![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
davebugs
2
Everything posted by davebugs
No harm in PB Blaster. I buy it by the gallon and put it into a squirt bottle. The back n forth things I always do on any stubborn bolt - with lube if possible. Likely since this car is neglected you'll find oil in the holes due to VC leakage. You may end up wanting or needing plug wires too. If so I recommend OEM plug wires on the 2.5 engine. SOme here say I believe NGK wores will work. OEM's have never let me down and I believe close to the same price. But you will need a nice collection of socket extensions. I usually use a spark plug socket with a swivel built into it - S-K or K-D (I always forget). Liek I said I always do thios on a cold engine with aluminum heads - I'm waiting for someone to say to do it on a warm engine - I believe some folks think this helps.
A few pointers on teh job in general. I use a somewhat rare 1" extension it seems on Subaru's. On the drivers side I use a WAY long 3/8 extension to get the ratchet out of the engine bay. ANti-seize the new plugs (I do di-electric grease too on the plugs/wires. Don't be shocked if you find out and need to replace valve covers. Some folks like ot do plugs on a warm engine, I prefer cold. Old unknown plugs in an aluminum head is always a bit nerve racking. Good luck
WISH we could get that engine here. But those are CLASSIC gasser HG issues here - especially for the DOHC 2.5's. On our enginers they don't cause white smoke, they will pass a compression check too. The combustion gasses leak into a water jacked and cause a bubble in the cooling system which causes residue in overflow bottle. The classis symptom of the air bubble is that the radiator is low and the overflow is full (and has run over and lost coolant).
Seafoam is best into a vacuum line, in the tank won't hurt though. Does produce SERIOUS white smoke if done correctly. Since I'm not worried about cumbustion chamber I'd use vacuum boost line because I could neve rfind a candidate that worked for me by the throttle body. Now the chain places have aerosol cans that you can use and place on throttle body and replace airbox. The simple can used to tell you to stall the car when the can was almost done IIR. Then let it set 5 minutes and take it for a drive (killing all local mosquito's). I still woudl take that route even though I believe the instructions are different now. I've only tried the aerosol cans on a Toyota RAV4 and they make it very difficult due the throttle body replacement half was down engine near firewall on drivers side. I don't realy work on cars much anymore and haven't tried the new expensive aerosol can on a SUbaru.
87 is the lowly standard here. Of course ANYTHING with Ethanol that they force on us sucks. I saw at the local outdoor power equipment place they actually sell fuel for weed wackers n stuff by the quart for like 8 bucks. NO Ethanol. SOme folks that owuld be an excellent idea versus it eating the fuel lines every year and gumming up the carbs (ask me how I know!). I jsut use both of mine too much. ALso the Seafoam cleans the cats and both O2 sensors. But yea - a good basic tunup and OEM wires on the 2.5 are excellent idea's. You're very likely to find the real problem doing basic maintenance things and Seafoam and still be way under what new cats would cost. ALso remember IMO aftermarket cats only seem to last a year or two and OEM are very expensive traditionally.
Common. I have had excellent luck running Seafoam thru a vacuum hose to fix this for thousands of miles. For the price an option I'd use rather than replacing the cat(s). Do a search. Oftgen discussed here. Starting in mid 2000's I believe it seemed to get less effective - teh Seafoam thing, but considering alterntives still worth a ashot. Besides - it creates an impressive white smoke cloud. Do it somewhere where yopur meighbors won't think your house is on fire.
Razor Blade is about the best I've found. There is a "silicone caulk disolver" now at your local home center - never tried it though.
Hey - it's already off to take to an old fashioned press that way also if you wish to swap the bearing. I'd jsut try to go by feel ont eh new "stub" and only one time bothered having a new bearing installed (I have no press or fancy hub tamer, etc.). Infact I started doing thie instead of doing the bearings. ANd I beleive I got the idea here actually. Not an original idea.
I'm simply saying 2.2's are sturdier. No HG issues which means less rod bearing issues. I also said that if you know this 2.5 it may be worth fixing. But when I dealt with unknown engines/cars the best solution for me was to do a 2.2 swap. It's your choice. ANd not a real clear cut one in this case. If it had many heat cycles fue to HG's for instance I'd definately say 2.2 it.
I gotta tell you I've fixed a lot of SUbaru's. A 99 Forester almsot caused me to swear them off! Took 3 JY engines to get a "good" one. I did HG's, reselaed, etc them all. That was a 2.5 SOHC on most 99 Foresters - including my nightmare. That's what the first engine was. In the end I made an 02 Legacy work (took a different timing belt) Infact I sold the remnants of the engine go Gary a while ago.
Looks lined up. I beleive I threw out most of my valves from paritng 2.5's and have more to do but not for a few weeks likely. I used to do a lot of 2.2 swaps. Yes the 95 auto(EGR) is the best/simplest. Since you know htis 2.5 you may want to fix it. On unknown or neglected cars a 2.2 is a very easy decision.
Very expensive transmissions (auto). Where was HG job done - dealer or independent. These can get picky about which HG's are used. Check for torque bind as stated. Often I check coolant reservoir even after HG's have been replaced. Becasue a place too lazy to clean otu the overflow to make it easier to monitor in the future may have does less than what I consider a "complete job" and you may guess at whatever toehr shortcuts were taken - like no idler or WP replacement for instance.
