18
Can I remove this thing all together with my stock setup? I would need to plug the threaded port in the exhaust, but any reason why I could not remove this?
The Awesome Vehicle Picture Thread
TheLoyale replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
WolfsBurg. Shaazu. -
I have made the decision to paint the new Manifold, Cheery Blossom Red (Or something similar that I can find locally) Gonna check out what Wal-Mart and Menards have for paint. I can get the exact color matched in an aerosol from Grimmspeed.com for $14, but I don't want to wait for it since I might have the manifold, Monday.
That works!
So, I am working on a few extra little things for this car come the Don Miller show. We'll see if I get them in time...!
Original Starter! Cleaned up and repainted the original Alt (Now it'll probably fail) Repainted the PS bracket/tensioner. Fill tube. Now have a matching center cap for the spare!
I was thinking about this style. The page gives measurements, so it would be easy to determine. And these are easier and cheaper to get then the correct ones. http://www.ebay.com/itm/Subaru-Center-Cap-/140665338797?pt=Motors_Car_Truck_Parts_Accessories&hash=item20c04ebbad&vxp=mtr#ht_500wt_717 http://www.ebay.com/itm/1993-2006-Subaru-Legacy-CENTER-CAP-/260880293531?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cbdad5e9b&vxp=mtr#ht_605wt_702 Even these! $1 but $19.00 shipping lol. http://www.ebay.com/itm/4X-Subaru-Impreza-Forester-Legacy-Tribeca-Wheel-Center-Cap-Part-28821SA030-NEW-/320897135751?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ab6f5b487&vxp=mtr#ht_646wt_936
Any Subaru lug nut will work. You could even pocket ones from a Junkyard Legacy as all EJ cars have chrome acorns. As for center caps, newer Subaru wheels (16") have flat center caps like that, I wonder if they are indeed the same size. I bet they would clip in!
Ooo! 1985 Rally wheels. Nice find. I like these 12x1.25 Acorns will be what you want.
Right on with the rust converter, I forgot to mention that. Another good brand to use is "Permatex Rust Converter" it comes in a white plastic bottle, and looks like Milk, brush it on, it will turn the rust black, and also put a clear/milky seal over it, you can leave it uncoated for a while before it starts to fail, so applying some type of coating over that will yield a long lasting finish. it will also turn a rust scared area into something nice and smooth with no craters, for a solid seal with no pin holes. I've learned a lot of what products work well with a combined effort, as I've had many failed attempts to slow down rust (You will never stop it)
This is actually a good idea, the POR will need something to grab onto, and this would most definitely work. Parkerizing is usually considered to be an improved zinc or manganese phosphating process. I know they use phosphate conversion a lot on Firearms, where as back in the day they would use the "Bluing" method to form Magnetite on the steel gun. ANYWAY! It all depends how much your looking to spend and how much apply time your willing to designate.
POR-15 isn't all that great, you need to do a perfect prep-job or it will start to peel off. I wasted a lot of money on POR-15 over the years, and have found better products. The Bed Armor stuff would also be good, It might be slightly rubbery like the Hurculiner, but it is very very strong. I painted a hood with it once, and you could not scratch it off. What I would do is, paint the entire underside with some type of good enamel, and then coat it with the Bedliner (Lots more protection) this is the process that I am taking on my Ski wagon build.
Try an Areosol High-Solids base Enamel (Lots of places carry it) I'm using it on my build. There is also a paintable undercoating which dries rock hard (Not rubberized) that is a good route as well. Rustoleum makes a rock hard Bedliner,that you can brush on, very good stuff. Its about $30 for 1gal, but is worth it! Wal-Mart carries it in the Automotive section.
Its coming along nicely, and look how simple that engine bay is without the Hitachi! I should have thought about the 2WD rad support vs the 4WD rad support, Doh!
I think the PS crossmember has a little notch right under the oil pan, so the hard lines can run under the motor, out of the way. There might also be an extra hole in it. I am not 100% sure about the EA82 crossmember, mainly how the Control arms would attach. There may be no concern there, but figured I would bring that up.
You should be able to hybrid the EA81 lines to the EJ22 pump. I know MilesFox did this with an EA82 Rack and EJ pump. Have the hard lines run out of the EJ pump, then meet them up to Rubber line which would run to the Steering rack (Hose clamps will hold) that is how my EA81 is from the dealer.
Cool! Much obliged. My car is gonna run again!!
Thank you. I appreciate the comment! plus, if I didn't pay you, I don't think I would be very welcome at your house haha I spent a little tire cleaning up the engine and engine bay, I also cleaned up the original alternator and added a little flare (As you will see in coming pictures) I am debating on color, for the new manifold. Pontiac Blue (Same color as Valve covers and Air cleaner) Metallic Gloss Gunmetal White Silver (Alloy look) Cherry Blossom Red (Japanese Power Color) Which one...?
Weber air cleaner alternative?
TheLoyale replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I take it you hammed up the Hood support framing? I did this to my Legacy so I could run the larger ram air style air snorkel. Don't know if I'd want to hammer up my new hood. -
TheLoyale replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Beautiful! I like it! -
I would hate to buy a NOS part, only to cut it up and use it for my purpose. Tom Redmond said he has one from a Brat, so I will probably be swapping that one on. I would have taken on off the '82 Hatch I found, but it was in a slight collision and was dented. As for whats going on, I'm hoping to finish welding up the passenger side rocker this weekend, and then coat the entire floor on that side. Then its onto the Driver side rocker and floor. I am desperately trying to get this car driving in a months time so I can take it to the Don Miller Subaru Show, Its going to be tight!
Rebuilding 1990 1.8l loyale
TheLoyale replied to 90subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When my speedo says 65, I'm really going 70ish. 27" tires will do that to ya :cool: To the OP, I would pull apart the motor and see what in all you would need to replace, upon that discovery is when I would make decision to rebuild the EA82T or start looking for a good Duel-Port EJ22. -
That poor DL. Subaru dependability. Loose it in the woods, find it 10yrs later, and drive it away! I75eya, 50mph is scary as hell in these old rigs
