davebugs
2
Everything posted by davebugs
I've been under my share of 95-99 Subaru's and don't recall ever seeing grey boots. Infact most I've "redone" had 120-200k on them and all seemed to have OEM axles but one car - drivers side. And on a 97 GT I had symptoms like yours and it was the drivers side axle. I've probably been under 100 of these cars and have only seen 2 bad or replaced front axles. The one that needed RR axle had a torn boot. Maybe I'm just lucky, but we do have winter here and these weren't low mileage cars. YMMV
rotor, wheel bearing, or tire. If it were backing plate it would be noise but I don't see that causing feedback to the steering wheel. Also could be axle. I'd yank on the axle and feel for play. Often the axle will vary from being under load to coasting(usually more vibration when under load). In my experience usually the drivers side goes first for some reason. But if a boot was compromised who knows, I've even had to replace a rear axle.
If you ever need to do this job I hope you have an Outback. The like 1" body spacer really gives you a lot more room then the other models. I have one of these used left. Works for like 95-97 IIR due to Evap lines at top. Nothing special has rust but didn't seem to leak. Could be experimented with and coated with something before being installed. Knowing what they cost I kept them when I parted cars if they seemed any good. And I can't really work on cars anymore.
There is so much you can check over and do on the engine while it's out. You can leave the radiator in (although I usually have it out to be cleaned/tested) just make sure to put cardboard or an old chunk of paneling in there after you take the fans off to stop from accidentally damaging the rad. I hate working on my back. Actually I have a lift and can do it either way and always pull the engine.
Block of wood and sledge hammer. I usually do it underneath. A 2x6 works best for me on basically the bead of the rim. Don't forget to spin the wheel from time to time. Don't wanna pound all in the same place. I always buff the wheels and the metal mating surface on the car and anti-seize when reinstalling.
Actually when it' s electrical 1&2 or 3&4 miss together. Due to the "wasted spark" ignition system Subaru's use. Could be a plug, wire, or coil pack. You can start by moving the wires front to back if you'd like and perhaps change the plugs while you are at it. If the code follows the plug wires then they are the problem. If not it was a plug(you may have changed out) or the coil pack.
The old style (brass ones) were sturdy, reliable, and easily reusable. The newer style seem less sturdy and expensive. But I'd usually replace them. IIR you have to pay close attention to their orientation when compressing hem too. I take a long time to compress either of those. If you wer ein the US I have a few "kits" including the aluminum piece that goes onto the block to allow use of the old style tensioner, an old style tensioner, bolts, etc.
17. 5 hours? Seriously. I"m not a prefessional but if I went at it seriousely it takes half that. I do it at my own pace, working alone and it takes a long day. I remove the rad and have it cleaned and tested and definately remove the engine. Removing the engine IMO makes a better job of it (surface preperation and stuff. And if a plastic baffle place you reseal it. Heck I reseal the metal ones too because I have the engine out. And he's clueless about the current problem. Did he use Subaru HG's (or something he made more money on? And I believe in 98 the charcoal canister was moved to the rear basically under the fuel filler tube. First guess is he screwed up and left a hose off the intake, broke one, you get the idea. Or the filler tube just happened to go bad - because why would you have just decided to replace the fuel cap?
Everything helps, especially large items like fenders. Old Subaru's are light cars. Often folks don't look in the trunk, atleast when I used to haul in scrap cars they didn't. I just see it as a wasted opportunity to ship empty cars they cut back on what you can haul to PA seperately - or cost you more. I passed a car hauler last night that had 6 on top row and could have handler 5 on bottom row. It was one of those that was kinda extended on the tractor side. With a car over the cab.
