TheLoyale
    18
  1. Yep, but Subarus older then a Loyale have rotted away long ago over here (Sadly)
    Sorry I couldn't help you.
  2. +1 on the WoW sticker haha! Nice RX. -Tom
  3. Good luck finding Brat parts in the Mid-west. I have never had any.
  4. Its hard to find the 55w kits, You're are even brighter then mine! I think they look good. 6000k is the highest anyone should go, its like a "cool white" 5000k and 6000k are the best color temps.
  5. This might just be the final chapter of Trashwagon10, I step down, take a bow, and say goodnight as I move onto a '92 Land Cruiser. It has been a good run with TW10, but it will soon be over.
  6. Or a timed relay that kicks off after an amount of time (Like GM has)
  7. I like how it shoots. It lights up everything! Which is what I'd want (And have) JesZek, you've seen my HIDs on my EA82, right? I have 35w 6000k.
  8. Yeah its gonna suck more to fill it up, but then again, I came from full size Chevys, so I'm used to it. At least I ain't buying a Hummer
  9. I didn't know it had an offset rear diff, thats pretty cool! What does it have for suspension, 4-link? Need to drop some portal axles under it for maximum clearance!
  10. Specs show 11city/13hwy, But I don't think thats accurate, its a 4.5L FI Straight-6. No, fuel consumption doesn't bother me. Do you think someone with a '68 Chevelle care about milage? Nope! Cause its cool, and thats ALL that matters.
  11. If I am able to come onto this 80-Series, This is whats in store!
  12. Awesome you sold greenie! Yeah, i think you should jump on that 2000 Outback, just really check it over before you buy it, I will help you with the reseal and make it into a "Flip" car if you want. I bet anything that you could get $4,000 easy with that car. I'm hoping these people with the Toyota call back, needless to say I already have plans for it if I get it (Since there is sooo much aftermarket offroad for these vehicles)
  13. Made a call to Adam who owns the Land Cruiser, waiting to hear back on when I can take a look at it.
  14. If I could unload this Legacy for $2,500 I would go after this! http://madison.craigslist.org/cto/2567252300.html
  15. You do not need an Genuine Waterpump or gasket, the ebay kit provides everything you need and will work just fine. I would use Red RTV on the waterpump gasket to ensure a long lasting seal (I always do it that way) and also put anti-seize on all the bolts you take out (Except head bolts) Just dip the head bolts in oil before screwing them back in - just a little fyi That Haynes book is pretty good with specs and tear-down process. You're in good hands. But if you do run into an issue, feel free to ask us. Thats why we're hear. If you need a quick answer on anything, give me a call at 262-349-6488. Cheers, -Tom
  16. in other news, Jboy and I did cam and crank seals today on TW10. Only took about an hour of real work, most of the time was spent waiting for paint to dry and looking at Craigslist Subarus. I am wondering if I had set the timing off a tooth when I first did the timing belt, as now feels like it has stronger acceleration, also, the exhaust note has changed some. Makes me wonder, Jon, whats your take on this?
  17. Then don't read it, I really don't care. The point is, they contain info and will remain there for others looking for knowledge and ideas.
  18. Let me asking you a question, whats wrong with paintingvalve covers, sprockets etc... A different color then the rest of the vehicle? Ever seen Gyro-choppers, those guys paint all kinds of stuff on the motor, so whats the difference if its in a car? I will not get into another debate about what is "Ricer" with you, I really will not.
  19. Its the same principle as having a Red EA81 with a Blue air cleaner box and Valve covers. It dresses up the engine bay.
  20. It'll make it more appealing, its only paint.
  21. Welcome to the board! Hope to see you on the road sometime. Since your going to do a timing belt, I would also do cam and crank seals so you don't have to get in there 20,000 down the road. -Tom
  22. Possibly. Just remember, sometimes another sensor can fail and make other codes trigger without even being the issue. Like with my Legacy, I had codes for Knock, Cam and Crank sensors. I replaced the Cam and Crank sensors and the Knock sensor went away. If you want, try cleaning your Mass Airflow Sensor on the airbox. Use some electrical spray cleaner and mist down the little tong inside. Might take away your lack of power. -Tom
  23. If you take out the Climate control unit, then you can see the vent box and can get your entire hand in there to do what you need to do. Just take out your cup holder first, then gently pop the upper cover off (Where the dash vents are) and you should be in good shape. -Tom
  24. Complete list of every code a SPFI EA82 can thow:
  25. 32 is "O2 Sensor" 33 is "Vehicle Speed Sensor (VSS) "
