18
Gary, thanks for the tips. The replacement hoses I got I can sure blow air through them easy, plus I know these hoses came from a car with proper working brakes. I agree that is isn't the caliper, as I said before, my Legacy has 216k on it and was owned by a dude in the ghetto for 205k and was not care for what so ever. So if my calipers still work, Kara's should aswell (Unless by chance its a defect, doubt) Kara, I am gonna reuse the Bajo bolt and washers from your old hose as I couldn't get the ones from this hose (They were gone) Never Fear, we will get you're car fixed this weekend and bleed the brakes. Question for anyone, Now do I only need to bleed the 4 wheels, or is there also a bleeder on the ABS box or something?
I would like to see the other side, and I don't think your calipers are the culprit. The problem with the duel port calipers Fox has, use a different style bracket, so it makes me wonder if these would be the same diameter. Fox, the style Kara has is the type with two 14mm bolts which hold the caliper to the bracket. Not the style you have, So I wonder if the rotors are larger on this 3.0 Outback vs the 2.5 Outback?
"Whipsh" Where the pictures at? Because this thread is useless without pictures
Sounds cool, I will see what comes of tomorrow. Thanks! As for the Job, I wouldn't know off hand about any positions downtown as thats out of "My" loop. But it is in Tim Wessels loop and he is the area manager. Give him a call any time during the day at 414-336-4141, I know he is looking for people ASAP. And I know you know how to do all kinds of work, floors, basic janitorial etc. Good luck!
Awesome, I will try to get down to the Shop tomorrow if that works for you. I will call you tomorrow to see where you at. I will also inspect the caliper even more, The pistons seemed to press back in easy like normal, but good idea. The brake pads are almost like new also. Kara, I wonder, since you said the lady had the caliper replaced on the passenger side, I wonder what the pads look like on the driver side? Have they been done, or are they really worn. This is something we should also look at. Kara, let me know what time you want to get your brakes done this weekend. As Saturday I am gonna help Fox do Head Gaskets on a Legacy, so I can either help you before I do that or after. Either way let me know.
We will check out that hose, I might be able to get an entire duel pot caliper assy which I know works correctly. Waiting for a response from Fox. I am gonna rule out "Wheel Bearing" if the wheel keeps getting extramely hot, it will over time damage the wheel bearing and break down the grease, but I doubt this is the problem at hand right now. I'm sure you'll read my PM with all the other info
It might be a brake hose as Gary said, I have never had this issue, even with a Legacy that has 216,000. If anything, I might be able to get you a brake hose from a 2000 Outback down by Fox. If you still need to go to Westbend friday, we could stop there and grab it probably so you don't have to buy one unless your cool with buying one, dunno if any parts house would carrie the right lenth in-stock, but I'm putting ideas out there. To me the wheel bearing would also make some type of noise if it were bad, this car is super quiet. I will have to think about all this some more...
Pretty sad the dude doesn't even know what it is You have a thing for White EA82s eh?
Hope my rump roast hole isn't sore the next day...?!
Farms down by the river? What else goes on at this site....?
Heat gun works ok, but I use Mothers Back to Black. It soaks into the rubber/plastic and restores them and protects them. Give it a try, cause Ben, you know what my car looks like and how I keep up on it, so I'm not BSing ya.
I just hope the epoxy primer will adhere to the plastic and chip off after a few months. You could try acid etching primer, I used that on my Grill and it worked out.
Tow-Bar and a 20 year old Subaru will do you right
Haha, I'm gonna get flamed for this but. I have a can of Rustolium clear which I was spraying around the engine bay of the Legacy, so I did the hoses to, hasn't flaked off yet. I use Mothers Back to Black on the Loyale, thats the way to go if you car about your car. Its not like armor all at all.
Alright, enough wet dreams about EZ powered EA82s and the like Moisted up the engine bay and Mirrors with Clear coat. Worked better then I thought. I should be getting Potenza G019s put on tomorrow
More Stainless nuts and Bolts. Little here, little there till most of them are changed. SPT Battery Hold-Down with Chrome Locknuts. This is the best Metal cleaner I have ever used.
I would say only turn that pass side rotor, do all new pads in the front and you should be good. The calipers looked fine and both pistons went in very easy. I would leave the drive side rotor alone and just replace the pads, also couldn't hurt to check the rear as that noise seems to travel man. At least check it out so you know what your in for.
Hope its going to a better place and not the junkyard.
