davebugs
2
Everything posted by davebugs
I've thought about trying to use electrical tape to hold the bolt in the eye. It is often frustrating. I use the connector end to help maneuver the eye of the knock sensor. Often I stick a magnet to the side of my 3/8 wobble extension and that's just barely enough to help with the bolt. FYI Gearwrench does make extensions with a magnet at the end. Just an awkward place. Atleast it's easy to see what is happenning, just hard to reach. Still haven't found the best consistent approach. Always involves a magnetic pick-up tool and swearing - and a sore back.
There is lots of good info here about doing the job. The "skipnospam" link is one of my favorites and probably the best available now that endwrench is gone. Now threads about folks that'll show up and do the job for 200 bucks - those are rare - and should be. Cause it ain't gonna end pretty. Threads and writeups on how to do it properly are all around if you search. If I were still traveling to Woodstock VA with regularity I'd offer a hand. Although this accident has me pretty busted up at the moment. Do it right. OEM gaskets, have heads checked, I always pull the engine, crnak/cam seals, WP, idlers TB and acessory belts, spark plugs, reseal baffle plate, etc. Lots of folks start out cheap. And if they don't realize what that actually is gonna cost them - well - atleast it's entertainment for the rest of us. Find someone here or the instructions here and do it yourself. Please search a bit on your own. As you see there are lots of folks here to assist you along. But it goes better if you've done some of the investigation yourself. Good luck. Hey - I posted in a thread I said I was done posting in! Sorry. But atleast the outlook is looking better.
As pointed out the compressor shouldn't still be on when you are reinstalling the strut/spring assy. Sometimes spinning it to get the top 3 bolts (from memory) to lign up can take a little effort. Struts/springs make me uneasy too. I actually thought about getting one of the nice wall mount units but they went for like 500 bucks at the acutions I went to last year. I'm a hobbyst not a professional. Often if during "normal business hours" I take them to a shop and pay them a few bucks to swap put the struts in the assy for me. Respect for struts is healthy - for me atleast.
200 is a fair price for a timing belt/idler crank/cam seals WP job alone in my opinion done correctly. Don't know you or this guy. But I wouldn't go for it. I won't post anymore in this thread. But especially if you take the cheap route I hope you'll update us a few times over the next several thousand miles.
I don't believe copper spray is warranted or a good idea on a Subaru. I've used it a lot on VW 1.8 and 2.0's but never on a Suby. Personally I don't think you can do near as well of a quality job with the engine in the car. Well, you probably can if you wanna make a point of it. But really it's not time well spent in my book. It's a lot harder to prep the block and see what it looks like for instance. Then you know the baffle plate is gonna need resealed (even though yours may be aluminum). I'd guess this kinda fella won't use OEM gaskets either. I'd pass myself. I'm thinking you may be out more than 200 bucks by the time you fix it again. YMMV
Paper towels and rags mostly. Some goodwills you can buy a garbage bag of rags for 5-10 bucks usually mostly towels and t-sirts. I have been known to buy their used "flannel" sheets to detail cars with. Also sometimes I can get pretty used up rags cheap from one of the uniform places cheap but they are on their last legs.
man i hate these kinds of pm's and was in a car wreck in the 10th so not typing well
EM me at davespillers@hotmail.com please put USMB in subject line
both of these are a bit obvioud - don't be offended. the flex joint is the very likely culprit. is you pulled the entire exhaust in one piece to test i still dont think you could test this well. the other is that the baffle plate is leaking and you're smellin oil and not exhaust. typing one letter at a time left handed - sorry for lack of punctuation
Someone probably didn't put the little holder back on the lower eng/trans bolt on the pass side to hold that O2 sensor wire and it rubbed. I doublt they go over 200k. There are probably 2 (forget ehat year you're working one). Search for discussions here. One is thought to be needed to be OEM and the other generic seems o.k. I always buy OEM because I don't need a collection of aftermarkets that didn't work. Search for "tubing wrench" - like I said probably even on Sears site. I don't have a 7/8 tubing wrench. On a Subaru the connector is small enough that I use a 7/8 box end. Easy to hit with a hammer too. But keep soaking that puppy.
Tubing wrenches are great. Especially for brake lines. I even use one for that EGR tube that goes from the block to the drivers side head in the back when doing HG's. More contact points than and open end, but still with an opening to get around brake line, or other "tube". Sears puts them on sale a few times per year. SOmetimes the better brands are thinner and sometimes that's nice.
