davebugs
2
Everything posted by davebugs
I seem to do a lot of 97's and this is the method I'd use. First couple sets of heads I checked again for kicks when they were in the car (just threw the valve covers on without gaskets or old gaskets to make sure no damage or dirt on engine install). They were always o.k. On this year with the shims without whatever the dealer tool is was the only way that made sense to me. Also doing it this way there is no compression so it's very easy to hold the cam sprocket and move it back and forth. Often I'd give it a few revolutions to displace the assembly lube first, I'm kinda generous with the stuff.
There is probably a how-to on shanging plugs somewhere here. You gotta be patient. Perhaps remove windshield washer reservoir and battery. I find a rediculosely(sp?) long extension or series of extensions helps. On the drivers side often it's easier to extend out to above the fender and use your ratchet literally outside of the engine bay. I use a swivel spark plug socket. For some reason I recall on one type of Subaru engine that my 1"(that short) snap-on extension is needed. Hose clamp pliers (if you have them - handy tool) are often best way to remove wires from plugs in manual method doesn't work. Dont' forget anti-seiza and dielectric grease for new plugs. Those NGK's are usually gapped already - I believe tha gap is the "-11" part of the plug #.
You also still may not be correctly burped. Make sure wen you think it's o.k. take the car on a 45 mintue to 1 hour drive. See if it overheats. No AC on (yes I know it's wnter). If it overheats it's still not burped correctly and/or HG troubles. Most of the timing can be rather easily checked by removing the timing covers on both ends/sides. To make sure the timing mark on the crankshaft is set proper it's a bigger deal (more to remove).
2.5's like OEM wires. Get the cheap NGK's with the green writing BKR6E's or something. They are like 2 bucks each. Don't forget on this engine an electrical missfire on one cylinder will also generate a code on the opposing cylinder. So if the missfire if for 1&2, or 3&4 it could still be one bad plugwire or plug, or the coil pack.
I've had luck with seafoam. If you do a search here there should be plenty of reading. Feed it through a vacuum line. Makes a HUGE cloud of white smoke. Under 10 bucks a can. Worth a shot to me. I've done this with several and put another 1k or so on them without the code coming back. The old GF's 06 Impreza now gets this code when she gets cheap gas. Try a major refiners station for a while.
I have found them excellent to deal with. In all the kits/orders (I'm always adding or subtracting something) I've had 2 minor problems over the years. Those issues were handled promptly and very satifactory. That's atleast as important as price. They were recommended to me here on this forum and now I recommend them as well. I have also started buying other timing belt kits of of them with the same success. Remember to check Ebay FIRST. Sometimes they have deals on Ebay that aren't on their website. The boss decides to run Ebay specials and some of the workers don't always know what he's running. They will match that price if you've done your homework and know to tell them. I'm personally still hesitant to install the MitshbOshi belts on interference engines. I did recently buy a kit for an 02 and got the WP from them and cam/crank seals. I must say the WP gasket and seals look OEM. Haven't installed them yet on a friends car. I have OEM parts here incase he wants to use them instead.
The hoses (and the OEM clamps) can be a pain. Especially the lower one. Clamps rust and twist, limited access to get them off even with hose clamp pliers and battery removed. If you remove the ATF lines you'll very likely need new hose clamps for them too. I always replace all clamps. I live in the rust belt. One of the assortment wall racks is what 50-60 bucks? Ideal clamps? Then I usually buy a different brand that aren't the same sizes and end up with a drawer full of boxes anyways. If folks are unaware boxes of clamps are much, much cheaper than individual. Like if you're already buying 2 often for the price of 3 or 4 you can get a box of 10 or 12. Kinda like car tail light bulbs(other than headlights).
If you remove the rad and it's an auto you've gotta unto the ATF lines as well as the rad hoses. Unplug fan connectors, 2 bolts for rad supports, 2 hoses, 2 ATF lines, and you're good to go. Somehow I usually get ATF in the pan with the coolant but am usually putting new coolant in anyways. Sometimes the ATF lines can be hard to reach(lower one) and be a bit crusty. So often for me it's whether I wanna hassle with typically older ATF lines (clamps will be junk - that's part of the problem). Another factor for you could be if you're doing the WP you'll be draining the coolant anyways.
The cars I see typically are far beyond that before needing replaced. However if the baffle plate was leaking. Of if they didn't know how to drive a stick. I'd suppose a lot of city driving or towing. Other things come to mind. But that isn't many miles for any clutch it would seem if they knew how to drive.
Ethanol free gas is "real gas". What you car was made to run on. If anything will help your car, pure gas will.
That's cause it's been force fed to the rest of us. You folks probably know how evel it is and laugh all the way to the subsidized bank! Clueless and "green" politicians strike again.
A few suggestions. Are you nuts? An 'R' title, 200k and needs an engine. For 2k? Outbacks must be worth more out there but if you can't do the work yourself you're probably better off taking a pass on this one. A 2.2 would be the answer rather than tryin gto figure out what is messed up with this one. And that's probably gonna run you 1k or so. Now you're over 3k into an 'R' car with over 200k and you get to find out what ELSE is wrong with it. Things like torque bind, rod knock and such. Folks here will do their best to help. But I'm thinking you outta pass if you can't 2.2 it yourself. And even then it's questionable.
