scotte6
Everything posted by scotte6
Sorry, forgot to add that point that the defroster is off. I think I was on the right sensor earlier today. It is plugged in. I unplugged and re-connected to make it it was making a good connection. There was two wires going to it and I think one was white with blue trace and the other was a yellowish color. Does that sound right? That was one thing I checked over because it made sense that something was left unplugged but I can't find it!
Reinstalled timing belt, this time used the marks on the belts, not really sure why I did not the first time. Anyway, running "so-so", thought it was good, but ended up getting a CEL. Have not had a chance to pull the codes. Adjusted TPS about the same. Checked tps voltage, get 5 volts all the time. Checked resistance of TPS and it changes with the movement of the throttle. At this point it will not idle, just stumbles and stalls. Any suggestions? Should have codes Sunday afternoon. Thanks!
Just thought I would post a quick update. I got the heads back tonight, the shop said one of them was warped (.006), from what I heard the acceptable limit is .002. So this could explain why the hg's did not look bad but it was overheating. Now I wonder what caused the head to warp, heat no doubt, but what caused it to oveheat to start? My plan is to spend Saturday trying to get it back together, will update this when I get done.
OK....heads are at the shop, they con provide "Felpro" gaskets there, are they ok or should I go straight to Subaru? The shop is also doing a "valve job" so they need the valve seals in order to complete. Car did not overheat much went water pump went. Yes it did get hot, but it was hotter last week than when pump failed. Is there a way to identify the original factory gaskets?
I bought the car in the end of March, it had ~ 124,000 miles on it at that point, now I am up to ~ 133,000. The water pump went aroud the end of May, replaced that and the timing belt at that point. Sending the heads out today to be pressure tested and resurfaced. I guess then put it all back together and see what happens. Unless they find something when they are testing the heads I'm gonna be a little nervous until I run it down the road.
ok, now I am worried. Got the motor out yesterday, wasn't to bad, pretty much as explained on here. Pulled heads off today and I CANNOT find any sign of a BLOWN HG! Gaskets appear to be 3 layers, thin metal on each side over some other material. One thing I did find was one spark plug on the passenger side was loose! The cavity that the plug sits down in was black compared to the other 3 being clean. Plugs are champions, which I have heard good and bad about that, and appear to be ~ 42 - 44 on the gap. Obviously I have to push on (heads rebuilt/tested) does anyone have any ideas? other suggestions I have heard: replace plastic seperator plate with metal retighten oil pump backing bolts seal in the front of the transmission front & rear main seal new oem thermostat new NGK spark plugs oil/filter comments?
that is my intention (replace hg), I just think it will be easier to pull the engine to replace them. looks like front crank seal might be starting to leak a little too. I would rather just pull the engine so I can get at it to work on it. Got a "estimate" today of $200 - $250 to have the heads resurfaced, pressure tested, and valves done. Have not checked on gaskets yet. I just figured I might as well do everything while I am at it. Any watch-outs or "now is a good time to do that" that anyone knows about let me now. Hopefully it will be good for another 100,000.
