davebugs
2
Everything posted by davebugs
Diesel?
davebugs replied to subarulegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
PA is bad about diesel tax, it's about the same here. Until the past year or so it used to average about mid grade gas. Used to actually be cheaper than RUG in the fall. About 1/3 better mileage. Simpler engines (no plugs/wires/etc) and longevity that far exceeds a gas engine. On my DD an auto I average 38-40 MPG including with winter diesel. Other than timing belt every 100k and nromal fuel and air filters my "repalcement parts" is a very short list. I've redone suspension bushings and stuff to get the superior handling back. But as far as repairs an oil pressure sending switch at like 150k, 2 glow plugs and a glow plug harness(50 bucks). Not bad for 220k and I really do think it's half way through it's life. The early 2000's VW auto's are wimpy (o1m family) and I just had to install a reman at 215k. The 5 speeds get 50 mpg. Remember VW's are heavy compared to all the jap cars - part of the reason they ride and handle so well. So I've got I'd say 200.00 in repair parts in over 200k. Can't beat that with a stick! And after 150k I really consider most anything a maintenance item really. Now that I drive maybe 15k a year the and with the diesel prices and mandatory biodiesel (not quite as evil as Ethanol) I don't know if I were to buy new now if it would be diesel personally. Great traveling cars - 500 miles per tank - basically longer than your kidneys can last before stopping. The 5 speeds get 600 miles per tank. WIth all that low end torque very fun to drive. If Subaru ever gets their Diesel here or VW offers an affordable AWD Diesel I'll own one! -
Diesel?
I own 3 MKIV TDI's at the moment. So I'm rather firmiliar with them. My 01 Golf I bought new and is ready to turn 200k. Can't bring myself to pull the trigger on the thing. Whish is the only body style I'd like to add to my air cooled collection(I have 6 from early 60's to the last year convertible). The tracker conversion was done well and the driveline only has 16k on it. It is a butt ugly green inside and out. I did some Google searching and on thesamba with really no luck on this thing/tracker conversion. Perhaps I was guessing keywords wrong. -
How old is too old for gas?
davebugs replied to The FNG's topic in Old Gen.: 80's GL/DL/XT/Loyales...
We have a winner. Yet another way Ethanol will harm you. 6 month old Ethanol gas will cause problems. Sta-bil was slow to put out an "Ehtanol" produst but they have, it' sgreen, and usually called Marine. I can start an old VW with 10 year old real gas long before one with a year or two old gas with Ethanol in it. Just sayin.. -
Welcom eto USMB. WHen in doubt grab the rearend too. I'm not positive but the rears are probably hte same other than maybe drum versus rotor. But grabbing them both insures matched gearing. I believe I've done htis with early 90s Impreza's and Legacy's without issue on 5 speeds but it's been a while.
I buy reman's and don' tbother trying to rebuild them here in the rust belt. You'll have enough time in cleaning up the pad carriers, etc. Descale/derust usually with a file for me. As pointed out dont' forget the pad holders BEHIND the metal shims the pads ride on. ANd I wire brush the stainless pad shims an dlube them too. You'll likely need rotor and pads too is stuff has been frozen up.
Not really. Not a real exact science on most cars. I believe some Acura's you check them like oil. When cold and not running. Now that's the way it should be. Yea - I understand all the TC reasoning and it's effects on level. But if folks can't read it well it's less likely to even be checked. Leading to premature issues and possibly failure. I'm talking all auto trans - not just Subaru. I think this could be the best advancement in automotive technology. Keep your battery cars, give us an ATF dipstick that's easily read!
Yep. Double check the hot wire stuff too. A lot of times if you undo the nut up by the positive battery terminal there is lots of crap hiding there. ALso the solenoid hot wire to the ignition switch. Sometimes you can see how crappy the wire under the red cover is. Because it certainly does still sound like something electrical is going on. Perhaps Cougar is alive and well and has specific recommendations. I lack sophisticated electrical knowledge (and kinda like it that way).
Diesel?
I'm feeling all fuzzy. How much to spend on one toy? Going today to look at a VW thing on a GEO Tracker(Suzuki) frame. I hauled in a 2000 VW TDI tuesday that a kid screwed up the timing belt on and probably bent valves. Especially for the "crawlers" it appears a VW diesel into a Suzuki is somewhat of a common swap. Seriousely doubt it's worth the time and money but potentially I could end up with a VW Thing/Tracker/VW Diesel AWD(yes AWD). I 'd have to believe it would be the only one! THe Thing isn't cheap though -
Man I HATE these kinds of messages.
ALl are regular mostly 97 2.5 DOHC's.
I don't do anything exotic. Mostly because the equipment is already beat by kids and it's usually kids looking for the parts. And then wanna spent more money on the stereo and wheels than keeping the car running.
If one of these will work let me know. He may be coming for them next week.
First place to look for adapter is Kennedy Engineering - they were the king of VW adapters back in the day and still around.
Diesel?
There are threads already here about Subaru's diesel which ISN'T coming here. And folks selling Subaru Diesel engines here in the states. My DD is a diesel, I'd love to see it. But VW even only brings a small portion of their Diesels here because of all of our red tape. Don't hold your breath. -
I write on airbox with chalk mileage of last replacement. Then every time I'm changing the oil I don't have to run to the computer to see how it's due. Try and find cheap chalk like at a dollar store. On seriousely a chunk of "innards" from drywall/sheet rock depanding on what it's called locally. I usually have one ahead for all my vehicles - just like oil filter and oil which I stock more heavily. Air & fuel filters, transmission and radiator are the forgotten maintenance items. But the air filter has the shortest service life.
