davebugs
2
Everything posted by davebugs
I got the IR reader and some of my rechargables are now charging because I think it said they were low. LED screen worked but no laser dot or readings. On this toyota the cat is on the front of the engine jsut after exhaust manifild and between engine and rad assy. Seafoam didn't work. I was gonna pull the second O2 sensor on whichever bank and add a non-fouler. Car has 138k rust belt miles on it. Have to think what heat shield fsteners I'm gonna break and what shape O2 sensors may be in as far as removel. I replacement Walker is like 600 bucks and replacements never seem to last. I may ignore the car until tomorrow. I had assumed cats were under the car. This thing is stupid layout. Throttle body is half way down engine between engine and firewall facing upwards. I try to stick to VW's and Subaru's even for friends and family. But sometimes I get other vehicles that folks ask for help with.
Correction. I've never seen a Subaru engine (2.2 or 2.5) mix oil and water. I have some trouble typing and getting words out of order after my accident. So I try and proof read real well but was in a hurry this morning. Time is moving quickly and coming up on 2 years and I seem to not be getting any better anymore. Same as the physical issues. The 2000 and up 2.5's you seem to be able to basically add a little coolant indefinately. And usually the car will leave coolant marks where you park it, not much but if you look for it some. But they don't overheat due to air pockets in cooling system like the 2.5 DOHC's. I keep a few bottles of the "conditioner" here.
Thanks. I ran out of patience to stop there this evening after hitting 2 lowes to find the tool set on sale to be able to see the contents since they aren't listed on the website.
Actually I do have 2 turbo diesels but no need to check either of them. If I suspect a cat problem on either of them that's easily solved. I thought cat's themselves run way hot - like 1,000-1,200 degrees. But I just wan tto check the pipe before and after. HF has a cheapie that I didn't think would read high enough. Reads to 968F onsale for 19.83. So you fella's think that'll do for this Toyota and most gassers?
yea - but what temp gun do I need? Don't know how high of temp reader I need.
I'm working on a Toyota RAV4 of my aunt's. Had a miss fire (one coil pack and 4 plugs - old ones actually looked o.k.) and it was fixed for a week. Catalyst below effeciency. Seafoam works for a few days. About to try non-fouler but vehicle isn't here so unsur e if there is room. My real question is how high of degrees F do I need to ba able to read before and after cat to see if cat is actually clogged a bit?
I've gone through a few. My latest is a Kobalt it's black, seperate motor and compressor. 110v. Overall it works well, now close to 400 I believe. On wheels. I've had it I'd guess 4-5 years. Stay away from oilless that cmbine motor and compressor unless you enjoy lots of noise and short life. Short life if running something like an air drill, grinder, sander, etc.
Actually VW/Audi coolant is different, and doesn't play well with others. And it's supposed to be "lifetime" just like their ATF. I don't believe in any fluid being "lifetime". I replace coolant with G12, or now super duper G12 every timing belt at 100k on my TDI's. The VW's I happen to have (early 2000's) are known for wimpy automatic transmissions. Both on the ATF side and the diff side so I do both of those fluids every 40-50k.
They differ by the EVAP hoses at the top. IIR they changed around 98 when the charcoal canister got moved to the back - I never tried but you can probably replumb if you get the wrong one. IIR over 100 at dealer, someone lists redone ones with warranty on Ebay for about the same price. DON'T install plastic protector on replacement.
Imagine owning a working Subaru 360 Sedan
davebugs replied to 2stroketurbo's topic in Historic Subaru Forum: 50's thru 70's
Looks like a fun little car. Too bad it's not still in PA like that old inspection sticker. I'd definately check it out. -
I used a round prybar from a cheap set that was tapered at the end. But I also took a chunk out of most of the pistons on that blind side. I was scrapping the engines anyways. But it wasn't the best method. Perhaps the flat end makes a significant difference.
