TheLoyale
    18
  1. I've started with the stainless bolts already on this car! I actually started with stainless the same way as I did on my Loyale, first replaced the hood latch bolts.
  2. This is why I gave the diff back, I didn't want to get that much into a unit that may not work correctly.
  3. Liking that Nissan wagon! 70s Japan had some nice lines
  4. http://autos.yahoo.com/blogs/motoramic/jeep-revives-forward-control-gladiator-pickups-easter-concepts-203117868.html
  5. I think my neighbors are getting worried. Everyday, I take something else off the car, and never put anything back on. A Fuel tank would be really nice right about now Hopefully I might have it by next week or so!!
  6. Some updates: I have now removed the rear trailing arm to de-rust and repaint. I cleaned and polished the new front bumper. Looks reeeal good now. The '81 4WD bumper came with another one of these bars, BUT there are major differences between the 1981 and the 1983 version - Top is 1983, bottom is 1981. The 1981 version is thicker and twice as heavy as the 1983 version, it also has an extra reinforcement stamping on each side. 1981 1983 Pretty interesting eh!? Here is the Midpipe/Cat flange. I am also on the look out for another set of these. Non ripped, with metal brackets/Screws. These are from a 1981 4WD bumper. (Do not need Lights) Anybody want this bumper?
  7. Yes, belongs to that Kristjan guy. http://www.ultimatesubaru.org/forum/showthread.php?t=106020&page=10
  8. No one is parting anything, the Diff was a spare from his old SS which is long gone, and the stubs disappeared.
  9. This is 100% true. Why does a 1947 Dodge pickup still have the original clutch disc in it? When a 2007 Honda needs one replace in 50,000? Depends how it was treated. Shawn, good to know about the Extra S from Subaru. I am debating if I should keep this diff, or give it back (As I only took it home to compare the two) and then I have the option to buy it if it'd work for me. Everything will work, except the axle stubs, I don't think there is any way to use the EJ DOJ on an EA axle, the splines look to different. Has anyone done this? or does somebody offer custom versions? Suppose I could save my self $50 and forget the LSD idea for now?
  10. So now I have a better understanding of a VLSD in general. Only thing I am not sure on about this one I have is, Do I need to add an additive to the gear oil? Or is there a sealed unit which is not serviceable like the quote from Wiki states? I do know the Clutch style LSDs are more popular among everyone on the USMB, but the VLSD is still decent, yeah?
  11. So this is indeed supposed to have Male stubs. Hmm... So I'll need the axle stubs from a Turbo car, guess I better start my search. Thank you guys
  12. I just picked up a 3.900 Viscous Diff from my buddy who has an SS, The case matches mine from the EA81, the only difference is this diff has axle stubs that press into the diff Vs Diff stubs that stick out of it with a roll pin. SO my question is: How hard is it to find these DOJs with the stub build onto them, and can I make a hybrid axle with the EJ DOJ onto my EA81 Axle shafts? Are the shafts the same diameter? Cause I want to drop the whole rear diff assy under my car and bolt it up without changing internals. The only thing I do need to add to the EJ diff is the Bushing plate on top, other then that all looks good. Also where do I get the correct oil for the Viscous diff? I tried to turn the tail shaft, and could not, so then I checked the fluid level and there is no oil in it. Shouldn't the diff still turn somewhat easy with no oil in it? I couldn't really even budge it with a 1-1/8" Socket. -TJD
  13. I am fresh out of ideas as well, but I would really like to know the answer too! This is mind boggling. Probably something real easily over looked too
  14. The big rubber things in front of the bumper? Sure, I could sell them if you need them PM me what their worth to you and a Postal code and I'll see what shipping a 2lb box would run. Cheers! -Tom
  15. This is an '81 4WD bumper I can't wait to clean it up, and then add some blinkers (Since there are non on this style) Should I get factory color matched paint and do the hood White again, or should I paint it Semi-gloss black? I think the white would look better, but would be harder and more costly to do. Hmm..
  16. I snagged these goodies today from the Pick N Pull for $100. I forced my the guys hand to give me the wheel for free. Will clean up nicely with a little polish. Original Bumper I will need to replace the front Rad support structure. Somebody beat me back to the car, and removed the Passing Light bracket and center piece, But they forgot one key part, the Passing Lamp Push switch (Which I now have and is for sale to anyone who wants it)
  17. Agreed, the 4spd is not a good match for an EJ. The diff in the car is a 3.900, which should be what you have in the Impreza.
  18. Possible Vac leak somewhere? Intake gaskets good? Getting down there with possibilities, after everything you have swapped. There really isn't much to the TB with moving parts, very simple. I don't know how different, even incorrect injectors, could cause a revving issue. It would just be over or under fueled. But it is good to look at all aspects.
