Everything posted by 1997outback
Test light did its job. Used the cigarette litter fuse for the panel. Thanks for the advice.
That is one way. Thought a guru would know
I have a 1986 DL wagon. I want to instal a 6 gang switch. The panel needs to be wired to the accessories fuse, the one that powers when the key is in. Which one is it?
heater blower failure
1997outback replied to 1997outback's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I know. So simple yet some hard. Not very mechanical. -
I found on Facebook group. guy name is David Melcher. he seems to have lots of parts. out of Redding CA. hope that helps.
it was a switch that fail. took 4 years to figure out so lame. But I have a heater now. -
the air is hot when o am driving. doesn't change power with e switch. where is the relay located? can someone post a picture? thanks -
hi, my 1986 dl wagon recently had the heater motor fail. it was weird. I arrived at my designation and turned off the car. the heater was still blowing. it turns off once the car if off, I had the key out. then I turned the knob to off and it still was blowing. is there a relay I cam check? the fuses are good. what can I check? what do I need to replace?
therE is a hose under the carburetor that is leaking. Going to replace a few other hoses that are stiff.
Why doesn’t it overheat?
I’ll check tomorrow. Thanks.
I’ll try that. When I just check the reservoir was empty. Only drove it about a mile. I can see coolant in the radiator when I remove the cap.
hi everyone. i am losing a lot of coolant in the 1986 dl wagon. the temp gauge does not go to overheat. what could cause that? could it be a hose. i don't think it is the head gasket since it don't overheat. going to check hoses and the recovery tank. maybe water pump? any ideas.
Hi, I have an 1986 dl wagon. I need chest belts in the back for the kids booster seats. Has anyone upgraded the belts to chest belts? Could I bolt to side pillar?
Was able to find s guy parting out a wagon with the drill out hubs.
Hi. I want led hid head lights. Bought some but might have been wrong ones. I got 9004/hb1 led headlights. Has anyone else try this?
'86 GL Wagon Original Clock - Weird
1997outback replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How do you remove the dash clock? Just pop it out? -
Would I drill the hubs? That is what I hav seen in the videos.
Is it worth it to replace the dash clock on my 86 dl wagon? It’s not necessary but it bugs me. Do you see them at junkyards?
Hi. Everyone. I have a 1986 dl wagon. I bought a adf 2” lift. Now deciding about the wheels. I seen the 4 to 6 lug drill out. Is There a better option? Adapters or drill out? And can you drill them out to a 5 lug? In Washington so lots of Subaru shops to do the work.
I want to update my oil cap. Can I use a cool modern one from a aftermarket subbi dealers!
What kind of skid plate you all run? Looking for options for my 1986 DL wagon.
