biggman100
Everything posted by biggman100
Latest developments with this issue, as well as some more info. I used the 2.2 bottom end in this swap, changed the crank and cam pulleys from the 2.5, and the intake and wiring from the 2.5. I went to pick the car up this morning, drove it home, ran fine, no issues, pulled in my driveway, shut it off, restarted it, was running, and then it died. Changed the crank and cam sensor, new oem crank sensor, known good cam sensor from old engine. Will not start, acts like it is getting no fuel, and isnt showing a spark. Went to see if it had any pending codes, and it shows P1510, P1512, P1514, and P1516, all IAC codes, and no other codes. What is odd is, the way the car dies. Except for the one time in my driveway when it died at idle, the other times it died, i was between 25 and 30, the second time was right around 55, the third time, i was doing 40 going up a hill, and the last time, i was doing 15 just starting up a hill. Wouldnt the IAC only cause it to die at idle, and not under load? What it will do is, lose power, slowly coast to a stop with the engine surging between 250 and 600 RPM's, and, also, chug kind of like a diesel does, and then would just quit, and not want to restart, unless i let it sit at least an hour or more.
Ok, some clarification. I only unhooked the battery the first time it died, and then the second time. Since then, i havent unhooked it. I have started it at least 15 times, drove it about 5 miles, it dies, then let it sit, drove it about a mile, it died again, which means, in total, it has died on me 7 times since i started driving it, of those, i only unhooked the battery the first 2 times it died. As for the igniter, i am leaning away from that, only because before i pulled the engine i didnt have any issues with it. The cam and crank sesnor though, are the ones that came with the 2.2 when i got it. I got a used 2.2 from a car that i knew ran well, but then got wrecked, and i never asked the guy who owned the car if he had any issues with it. For all i know, the cam or crank sensor could have been bad, and it died on him, and caused it to get hit, so, i will swap them in the morning and see what happens. Is there an easy way to get the crank sensor out without fighting with it though? Everytime i try to take one out, they break.
I would doubt it is the Ignition control module, only because, i pulled the original 2.5 3 days ago, and it was running fine with the old engine, but knocking bad, which is the reason for the swap, swapped the cam and crank gear, put in a new timing belt, components, and water pump, but i didnt swap the crank or cam sensor, but, if it was one of those, wouldnt that cause a code to at least be pending? The last time it died, i just left it on the side of the road, and havent went back and got it yet. I didnt even unhook the battery this last time. But, would a bad cam or crank sensor cause it to lose spark and fuel?
Here is the situation. I have a 2000 forester, automatic, that i just did a 2.2 swap in, and after the swap, which was finished yesterday, it started and ran every time i hit the key. Got it done, cycled the antifreeze, got ready to take it for a drive, got about 4 miles, stopped at the gas station, got gas, restarted it, got about a mile, it died with no warning. Cycle the key, no fuel pump sound, turn it over, no spark. Disconnected the battery, reconected the battery, it starts, goes about a mile, dies again. Tried disconnecting the battery several times, no results. left it sitting on the side of the road approximately an hour, go back, starts right up, goes about 5 miles, quits, wont restart. I tried cycling the key 3 times, just to see if the security system was acting up, no luck. I dont have a remote for it, but i did try to program the remote from my 99 legacy, with no luck. It wont even go into programming mode. I tried to find the button under the dash to disable the security system, and cant find one, and then was told that year didnt have that button. Each time it dies, it acts like the security system is disabling the fuel and spark, but, the security light on the dash never comes on, not even to blink, and disconnecting the battery and reconnecting it, the lights dont flash, and the horn doesnt sound, so i am at a loss as to what could be causing this.
The head unit isnt even a newer one. Its about 4 or 5 years old. I dont know if it would make any difference, but the head unit is actually a JVC, not an Alpine, but when we first got the car, it had an Alpine that was supposedly a few months old, and it stopped working not long after we got the car, so i just stuck a cheap JVC i had from another subaru in it. I enclosed a pic of it, so you can see what it looks like. As you can see from the pic, no usb, no dvd, no navigation, just a basic am/fm cd player.
The problem is i dont have the remote for the keyless entry system. I did try disabling it by cycling the key 3 times, but since it is only a keyless entry system, and not a security system, it didnt work. And as usual, the local Subaru stealership was no help. They want me to bring it in and pay up to 2 hours diagnostic time, just to tell me what the problem is.
Ok guys and gals, here is an odd one for you. I have a 1999 Legacy L wagon, EJ22, automatic, that i put an alpine aftermarket head unit in. The other day i replaced the battery, and the door locks wouldn't work, except once in awhile, but tonight i was driving it, and everytime i changed the radio stations, the door locks would cycle, as in it would lock and unlock on me while i was driving. I thought maybe it was a coincidence, so i parked it with it running, and just kept changing radio stations, and it did it everytime. Any ideas on what to look for? I was changing the stations by pushing the buttons on the head unit itself, not by using the remote for it.
We may have found the problem, and i was wrong in one of my earlier posts. I had my brother check it at his shop, and he found that the drivers side wheel bearing is extremely loose, so he is gonna replace it in the morning, and see what happens. When i did all the brake work, i thought i checked it, but i may have overlooked it somehow.
That is one of the things im leaning towards, mainly because even though i hear all the time they rarely fail, the car sat for quite awhile, and who knows what the P.O. did when they had the car, or even if the brakes were one of the issues he parked it for, since after i bought it, i found out he isnt exactly the honest type at all, i just dont want to spend the time and the money to do it, and have that not be it. The thing that sucks is, my outback's front brakes are different than the legacy's, so i cant just swap the mounts and rotors from one to the other and see if that changes anything.
We have been driving it this way since about mid february. I was planning on leaving it at monro and just let them diagnose while we are out of town for the weekend, and take my other car, but now it seems that car is having trans issues, so we might have to take this one when we go, so i was just hoping to have an idea before saturday morning.
The impreza uses a completely different bracket for the a/c/alternator than the legacy, but either bracket will bolt to that engine. When i did my EJ25 to EJ22 swap, i took the EJ22 out of an impreza, and had to use the a/c/alternator bracket off the EJ25, but it bolted up with no issues on the EJ22 engine.
This isnt a one time issue, when you first start driving it, it happens every time you hit the brakes. It doesnt matter if it is every 50 feet, or every 200 miles, each time you hit the brakes, it always acts the same. I have checked wheel bearing, and all the front end components because it had a vibration we finally traced to a bad wheel, so i know nothing is wrong there. The only things i can think of it could possibly be, are the front rotors somehow causing it, or either a bad booster, master cylinder, or the front caliper mounts somehow screwed up from being rusted from sitting. I have just spent so much time on these brakes, and replaced so many parts, im starting to think it is just jinxed, so i figured before i messed with it again, i would see what the people on here had for ideas.
We bought the car in january of this year, after it sat in a guys yard unmoving for 11 months, and i figured that the brake issue would be because everything was rusted or frozen, which is why i replaced and repaired the stuff i did, but the brake issue is still the same no matter what i do to it brake wise. The parts i replaced are as follows: Front pads, new semi mettallic, front calipers, rear calipers, pads and rotors, all about 5 months old, that i took from my other legacy that got wrecked in a walmart parking lot by an idiot, just after i finally had the car the way i wanted it.
Yes the car has ABS, but i have the FSM, and also checked what it said in their against what several people on different subaru sites have said, and i made sure i bled it each time the exact way the FSM stated. I have also checked the master cylinder, and have done all but the vacuum tests on the booster, and so far it all checks out, and im done putting parts on it that the FSM says could be bad, just to find out it doesnt fix the problem.
