18
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Next fall! I take it you are gonna take it to a shop? Just roll it on yo, it does look really nice if done right! -
Wheel time
Gonna paint it up Trashwagon? -
Wheel time
Those are gonna look great with some rubber on them! Whats the difference if you leave the centering ring on or not? -
24hours of lemons
TheLoyale replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Desmond Jones knows all about the 24 Hours Of Lemons. He's attended a few times. Sounds fun as hell, its in Joliet right? you could pick up a Legacy here in WI for like $300 that might just need a clutch or a HG. -
Does anyone have a picture of these tires on their rig? I'd like to see how much smaller these tires are compared to the Grabber AT2s.
Wheel time
Look cool! -
Wheel time
Silver is pretty bright, but might look fine with ur wheels and body color. -
Wheel time
OMG! same thing here.. Its construction all over Waukesha and Milwaukee. -
Wheel time
I dunno, I repaint my hub and calipers with just cheep semi-gloss black from time to time and it doesn't flake or burn off. Starts to rust after a year of salt. -
Wheel time
Link!! Linkaroo, click or ticket! -
Wheel time
No, Rustolium "Hammered" gray, its a little brighter then gun metal and it has a cool effect, makes it look hammered. -
Wheel time
I would paint ur calipers maybe hammered gray or something, looks tuff -
1987 GL-10 EA82T Runs Rough & Lacks Power
TheLoyale replied to jboymechanic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well we figured it out, Turns out one of the plugs for the Fuel injectors (MPFI) was all corroded and wasn't getting good contact (No.1 Cyl) so that is what was causing the miss-fire. As for the timing, yes I set it to the 3 lines (Middle line) I think there was a misunderstanding that post by Jon. Only issue with the car now is it bucks sometimes during take off, which could just be dirty air passages and a Dirty MAF. Jon, post up how it runs now after you've been driving it all day! -
When you took the distributor out did you mark which way the rotor was turned? If not and just put it back you, the timing gear on it will be way off. We might have to pull the Dist tomorrow and then turn the engine to 0-TDC then find out where the timing gear needs to be and then put the dist back in. I think this is your problem. Even though we turned the top of the dist and it showed 20 BTDC with a timing light, if the timing gear on the rotor shaft it off I think that will cause a major issue, as timing won't be true. GD, do you have any input? -Tom -
+1 to Silicon spray! It helps big time with rubber bits. I've spent many a time dicking around with stuff when all it needed was some spray to slide right on. Just to get this right, that tool slides over the entire inner end (With outer end removed) then you just break the torque and remove. Well if so, then I wouldn't need to drop the header. Only reason I was saying is due to I run an Unequal Length Header on mine, and its all in the way of the steering box if you had to access it from underneath.
