davebugs
2
Everything posted by davebugs
I believe he already posted here. Infact I believe I responded. Does sound like fun. Fun and a budget where vehicles are concerned rarely works well. I hope this one does.
I've found the "new and improved and more expensive" new style tensioners to be more subject to fail. And they are always on interference engines. I think they fail more on their own and get ruined more by compression. I also try and keep them in their normal position when compressing in a vice. Therefore I probably wouldn't use it. A new one comes already compressed. All tensioners I give the vice a little nudge everytime I walk buy it the whole time I'm working on the engine. So often an hour or two to compress a tensioner. Probably overkill but I really do go outta my way to compress them slowly.
Back in the day a local shop used to cut new sunfoors into cars and trucks. I'd grab metal there - but that isn't done as much anymore. I've been known to ask local body shops to keep damaged hoods and fenders to be metal donors. I have some stuff here to play with my MIG welder when I get a chance that came from the VW dealer bodyshop. Duct work (galvanized) I believe makes toxic fumes if welded. I'm also not so sure how well putty and stuff sticks to it even if roughed up pretty good. Just remember to use 1/8" rivets when possible to aid in hideing them later.
I used to pay less than 200 for a specific Valeo kit. I say specific because I paid an extre 15-20 bucks to have all components Japanese for American (rather than 3rd world countries). Make SURE you get the TO bearing clips at the dealer while you're doing this in my opinion. I got my Valeo kits on Ebay but I forget from who. But someone will be a little more expensive and list this options of components from countries we think of as having better standards.
Exhaust Swap 95 Legacy Wagon to 99 Outback
davebugs replied to Legacide's topic in Subaru Retrofitting
You've got good odds if you're swapping the whole system. Thereis a CHANCE you may have isues due to O2 sensors - their palcement is different. If so I don't know if swapping ECU's woul dhalp or open another can of worms. Physically I beleive you'll be fine. Sensors ? -
I've used a block of wood on similar ghetto repairs in the past. That way your hammer is out where you can actually swing it. Also the endo of the 2x4 (especially if you round the corners) doesn't leave as many dimples in the metal. But yea - just buy used doors that match way cheaper and pretty easy to swap.
want to change to DOT-5
davebugs replied to soobie_newbie67's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I switched an antique VW (62 single cab) to DOT 5. Because I was redoing the brake system. Master cylinder, reservoir, wheel cylinders, brake hoses. Used my Motive pressure bleeder. First think I ever did DOT 5 in and it's been on jack stands the past few years waiting on the bumpers and wheels to be painted. Which reminds me I guess I outta call him! I went to it because this truck doesn't get many miles (or any recently) and it's supposed to basically be lifetime. Doesn't draw moisture much. Not at all for performance. -
EJ25 in 1997 Outback Wagon warning flashers
davebugs replied to BY Mechanic's topic in Subaru Retrofitting
You've set of fthe alarm. Slow 4way blinking is the symptom. Ironically you can still start and drive the car! Look for a little black button under the dash. If you're lucky it's by the hood release mounted. If you're unlucky it's in a mess of wires under the steering column under the dash. A generic black button often taped up with electrical tape making it even harder to find. I think htere is a way to cycle the key a bunch of times or something. BUt I always figure I need the find the button anyways to program keyfob's if needed. -
Engine Swap - 1998 EJ25 to 2007 EJ 22
What state are you in? Several folks here have talked about this but I don't know of anyone who had done it. The electrical stuff is too much to overcome. Also on a personal opinion note I don't think you can find anything more reliable than a 95 2.2. And it's a very easy swap - search around here a bit and you'll see. -
Check the title of your thread. And PLASE update your location to something useful including state. The title says one year and the body says another. And welcome to USMB. Lots of good info and folks here and a very useful search function. -
Iowa is first in the primaries. This is their golden goose. I'd prefer to think logic will prevail, but it never has with Ethanol. The folks in office will buy Iowa's votes again. And not only will we continue to directly pickup the tab. But they are trying to force us into buying new cars that they have determined all the specifications on. And this crap keeps ruining small engines, and the older the car the worse it is. Take it from a fella with 7 antique cars. So we get worse mileage and it hurts our cars. Politicians see us as being non-compliant to their tree hugger agenda so they keep forcing us that way. Ethanol ironically hurts the environment, distorts world food availibility and price yet then continue to push it. But Iowa votes first!!
That "sounds" like some cars that have a maintenance reminder light. Used to have to reset it on a Honda - I forget how now. But is it a low oil level light as originally stated or a maintenance reminder light? I have no knowledge of any Subaru's since 2006, just sayin' I know atleast some Japanese cars atleast(could be others) there is a maintenance reminder light to be reset and that's different that a true oil issue.
Tear it apart, remove engine or trans. Usually the folk cracks too far down to see from the outside. Just do the clutch job and source a clutch foltk just incase. It is amazing how many forks crack on Subaru's. ALso don't forget to ge tthe TO earing retaining clips at the dealer. I have seen them cause this problem after they break.
Very tight - not much help. I usually run them on with an impact and I'd guess about 90 lbs or so. But for those that know I assume you're talking about the bunch of them around the crank that hold the flexplate onto the engine and not the 4 that hold the flexpate to the TC(infact I don't know how you'd ever be able to measure ft/lbs there anyways).
A lot of times if it's an auto the "rod" gets bent and really doesn't tell the ignition it's in park. Sometimes removing the shifter cover can help find the problem, sometimes it IS the problem. Some cars I believe you can remove the key with the car off in neutral. Unless I missed it would help to know year and model, as well as auto or stick as folks have been asking.
Some cars you can just use a bolt extractor on and be done with it. Don't know if a Subaru has the space. On my VW one of the first things I did was get rid of those lugs! My local VW dealer will remove them for a fee (coffee kitty money). I don't live in the city and out here most folks have guns. Cuts down on petty crap like getting tires stolen. Last thing I ever want to happen is have a flat and not know where the lug key is because I had someone else rotate them, check the brakes, whatever.
