1997outback
Everything posted by 1997outback
  1. Test light did its job. Used the cigarette litter fuse for the panel. Thanks for the advice.
  2. That is one way. Thought a guru would know
  3. I have a 1986 DL wagon. I want to instal a 6 gang switch. The panel needs to be wired to the accessories fuse, the one that powers when the key is in. Which one is it?
  4. I know. So simple yet some hard. Not very mechanical.
  5. I found on Facebook group. guy name is David Melcher. he seems to have lots of parts. out of Redding CA. hope that helps.
  6. in the fuse panel, there isn't a fuse labeled blinker. who should I be looking for?
  7. it was a switch that fail. took 4 years to figure out so lame. But I have a heater now.
  8. hi all, I have a 1986 DL wagon. I had to replace the alternator. once installed on the test drive the blinkers don't work. could I have shorted the blinkers. not sure where to start to find the problem. any help would be great.
  9. the air is hot when o am driving. doesn't change power with e switch. where is the relay located? can someone post a picture? thanks
  10. hi, my 1986 dl wagon recently had the heater motor fail. it was weird. I arrived at my designation and turned off the car. the heater was still blowing. it turns off once the car if off, I had the key out. then I turned the knob to off and it still was blowing. is there a relay I cam check? the fuses are good. what can I check? what do I need to replace?
  11. therE is a hose under the carburetor that is leaking. Going to replace a few other hoses that are stiff.
  12. I’ll try that. When I just check the reservoir was empty. Only drove it about a mile. I can see coolant in the radiator when I remove the cap.
  13. hi everyone. i am losing a lot of coolant in the 1986 dl wagon. the temp gauge does not go to overheat. what could cause that? could it be a hose. i don't think it is the head gasket since it don't overheat. going to check hoses and the recovery tank. maybe water pump? any ideas.
  14. Hi, I have an 1986 dl wagon. I need chest belts in the back for the kids booster seats. Has anyone upgraded the belts to chest belts? Could I bolt to side pillar?
  15. Was able to find s guy parting out a wagon with the drill out hubs.
  16. Hi. I want led hid head lights. Bought some but might have been wrong ones. I got 9004/hb1 led headlights. Has anyone else try this?
  17. Would I drill the hubs? That is what I hav seen in the videos.
  18. Is it worth it to replace the dash clock on my 86 dl wagon? It’s not necessary but it bugs me. Do you see them at junkyards?
  19. Hi. Everyone. I have a 1986 dl wagon. I bought a adf 2” lift. Now deciding about the wheels. I seen the 4 to 6 lug drill out. Is There a better option? Adapters or drill out? And can you drill them out to a 5 lug? In Washington so lots of Subaru shops to do the work.
  20. I want to update my oil cap. Can I use a cool modern one from a aftermarket subbi dealers!
  21. What kind of skid plate you all run? Looking for options for my 1986 DL wagon.
