davebugs
2
Everything posted by davebugs
Bolts
davebugs replied to Sabaroo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Post up a pic or email someone. I have a lot of those bolts and parts here. Working on stripping a 97 2.2 now that had HG issues. Or PM me for an email to send pic to. -
Hello from south central ohio
davebugs replied to mushroomman's topic in Meet n' Greet. Your USMB Welcome Center
Read here about burping before you start the drain/fill. -
Welcome. I don't know of anyone in your area but someone else may be able to help. If you decide to do it yourself the folks here are very helpful. -
I recently found out that PB is supposedly corrosive. So I wouldn't use it as a lube. Strickly as a penetrant. I found out when having work done on my car and my friend asked for WD40 to spray on some electrical connections before removal. He says PB is corrosive so to never use it on wireing connectors. And if you read the can of WD40 you know it's the opposite. I still don't think of WD40 as any kind of a penetrant though. But it worked on the wiring connectors in my car with over 200k in the rustbelt.
I've always had enough parts to make them work. SOmetimes requires an additional T or a small plug to be installed in the intake about #3. If you get stuck drop me a PM. I'm debating about parting a 97/98 (I forget but it'll be written on it) 2.2 that should have all of that on it. Actually thinking of isting the heads if they are o.k. car had HG issues(traditional HG issues not Subaru specific HG issues). I also have an intake from like a 92 here all stripped down and I cpould send you a pic of those little metal lines that hug the intake. I won't be back for several hours though
I've never needed a slide hammer to remove a pilot bearing. Buy yea - the scothbrite pads you got are what can be used on the flywheel. ALthough I almost always have it machined myself. A spurt of warmth heading your way, cold again tonight. Froze here overnight (first real frost) and coming again tonight.
I won't be around for a bit but 2 things. Did you pull the lower hose to begin with - and fill through the top rad hose as the video and burping instructions here say to do? An air pocket (the EXACT reason for following burping instructions) could be causing hths. Have you run it long enough to open the thermostat (assuming that it has one and i'ts good). Have the fans kicked on?
I have those "flex joints" in the exhaust fixed regularly at a local INDEPENDENT shop for 40.00. Don't know about the rad. AC was somewhere between laziness and not knowing that it didn't need to be undone. I've done a lot of these swaps. I'd think the HVAC thing is mechanical (as opposed to a fuse) an dunrelated. I jsut say that after pulling a lot of those to fix the HVAC bulbs. Actually usually it's minor issues with vacuum lines and valve cocver breatehr hoses usually. I've never had one with an issue really.
