it was going to try and turn over then back to nothing at all. Now I'm not even sure a new battery is going to do the trick. Well partially since the old one is dead. Anything else to check? -
I was going to try the jump without the battery, but trying to convince the wife to hold the cables while I try and start it didn't go over so well,LOL Im just going to try a new battery and go from there. -
I did clean the terminals both positive and negative but did not know about the melted wire thing. I'll check that also. No rats or squirrels here to worry about. -
I'm pretty sure the battery is dead. I tried jump starting it with my BMW and it doesn't even make a sound. -
My 87 RX m/t has been sitting for a few months. I know the battery is dead but even if I try and jump start it, it doesn't even crank over at all. No key Chime,no lights or anything. I checked the fuses and replaced the fusable links and still nothing. Anything else I can look for? I would try and push start it ,but I live on a hill and if it doesn't start that way I have no way to get it back up. It has always ran great and did when I parked it last. Thank in advance
Pulling engine with radiator attached?
2K4 STI replied to 987687's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You would still have to disconnect the heater hoses going to the firewall so you are still going to lose some coolant. On the flip side, sliding the trans back is not a very discreet way to do it either as you are going to be dealing with the gear oil from the trans. -
We are going to be starting the swap this week, so ill see how it goes. I'll post pics along the way.
Any one have any pictures of lowered EA82's?
2K4 STI replied to flyjum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah i know it took long enough. This week is the big swap week. Ill take lots of pictures and post them up each day as we progress -
I can finally add my RX to this thread 17x8 Rota Boost 48mm offset 215/45/17 Federal Tires Megan Coilovers in the front from a 00 2.5RS Rear stock EA82 Struts with Eibach 8" 250LB springs Going to switch to a 200LB spring, These are bouncy Rolled Rear fenders 5mm spacer in the rear Rear is XT6 Hubs and backing plate, Front is 91 Legacy AWD knuckles,hubs and axles with 05 WRX brakes -
Took some new pics since getting the suspension done and new wheels and tires on. 2.5 RS Megan coilovers in the front, stock ea82 struts with eibach 8" x 250lb springs in the rear. 17X8 Rota Boost in Gunmetal with 215/45/17 Federal tires 5mm spacer in the rear.
got to get back on here
2K4 STI replied to subaruguru's topic in Meet n' Greet. Your USMB Welcome Center
Since you are in the planning stages, toss those opinions out here -
OEM or Aftermarket Tranny Fluids
2K4 STI replied to PlaneDriver's topic in Old Gen.: 80's GL/DL/XT/Loyales...
We have it where i work also in quart sized bottles http://forums.nasioc.com/forums/showthread.php?t=1946774
