1997outback
Everything posted by 1997outback
  1. not sure what brand, i live in socali but moving to WA this winter. any ideas?
  2. i check and i did not notice any "D" ring under the seat when i fliped it up. the obw does have top strap anchors, but that wouldnt help. we went to the chp and they help us fit it better.
  3. so does an 2000 obw limited have latch system, or anchors? my 1st child is due anyday now. pic would be awesome.
  4. those pics are great i have a 97 obw also. if you dont mind how much did it cause parts and labor? and do you have to be an expert to do a lift like this?
  5. where di you get the light bar?
  6. my gas final turned on, the guage would be way below E and not ture on, this time a run low as possible and it turned on.
  7. ok i got the clip and now i cant get in place. there isnt enought room. should i take off the window? and is that hard?
  8. hi everyone i cant seem to locate the dip stick for my 2000 obw. i need to check the level, there is a delay when i shift into drive from park. thanks
  9. Technical Service Bulletin were can i find one for a 2000 obw with trany delay. is it a thread?
  10. i unscrewed the top part to my power antenna, can i replaCE it with just a mast?
  11. i was able to slide it in place. ill look for a clip th next time it falls out. thanks, i might just brorrow one from the back door.
  12. can you just get the clip, i put the linage back on the the clip is broke.
  13. my driver side door latch will not open when i lift the handle from the outside. but will open from the imside, anyone have had this happen before?
  14. what is better to add the seafoam to the gas or to the injector? and how do i add it to the injector?
  15. its passed yesterday, it was hard to drive 50 mph on the freeway but i made it, passed just fine!! thanks for the help. it eases my mine about my purchase.
  16. the plug that goes to the bottom isnt hard to reach, on the 97 outback, there doesnt seem to have much room to reach down in there, but sounds easy enough.
  17. my subie guys told me to get the one that are red, the dealer only had the one in the box, and they are black with red boots. how hard are they to install, for a rookie owner?
  18. i need a ignition coil of my 97 leagacy ob, is it better to get a used part from a junk yard or need from dedaler? and the wire i hear that the wire in the pack/box are not as good as the ones you can get individually. does anyone have any advice?
