Occupation
none
Vehicles
1988 Gl hatch
glwagonman's Achievements
Advanced Member (3/11)
10
Thanks everyone! I found it on the New Hampshire CL and picked it up for $650. It's an 88 sadly its not 4wd, but fwd will have to do. I plan on keeping it stock and just getting as much as I can out of it till i'm done with college. once i'm done with school ill have enough money to insure my WRX again!
Just picked up this beautiful Gl hatch. The thing is rust free and only has 170xxx miles on it!
The altinator is good and every thing else in the cluster is functioning just fine I'm really stumped about what is going on
ok so i just got my 1987 gl wagon up and running when all of the sudden on Saturday my fuel gauge and voltmeter stopped working also my coolant temp sensor all at the same time i checked the fusible links they all seem fine i checked the cabin fuse box and the back of the cluster and i cant find anything wrong are there other fuses i am missing? or is the wiring in my car just nuts if anybody has any thoughts about this problem please let know what you think it could be Thanks in advance for any help
its a hitachi carb non feedback and to my knowledge it has never been rebuilt so i think i will start with that thanks guys
whats the best way for tuning the carb? i just got my wagon back together and my manual does not have very good info on tuning it? Thanks in advance:banana:
me and a buddy of mine lifted my ea82 out with a pice of rope and a roofrack it was awesome!
i figured it out i hooked up the vacuum lines all crazy so i redid them and it runs fine Thanks guys
i was thinking it could be a vacuum leek im looking in to that but by extremely high idle i mean it just goes up intil i shut the car off its like its running on starter fulid
so i just rebuilt my 1987 gl wagon Ea82 Carbed it starts up but the idle just keeps going up and up anybody have any ideas about what this could be? Thanks in advance for any help!
OK Thanks for everybody's input ill keep my eye on it
OK thanks i had just never noticed it before:banana:
i was out for a drive tonight and i noticed when i would stop at stop sings the oil pressure would drop to 0 until i hit the gas again so when i got back i parked it in my garage and the oil pressure went right to 0 so i checked the oil and it was fine looked under the car nothing leakin out its a 1987 gl wagon if anybody has had or knows how to fix this problem Thanks
OK i looked where they go the one that goes straight back goes right into the intake manifold and the one going right goes to the bowl vacuum valve and then to the carburetor
the valve im talking about is right behind the carburetor and it has a a blue and black wire with a two pronged connector two hoses hook up to it one going straight back and one to the right(looking from the front of the car) and on the diagram on the hood it say its solenoid valve 4 i started the car without it and it would not idle so i plugged up the tubes and it idles normally i just hope its not bad for the car im going to try and get to the junk yard this weekend
