18
Restored Green Gen 2 BRAT
TheLoyale replied to Pooparu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Iowa doesn't allow personalized plates? Huh...:-\ -
timing belt replacement
TheLoyale replied to tractor pole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Whoops! No, do not use RTV on the mickey mouse seal.. Sorry for not making a space between the two. you can use a dab of bearing grease to hold the Mickey seal in place if needed.. Sorry for the confusion. -
If you are to replace the seals, the seals you are looking to replace are: Seal and O-ring for the Cam carriers (Behind the cam sprockets) Crank Seal (Take off the crank pulley and the two crank gears which the timing belts grab. The seal will then be behind that.) Also, on the new waterpump and oil pump gaskets you can apply some Red RTV where the gasket meets the engine block just for added protection - plus it helps keep the gasket where you want. And the small hose I was talking about will be right under the A/C pump (you will need to remove that to get to the upper hose clamp. Just some added tips and pointers. -
I'm not a fan of the scissor doors nor the hood scoop. The color is cool, but not for the interior. But to each their own. Its a nice job though. Still running the EA81? -
What Ive been working on lately...
TheLoyale replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
zzz -
Oh no clutch fan, you have electric in its place? Nice. Gives ya more room in front of the motor. Sounds good btw. -
I run coverless aswell, and proud of it. Makes checking belt tension very easy like GD said. just keep rags away from the running engine PS: Make sure you replace the small hose on top of the waterpump which goes to the heater core pipe running under the intake. Also replace the O-ring on the water pipe for the waterpump, (What the lower Radiator hose connects to) Cheers -Tom -
Sweetness! How much difference do the Deltas make? would they work better with an SPFI..? -
The Boomerang (Mountain Grizzly) Returns....
TheLoyale replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
"Its going to be great when its finished!" -
93 loyale 4wd rear end shimmy
TheLoyale replied to Rust's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Buy a new car... Lol! But really, does the wheel have any play in it? (Wheel bearing) Check the Castle/Axle nut torque (150lbs+) -
Yea, The brake pads I got from Beck/arnley were made defective (Really crappy, I will show you in person next weekend) so I went to Bumper to bumper and bought some new pads which work great! I didn't get done till 9pm, I started at 11am. I wasn't in any real rush anyhow.. Yea, lets meet up next weekend. Either at Foxs place or some place (Store, Food place ect..) maybe give Fox (Liz) a break from us? Lol.
Gonna run a sleeper car Mick? Old GL wagon with a 500c.i Keith Black power plant! "Hence the hood pins" -
Hood pins are boss...! -
Guido Gets Lifted
TheLoyale replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In order to remove the axle off the trans stub, you would need to either remove the control arm from the crossmember or pop the BJ out of the hub from the control arm. to be able to swing the entire hub out enough to pull the DOJ off the trans stub. Ben, in order to get enough clearance I would just pop the BJ out of the hub so I could swing the hub out some with the axle DOJ disconnected from the tranny cause then the entire strut/hub assembly will pop down and out enough to get the spacer block up and bolted to the strut top, then just put it all together. The axle shaft will rub on the crossmember where the control arm meets while the car is jacked up (Mine does) but one on the ground you will have enough space where it won't. As for why one side does and the other doesn't I have no clue, maybe it was hit once and somethings a bit off. But with the DOJ disconnected you will be able to swing the axle up more to clear the crossmember so you can put your block in. (I've been there and done it, Lol) -
Guido Gets Lifted
If you were to remove the A/C pump or alt you will see the small rubber hose thats bent like an "L" that connects to the top of the water pump and then goes to the heater core line that runs under the intake manifold. you will have to remove the A/C pump or Alt (Depending if you have A/C or not) and you will then see it. If you were to replace the Waterpump you would need to remove this hose anyway to get the water pump out. -Tom -
Guido Gets Lifted
Looking good Ben! Finally lifting it Are those 14" BFGs!? Must be old huh? As for the waterpump, mine was leaking out of the weep hole and there was no play in the shaft (Go figure) it very well could be that small 2" long hose from the WP to the heater core line like GD said. I had the part number for it (Dunno if I still do) Keep us up to date -
Pictures please! -
Rough rides are what Subarus were ment for, I like my cars to ride like trucks. Hmm, a Brat Trophy Truck eh... That would be cool with long travel shocks and electric cooling fans ontop!
