wildwagonz
About wildwagonz
- Birthday 06/09/1985
Location
Crossingville, Pa
Occupation
Business owner
Biography
Hey im Tim and have had a passion for old Subarus since I was young. I have many old soobs in my collection from 79 wagons to Xt6 to svx etc
Vehicles
I Love My Subaru
wildwagonz's Achievements
Advanced Member (3/11)
11
OK......so I measured the resistors ohms and it came up 12.7 figured it was within spec. Then checked the tranny connectors they were not crushed all seemed fine. Measured ohms on #5 red wire to ground got nothing, pulled tranny pan measured solenoid pin to ground still got nothing all other solenoids were measuring something around 12 ohms but nothing on the line pressure solenoid. So does that mean its bad?
Hi all, I just finished changing the engine in my friends 02 Legacy (threw a rod at only 114k miles) No problems tranny wise prior to the engine swap, got the engine in last night and now I have a flashing AT Oil Temp light and a Check Engine light on as well. I read the CEL with my code reader and it comes up P0748 pressure solenoid circuit. Then I did the "secret handshake" to get the TCM codes and I get 7 long flashes and 5 short flashes for a code 75. I have searched all day today online and came up with the possibility of dented transmission pan when i jacked it up to drop the new motor in. I checked the pan and it doesn't appear bent but the bottom does seem a slight bit (VERY SLIGHT) caved in. Its just the ever slight concaved, and when I say slight i is barely noticeable. Could it be thats the problem? I am going to pull the pan off tomorrow to check everything out. Just was wondering if someone can elaborate on what exactly happens with the solenoid or if someone else has had this happen to them? Could it be something else? I checked all the connectors on the transmission on the top near the firewall and they all are fine. Thanks for your help in advance. ~Tim
Just a useful sidenote regarding your 90 legacy....my Subaru mechanic coworker/friend told me a while back that the 90 legacies with an early production date were notorious for the blocks cracking causing the problems you are experiencing, I ran into this with my 90 legacy as well which was made in 89. Replaced the engine with a 91 2.2 and all has been fine since. Had another friend with the exact same problem too
tWell my 97 legacy 5speed is grinding when I shift into 3rd. Car has 170000 with a 2.2. When the car is cold it shifts perfectly then once the engine/trans is warm it has a slight blip of a grind only when I shift into 3rd. Its the sane every time I shift just a slight grind but still runs and drives fine. I was just wondering why it does it only when its warm and no cold? Should I use thicker oil? I just want to do whatever I can to keep it from getting worse. Thanks in advance...
I still have the pan down, I was thinking it could be that, but I thought that only effected the 3rd to 4th shift....... I will replace it anyways, Anything else I should check or replace while I am under there.... I just dont understand this thing, it shifts like brand new EVERYTIME once it is warmed up Whats the procedure for checking the ATF oil temp codes, I searched and came up with gound out a pin #5 I think it was then do the whole shift through gears and press gas pedal....is that right? Thanks
