18
Water in my interior
TheLoyale replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well if thats the case, just get some clear all weather Silicone, pull out the rubber a little, pump some into the crevus and push the rubber back in (Wipe away exccess) -Tom -
Hmm, could the bottem of the windsheild seal be leaking and running under the dash and hitting your feet area? That or the firewall some how leaks? :-\ -Tom -
Now now, I was not gonna use "BJ" but I figure we weren't gonna go their Lol. Its pretty easy on the EA82, I just remove everthing off the control arm - remove the control arm (Incase the BJ is stuck in it and needs to be pounded) then just put it all back together. One tip though, after you get the BJ in the Hub and are ready to put the control arm back on, put the control arm onto the Balljoint first then loosen the two bolts that hold the Crossmember on that side of of the car, this will give you the extra amount of give needed to get the bolt back into the control arm and crossmember. then reattach your radius arm and the e-brake holder and you are done. If you even need to do BJs on the EA82, let me know and I will give you a step by step detailed write up on it, on how exactly I do it. -Tom
Public Service Bulletin regarding EA81 lifts and front axles
TheLoyale replied to The Beast I Drive's topic in Off Road
Hmm good reading, I've read every post on this. Thanks guys -Tom -
Can I buy new DOJ cups by themselves?
TheLoyale replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Tom, Thank you. I think I've heard of that place before (at some point) -Tom -
Oh, well by george it still looked like a good build -Tom
Wow, what progress. Nice detailed pictures too, its soooo clean. Amazing! -Tom
Rockford? Some sort of Company? -Tom -
Awesomness! (Making me want to paint mine nicely) -Tom
Bill, So hows the paint holding up on the oil pan? -Tom
I would check out Maxis Bighorns (As they are awesome off road from what I hear) I am going to go with them as soon as these BFGs get used up Good luck
Hmm, that'll be interesting. gonna need an adaptor for the top hat? As for Sound deadening on the EA82, there isn't much (if any lol) are you gonna remove the rear seat? as thats prolly about 75lbs. and if you have A/C, I would remove the A/C radiator and condenser (Along with the A/C lines) thats about 20lbs all together. Dunno about the pump, since the Alternater bracket bolts to the A/C pump (At least on the Hitachi pump) Good luck and keep us posted on any progress and what you find
Now now children - no pointing fingers as each other. -Tom
