monty h
Everything posted by monty h
  1. Sorry, I missed the post about the pictures. I have identified the compressor relay and the 5 selenoids and have them wired (no swiches installed yet) but would like to take a suggestion theat Skip made and put a lamp/LED on the wires from the swiches in the struts but i havent identified them yet. Skip will scan the FSM for me......I REALLLLLY appreciate all of the help with this problem and I will post some picts and a schematic of what I did when its all done. Monty
  2. I appreciate the help......when you can get them is fine......
  3. Skip, Thanks for that info.....I will add a switch for the discharge selonoid as well. Could you be so kind as to post the pinout for the computer? or e-mail me? Thanks, Monty
  4. I finaly got my compressor to run (thanks skip!). I got all 4 struts pumped up and they are holding, so.......I plan to pull the connector at the computer and splice in switches to the compressor relay and all selenoids. I will mount the switches in the storage compartment by the parking break handle. Does any one have the color code or the pinout for the computer? It would make the job go a lot quicker if I dont have to figure out which wire does what. I will post a schematic and picts when I'm done. Thanks, Monty
  5. since you replaced the air with springs.....are you interested in selling the air parts?
  6. For 2-3 months I have had intermittent problems with the air suspension on my GL10 (AT, 4WD, turbo). Sometimes I have the rear (both) pumped up all the way and the front normal or low….sometimes one (usually a front) will be low and all others normal. Because the trouble has been intermittent and not the same each time I have been thinking that the computer is flaky BUT last week the whole thing went flat and has stayed that way. The compressor is not coming on. I have been looking on USMB and XT6.net and have found some info but have also found a couple of questions I hope you cab answer: The height light will always start flashing….usually after 10-15 mins running. Are their 2 fuses in this system…the one in the fuse box is good. Where is the compressor relay? There is a relay by the FL strut solenoid, is that it? Any help will be greatly appreciated. Monty
