Losiho
Everything posted by Losiho
I guarantee you it isn't. SLX was discontinued in Australia years ago. The oil dealers use is Castrol Magnatec FM 10W-30 (a workshop oil, unavailable in retail outlets). There's no need to run a xW-40 or xW-50 in a new engine requiring a 5W-30 or 10W-30, especially during the warranty period. Dingbat, if you want "the best", in a xW-30, I assume you mean synthetic, which means your choice is Mobil 1 10W-30, Motul 8100 EcoEnergy 5W-30, Motul 300V 5W-30, or Redline 5W-30 or 10W-30. Other non-synthetic choices are Castrol Formula R 5W-30, or Penzoil or Caltex Havoline 10W-30.
Getting back on topic, I actually find the temperature control (climate control system) more annoying than the fan speed button. Sometimes when I turn the round dial clockwise to increase the temp, the temperature will actually go down ! You have to be very slow and deliberate when making adjustments. Does anyone else's Outback have this issue as well ?
Sorry, I have no idea regarding Phase 1 or 2 2.2L variations. My reply was specific to the 2.5L Legacy/Outback engine. "EJ25" is just a Subaru nameplate and ID code for the 2.5L engine. I have also heard that the main reason for Phase 1 EJ25 headgasket problems is the fact that it's a bored out 2.2L block. FWIW the new Outback/Legacy line and the Phase 2 EJ25 were released in late 1998 in world markets.
The phase 1 is a DOHC engine, the phase 2 is a SOHC. It's hard to describe on a computer without showing you a pic, but probably the easiest way to spot the difference is to look at the black cam/belt covers at the front of the engine (directly in front of the radiator). The DOHC engine will have two "humps" for the camshafts, the SOHC only one.
Thanks for the link. Over the time I've owned my Outback (almost 2 years) fuel consumption has ranged from a best of 8.92 L/100km (26.4mpg) on a long highway run, to a worst of 13.76 L/100km (17.1mpg) in city driving. Note, although my Outback is a 1999 model, it's the SOHC 2nd generation Outback model that arrived in Australia in late 1998 (our Legacys / Outbacks are imported from Japan).
RST-555......I love your rego ! Nice ride.....I almost bought a RS Turbo back in 1993, but insurance would have been a killer
Thanks guys. My service dealer (Subaru) seems to think it's normal, but I might contact them again to make sure. As I said over at the Nasioc Forum, I want to try Bendix Ultimate pads (I think they're called Axis Metal Masters in the USA ?) with DBA slotted rotors all round - the braking performance should be much better, but this combo definitely isn't dustless.
Whenever I reverse my Outback, then select a forward gear, my front dics pads make a knocking noise. For instance, I'll select reverse, slowly reverse out of a car parking space, then stop. I then select drive, drive for a short distance, and as soon as I hit the brakes with the car travelling forwards, the pads will knock (a clunking noise from the front end). I complained to my service department, who said it was "normal" and anti squeal applied to the pads is the only solution, but I have never had a car that's had the same "problem" (if you could call it that - more of an annoyance). The only thing is the effect of the anti squeal they applied to the pads at the last service only helped for about 100km before the knock came back. Do all Outbacks suffer the same problem ?
