davebugs
2
Everything posted by davebugs
I go 20k to 40k depending on the car. I check them every 10k when changing oil (and usually rotating tires at 10k too). I "flip it" end for end to lets say find a cleaner surface. All airboxes cause the airflow into the filter to not be evenly distributed. This will start to leave a dirt mark you can see. So often it gets one flip at 10k and changed at 20k, sometimes it lasts 30-40k. I forget the ratio on how bad a dirty air filter can hurt mileage due to the ratio of air vs. fuel in the combustion chamber. Often neglected, easily changed.
I guess first clarification is abotu the sound. At the start I thought you were saying the speed was different (meaning timing belt). Crank and no start occasionally with no code I've had be crank sensor several times. The crank sensor can become it's own project. If you have any thought about removing it start soaking it down. That bugger often disintegrates when trying to be removed.
2 things. The cam sprocket hash mark outta match up "dead nuts" with the timing belt back cover notch. And it's very hard to see, but there is a hash mark on one of the 3(IIR) tabs on the back of the cogged piece that goes over the crankshaft behind the harmonic balancer. It matches up to a hash mark you'll see basically under the crank sensor.
I'm not following what you are talking about. All 2.2 auto's since 95 have EGR so they have the foot long metal tube(for the year span you're talking about).
Search on Mizumoauto here. SOmefolks had troubles with Ebay kits and I think it was them. I think most of us use theimportexperts. Actually GD will probably have a preference or opinion.
I pull the fans. Put cardboard behind the radiator because you likely will accidentally hit and bend some fins. If the fan bolts break you gotta pull the rad which sucks because mostly of the lower ATF line. And it just became a bigger, more annoying job. You may be able to do a timing belt job without pulling the fans. But Id think it'd take a while and there would be no skin left on your hands.
If both cam sprocket line up that's be rare for the crank to jump but the cams be in alignment. I'd do a ccompression sheck I guess because it's simpler. Really one cylinder on each side should give you a very good idea. Much simpler than pulling the rad fans and getting the harmonic balancer off - not that in the end that may be what it takes.
I recently started a thread about a 95 that simply jumped time. Wasn't able to tell until I took BOTH sides TB covers off. No bad cogs on the belt - weird. I guessed that whover did the last belt forgot to slide the tensioner left before tightening up the 2 bolts. I had my friend ask the garage where it was towed to take off the R side TB cover because it's the easiest and they got back to me that it was tight and did rotate - and they were correct. When I took off the L TB cover I knew what the job for the day would be... Good luck. I've got some 96 Impreza 2.2 heads here that may go on Ebay tonight or tomorrow. If you need then hollar. They may be one of the last things I list since I don't really wanna ship them.
Take a file to the end, then I wire brush the studs. ALl to free up the threads of crap. If you can get them cherry red with a torch they usually come right out. On old member here Skip helped me do a few that way. I've been lucky enough using these procedures that I've never broken a stud in an engine I cared about (did break on e in a 2.5 that was junk so I didn't care). So no pointers about the one already broken. And I anti-seize the crap out of them. And use the expensive nuts from the dealer. Whatever that coating on those nuts is works pretty well. The same nuts as uses on exhaust , eng/trans nuts, cross member nuts.
When this needs done I do it mid way or further from the base to make sure I don't hit the nipple on the car. You can also try things to "shim" under the band wrench. I often use cardboard, sometimes old 80 grit sand paper. Since at the base you get the most bang for the buck because the leverage is more "true" and it's harder to collapse at the base.
As I believe has been mentioned they can be real stubborn to get out of that rubber Oring in the washer tank. Probably due to age of the rubber. If you have a used one handy I'd oconsider that. Because I believe you're gonna be taking the old one out to get some leverage on the old pump(s) to get them out anyways. I've never tried instaling them, but have taken them out to be cheaper to ship to an Ebay customer.
I understand all that very well. It had codes for cyl3 & 4. The car is at a friends 50 miles away and his sister drove several hundred miles to get there and got the code on I80. It calls for the cheap plugs BKRE5 or the "double platinum" that say laser platinum on the box IIR. Also IIR they say plugs at 60k so she's about due. I was gonna grab the fancy plugs (I stock the cheap ones) and a coil and head up there. Then backtrack 20 miles to dealer if plug wires were needed. That was my plan. It was cold/wet when she got the codes. Now no more problems so apparently she's gonna try and make it home. From what I've seen ANY electircal problems causes the opposing cylinder to have a missfire also. A bad plug, wire, or coil. I told him to swap wires back to front so if the code came back they could tell if it followed the wires or not. He had spine surgery before Thanksgiving so I don't know if he did it or not. But no codes since the lady had them cleared while traveling on I80. I did recommend he get a cheap ODB2 reader because they come in so handy for everything since 95/96. If she does get another code and he did swap the wires that'll give insight to the wires which is one of the 3 main possibilities. The plugs are due anyways so replacing them is no biggie. I'll be curious to see what the problem ends up being. I dont know her for all I know she'll take it to the dealer and get plugs/wires/coil - wouldn't that be a sad day!
