davebugs
2
Everything posted by davebugs
On my VW diesel it calls for H rated. I put T's on one time. Squealed, washed out, etc. I do see triple digits but never over 125 or so. I'm cruising on an interstate for long stretches at high speeds. The tires would squeal on on/off ramps and locally when cornering. Wore faster too. Yes I checked the pressures, rotated, etc. When I was considering the T's the fella at the tire shop recommended NOT going down to T's if you were used to the handling of the H's even if not doing high speeds. I only tried one set of T's so it could have just been that particular brand/model of tire. The snow tires I get are T rated. On a Suby I don't think the rating matters, you won't be going fast enough. And worst case they may make more noise or wear faster.
Do a little searching on the rear main seal around here. Most folks, including myself recommend NOT replacing it. Lets put it this way. I've probably done close to 100 reseal jobs on 2.2 and 2.5's. The only 2 that I had to replace the rear main is because someone had replaced them before. Typically a tranny shop. The baffle plate is what leaks and folks think it's the rear main. Yea - I know the rear main may require pulling the engine (or tranny) again but it's one of those rare instances where it's usually better left alone. The "I'll do it while I'm in there" can often bite you with this one. That said the 2 I did have to install I used PVC to set and didn't leak. But seriousely do some searching around here and develop your own opinion on the rear main. Good luck. Search for "skipnospam" has one of my favorite writeups. Get a 14mm Swivel socket for especially the drivers lower nut. And IIR a 12mm swivel socket or offset box for the flex plate bolts. Other than that read up on making sure the torque converter is seated properly before re-installing the engine. On the rad flush. I prefer to support the local tradesman (who are a vanishing breed). He charges me 20 bucks for a flush and pressure check. And he's on my way to the shop that does my heads. I'd guess he does a better job that I could. Then again if you'd do a flush with the rad in the car it might catch some crap in the heater core as well. Also read up on "burping" the 2.5. Can be a bit moody and there are a few tricks. Have fun. Not really a difficult job. Oh yea - read up on making SURE you get the harmonic balancer/crank pulley TIGHT.
Chad, It's you car. Do you really wanna risk those idlers (especially the splined one by the WP) to go over a quarter million miles without a failure? I don't. And they are very easy access when doing a TB job. The Ebay ones are reasonably priced. Hope you make the next 100k. If not it's really not much money saved (or agrivation).
I second the OEM Metal WP gasket and only ultra-grey for oil pan, baffle plate, oil pump. I also ALWAYS do oil pump O-ring, crank and cam seals - again all OEM. If you're working on an engine and the seals are black always replace them. If they are brown it's a tougher decision - that means they are OEM. IIR they each are around 8 bucks and are accessable when doing hte job you're doing so why not do them? Again while I'm in that deep I always replace all crank/cam seals. I use PVC pipe to set them. A note on the the oil pan and oil pump. If you go to a parts store they sell Fel-Pro or similar from a GASKET company. From the factory these things don't take gaskets just ultra-grey or anerobic(sp?). But if you ask for a gasket at a place that sells gaskets you'll come home with a gasket. I think Ultra Grey does better. You'll need Ultra Grey for the front cam caps in the corners anyways if you tear down the heads to have them checked. I always get the radiator flushed and pressure checked because by the time I get the car lots of "miracle cures" have already been tried. For VC gaskets I usually use Fel-Pro. Exhaust is a todd up but OEM seem thicker and are the same price as Fel-Pro but often you can re-use the old ones. Intake gaskets don't matter to me.
I've usually found that where the pads sat is hard to do by hand well enough. If the rust got deep enough they will never really get totally smooth and you'll notice it a little when driving. If I have a car set for a year I plan on new rotors/pads and I closely check the brake lines (living in the rust belt and car is often parked in grass).
I've had issues with a 99 Forester. Took 3 engines to get a good one. A 99 forester SOHC was bad, a 2000 Legacy SOHC, also bad, finally a 2001 Legacy SOHC. If you think the timing belt you have for the 99 is impossible to install on the Legacy engine this is exactly what happened to me - and they call for a different timing belt. IIR the one for the 99 SOHC is smaller and when I couldn't get it on I called the parts store and the Legacy engine actually took a different belt. I swapped intakes, for some reason I believe motor mounts, etc.
You can definately get the PCI kits without the belts. But often it's cheaper if you get the entire kit and throw away the belt. They are actully fairly priced on the new style tensioners as well. I did install one of their MitsubOshi belts a few years ago on a 95 2.2 swap with the future owner's knowledge. As far as I know it's o.k. But being the paranoid sort I have a few of them here because I wouldn't risk one on an interference engine.
