TheLoyale
    18
  1. Hahaha, Well hey you got it off.... And well i got the drain plug loose.. Not off!!.. Now once i get the filler one off i'll be happer.... And no i did not drain the oil! I'm not that dumb:)
  2. Oh wow its that strong! Cool i'll see about doing that today.. And yeah i know the right way. It's lefty loosey...... Thanks
  3. Yeah ok! But i'm a little afraid about busting something?? Will that happen? How much torque can the diff cover and plug take? But i will try that. Thanx Tim:) Tom
  4. Yeah i hope it's nothing bad?? but i'm with Mike, Why wouls B/A stop makeing parts for Subaru??? It's just one of there suppliers closeing out... Keep your fingers crossed:grin:
  5. Hey nice wagon! Yeah the jacked up 70's look! :-p I want a lifted wagon so bad buit don't know what to buy and how to do it right... I only want a 2" but from what i've see all the kits are like $600 and up! I can't figure how the aussie guys can afford it? Anyhoo cool EA82 and nice Pugs too!
  6. Yeah what is the point of/if putting in grease fittings? If it gets that loose i'll just replace them... But anyway, So far my Control arms, steering arms, ball joints ect.. have no play in them.. BTW are the CV's supposed to have a very small amount of play in them? And i still can't get my rear diff plugs out??? I've soked and soked them in Sea foam deep creep... But i can't get them to move.... I'm hitting the long 1/2" wrench with a rubber malet.. But i'm not hitting it to hard, Just enough to make the rear diff shake a lil'.. Should i hit harder? I will keep soking them in Deep creep.... Thank's for any help:grin:
  7. Yeah that's whaty i was thinking.. I don't understand why they did that? So i just wait till something wears out and then replace it:lol: Crazy hey.... Thank's
  8. Yeah those look great! It's too bad these is a few rubbing spots, But if you get a lift that will go away. Still looks good the way it is.... Good work:headbang:
  9. Man, Did he have a brain? I thought to be a mechanic you had to have a deploma?? Well i guess he was sleeping in class the hold time:lol: To bad about to soob..
  10. Ok so theres no grease fittings anywhere i can see? So what can i grease for winter? I don't think theres any fittings on the steering arms nor on anything else..... So what to do??? My car is not having any noise or anything but i thought i would have to grease something.... So if anyone knows let me know:) Thanx
  11. Yeah i guess it would make a difrence if it's a turbo or not... Learning something new everyday!
  12. I'm pretty sure there the same.. Dipending if it's FWD or 4WD but i think a 4WD 86 GL-10 wagon is the same as any other EA82 wagon.....
  13. So basicly a 4WD auto SPFI EA82 S/R wagon is about 2630lbs..... WOW a Full time 4WD GL-10 turbo is almost 3000lbs:eek: No way!
  14. yeah thats the only reson it won't stay running.. So yeah just blow some air in the line and see what happens..
  15. S/R single range! God i'm dumb.... thanks:grin:
  16. Just a little off topic, What does SR stand for for the tranny?? Is it a name or just 2 letters?
  17. Oops sorry i ment to say that in my message. but yeah you should ad some Marvel Myster Oil to the fresh gas. So when it's pumping thru the system it might clean it out too... Good luck
  18. Humm? Well i've this problem with small engine's (Mowers, Blowers ect) lots of times.. Now you say once the fuel in the carb is used it stalls. Well sounds like a clog in a fuel line somewhere. That's my thoughts on that. And as for the fuel tank, Don't take it out just add some Marvel mistory oil. Yes i said mistory oil... Because you can ad that to gas too. And it cleans great! Once you add the hole a bottle and once you get the car running go fill it with fresh gas and let it run for a few... Ok I still don't know what to tell you about the stalling issue??
  19. Yeah it looks good! But how do you open the rear hatch? Does the tire mount swing away? I still like it.....:cool:
  20. Oh wait! The more i look at it it does look a little str8ter then 2nd or 3rd.... Humm
  21. 1st doesnt look str8t... It looks like 2nd and 3rd.. the only gear i see thats str8t is Reverse, That's totaly str8t.... Maybe my eyes are messed up?
  22. How heavy do you think a loyale is? 2700lbs sounds ok. I think the base lbs is 2500 for the 4WD wagon. Maybe i wrong......
  23. I was kind woundering what happend to him... Whats wrong eith dial-up anyway?? That's what i got... AOL 9.0VR works fast and always has a connection. Back to the subject Hope you feel better man....
